10th Mar 2023, 4:35 pm | #1 |
Field coil speaker?
This is the speaker in my Marconi C10A corner radio. It seems to have a lot of wires attached. Is it a field coil type - I have never seen one in the flesh.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
10th Mar 2023, 4:48 pm | #2 |
Re: Field coil speaker?
Yes, two wires to the usual speech coil and another two to the field coil (950 ohms).
10th Mar 2023, 5:43 pm | #3 |
Before you do any restoration work it would be worth checking if the field coil is open circuit, as they often are.
If it is, you'd need to decide whether to have it rewound, which would be quite costly, or whether to replace it with an 8" 3.5/4 Ohm permanent magnet speaker. If you did that, as the field coil also acts as a smoothing choke, you'd either need to buy a suitable choke, rated to cope with the HT current, or use 1K resistor of suitable wattage. The are two lots of service data - 4 pages of RER, and 2 pages of Radio Servicing. If you don't already have it, the RER one in more comprehensive in that it has above and below chassis component placements, and the two dial stringing arrangements (which look like the work of Satan.) It went on the market in October 1947, rather late in the day for a field coil speaker, so was probably a design which dates from say 1939, paused for the war years. If the field coil is intact, I'd be cautious about running the radio for long before checking it out, (leaky capacitors etc) and only through a lamp limiter, as excess HT current might/would be 'curtains' for the coil. Good luck with it.
10th Mar 2023, 6:06 pm | #4 |
Thanks - I can see it on the circuit diagram now.
10th Mar 2023, 6:10 pm | #5 |
I have no experience with this type of speaker, but the Odhams "Radio Television & Electrical Repairs" book describes a type where the field coil has an additional hum-bucking winding that was connected in series with the speech coil to neutralise residual hum induced by the field winding. So a field coil could have two sets of windings.
I think that Dad's late 1940's HMV table radio had a mains-energised speaker. |
10th Mar 2023, 6:13 pm | #6 | |
Roger
10th Mar 2023, 7:47 pm | #7 | |
Lawrence. |
10th Mar 2023, 7:56 pm | #8 |
That's a good point about a hum-bucking winding, most field coil speakers had one. In this case there isn't one shown, at least not as a separate winding. More about them in this thread: https://www.vintage-radio.net/forum/...ad.php?t=86359
Voltage checks are a good start or seeing if it works on the Gram position would show whether the amplifier stages are ok. |
11th Mar 2023, 1:13 am | #9 | |
11th Mar 2023, 10:14 am | #10 |
If you are solely using the radio as an amplifier for a CD player (interesting?) will not the line level output from the player be somewhat overloading the first AF stage?
Edward. |
11th Mar 2023, 10:40 am | #11 |
I suggest following David's advice in Post 3. As you have slight hum the field coil may still be ok, if it is you need to protect it from excess current due to leaky capacitors.
11th Mar 2023, 12:08 pm | #12 |
I haven't metered it, but the volume range seems perfectly normal and in line with the radio. It's actually a DVD player, because you can buy small DVD players which sit nicely on top of it, whereas all CD players seem to be standard hi-fi component size.
23rd Mar 2023, 8:50 pm | #13 |
Guilty party found! This is C20 on the diagram and it was looking a bit worn out (only 75 years old - planned obsolescence I call it!). It appears to my poor brain to go from the HT line to ground. Does it have some sort of smoothing function? Isn't it a bit small at 0.1uF?
Also - in the last photo you can see the rear leg has a kind of scoop out of it with two rings top and bottom. Any ideas as to what they were for?
23rd Mar 2023, 8:54 pm | #14 |
And another question. The old field coil speaker is working well, but there is a facility for attaching an ext speaker - only 2 sockets for it. Would that need to be FC or standard type?
23rd Mar 2023, 9:07 pm | #15 |
That 0.1uF/100nF cap is a decoupling capacitor having a low reactance at RF and audio frequencies, most important.
"Behind every crowd, there's a silver Moonshine" |
23rd Mar 2023, 9:08 pm | #16 |
Bulgin used to supply a 4-pin plug and socket for field coil extension speakers. This is from their 1936/37 catalogue.
23rd Mar 2023, 9:18 pm | #17 |
Well done for finding that.
The extension speaker would be a standard type. |
23rd Mar 2023, 11:44 pm | #18 |
I assume you have replaced C25, the interstage coupling capacitor.
24th Mar 2023, 12:53 am | #19 |
Yes I have. I am barely a journeyman repairer, but that was my first thought.
