Old 8th Mar 2023, 3:11 pm   #21
ms660
ms660's Avatar
Default Re: Question Murphy B40 Power Supply
No problem, here it is after being cleaned up, I built a substantial bench for it to sit on..! The jacket hanging on the back of the chair is my original leather Wrangler jacket which I bought around 1966, it still fits....just about!
Good luck with the research.
Lawrence.
ms660 is offline
Old 8th Mar 2023, 5:49 pm   #22
ToonMurphyB40
Concusion of measurent results:
Measurements show that in the mains frequency range of 40Hz - 60Hz the ‘ripple attenuation response slope’ is flat within 0.6 dB.
Result:
There is no need to readjust C316 // C317 of the (L304) resonant filter.
Toon. PE1NHP
ToonMurphyB40 is offline
Old 8th Mar 2023, 5:54 pm   #23
ms660
ms660's Avatar
Good test.
Lawrence.
ms660 is offline
Old 9th Mar 2023, 9:00 am   #24
ToonMurphyB40
The B.R.1617 manual specifies the range of 40Hz to 60Hz for the allowed B40 receiver mains frequency.
Due to the full-wave rectification for the HT-voltages, the ripple frequency is in the range of 80Hz - 120Hz.
My conclusion:
There is no reason to optimize the resonant filter components for the mains frequency range of 40Hz - 60Hz.The capacitors C316 // C317 comply for the mentioned mains frequency range.
The ‘ripple attenuation response slope’ is flat within 0.6 dB.
Toon. PE1NHP
Old 9th Mar 2023, 10:58 am   #25
Andrew Sinclair
This article from the IEE Electrical review Volume 108 Part A Number 37 February 1961. It explains the change of RN Ships mains from DC to 115V 60Hz AC.
The B40 receivers were used in shore stations as well as ships, so 240V 50Hz would have been a necessary requirement.
Andrew Sinclair is offline
Old 10th Mar 2023, 3:30 pm   #26
ToonMurphyB40
Thanks for your interesting contribution Andrew.
60 Hz will now be the standard for ships.
Old 10th Mar 2023, 10:02 pm   #27
CambridgeWorks
CambridgeWorks's Avatar
Around 10 years ago, RN ship radios were still 115V 60Hz.
We just used 115V 50Hz when testing them.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 11th Mar 2023, 11:52 am   #28
ToonMurphyB40
Lawrence,
I enjoyed the beautiful picture you sent of your ‘radio table’.
The Murphy B40 has a nice place between the other ‘jewelry’….!!!
Toon
Old 11th Mar 2023, 11:58 am   #29
ToonMurphyB40
My ‘radio table’ ….
Best regards,
Toon
Old 11th Mar 2023, 4:54 pm   #30
ToonMurphyB40
That’s interesting Rob.
This means that the ‘Mains Voltage Selector’ on the back of the B40 receiver was actually used by Navy personnel!
Old 11th Mar 2023, 5:39 pm   #31
ms660
ms660's Avatar
Originally Posted by ToonMurphyB40 View Post
My ‘radio table’ ….
Best regards,
Toon
Very nice and looks strong too, I had an Eddystone receiver, a 358X, it had plugin coil packs, also had a Racal receiver.
Lawrence.
ms660 is offline
