11th Feb 2023, 10:42 pm | #1 |
Hacker Gondolier capacitor
Hi - new member here.
I'm servicing a Hacker Gondolier and noticed that the machine I have has a 0.001uF capacitor across the output transformer. This doesn't appear on the schematic, and I haven't seen it in the various posts/YouTube videos I've come across. Can anyone tell me what this capacitor is for? |
12th Feb 2023, 1:38 am | #2 |
Re: Hacker Gondolier capacitor
I think I came across this once and seem to remember it was because someone had replaced the original amp with one from a Cavalier.
Bill |
12th Feb 2023, 10:21 am | #3 |
Or does the empty socket mounting hole suggest it was from a SERENADE (RG16) ?
12th Feb 2023, 10:57 am | #4 |
Ahha - I should learn to check carefully - the machine is in fact a Cavalier!
Is a capacitor like this worth changing? It looks like the grid coupling capacitors have already been replaced, so my original plan was just to change the electrolytics and a couple of resistors that are out of tolerance... Last edited by paulsherwin; 12th Feb 2023 at 11:21 am. Reason: To comply with forum rules |
13th Feb 2023, 12:22 am | #5 |
I would regard any supermold capacitors with suspicion.
13th Feb 2023, 12:21 pm | #6 |
If the capacitor is across the O/P TX primary, its leaky or S/C failure wouldn't damage anything though it would affect the output sound to a greater or lesser extent. Worth replacing though and stay with the high voltage rating. Transients from record scratches or noisy pots etc. can develop seriously high peak voltages across the O/P TX primary!
13th Feb 2023, 3:02 pm | #7 |
On the Hacker Cavalier schematic (on radiomuseum) identified as G.P.15, it does not show the capacitor across T2 primary.
However on the right hand side Issues column, there is a note saying R17 6.8K and C14 .001 added in series across prim T2, then a later note saying R17 & C14 deleted across O/P trans prim. Plus other notes. David Edit Update - The capacitor is shown in photo on radiomuseum. Last edited by DMcMahon; 13th Feb 2023 at 3:09 pm. Reason: Update |
22nd Mar 2023, 8:38 pm | #8 |
Thanks for the help - both here and elsewhere on this forum. I’m pleased to say the Cavalier now has new capacitors and is working very nicely!
