Old 19th Oct 2020, 6:37 pm   #1
antpant7
Default Microvitec CUB 1431ms
Hello, I have recently purchased a Microvitec CUB 1431.
So far I have replaced :
  1. Trippler
  2. LOPT
  3. Various fusible resistors
The unit powers up fine however I am getting a red background. I have tired the lowering the Red Gain however it makes no difference. I also tried disconnecting the Red Channel from the main PCB to the PCB mounted on the back of the tube, again no difference . I think it may be a problem with the PCB on the Tube.
I have attached a picture, any ideas ?
Many thanks.
Antony Myers.
antpant7 is offline
Old 21st Oct 2020, 4:38 am   #2
Kyle__B
Default Re: Microvitec CUB 1431ms
Also looks like you have retrace lines?
Maybe this would get more attention in the telly section being a CRT problem.
Kyle__B is offline
Old 21st Oct 2020, 10:18 am   #3
Station X
Station X's Avatar
Thread moved.
Graham. Forum Moderator
Station X is online now
Old 21st Oct 2020, 10:32 am   #4
cmjones01
That to me looks like the red gun is turned hard on all the time, hence the retrace lines. The fault is very likely to be on the tube base PCB. Looking at a circuit diagram here, I'd start checking TR901 and TR902, R907 and the other components in the red channel.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline
Old 21st Oct 2020, 11:20 pm   #5
McMurdo
McMurdo's Avatar
have you reset the A1 volts?
Kevin
McMurdo is offline
