Old 15th Oct 2020, 8:18 pm   #1
DavidG0MRF
Default Avo 8 mk7 current transformer
Can anyone please help identify the correct mounting points for the current transfomer in an AVO 8 mk7?
I have managed to repair the moving coil assembly but replacing the current transformer in the case is proving difficult, - I can't see if the transformer mounts on a PCB or on pillars or in the case! (Meter arrived disassembled and Megger only have a user manual no internal assembly diagrams)
Many thanks
DavidG0MRF is offline
Old 19th Oct 2020, 1:08 pm   #2
Superscope
Default Re: Avo 8 mk7 current transformer
Hi David,
The Transformer mounts directly onto the Metal Frame behind
the Scaleplate. There are no standoffs, just screws.
The Transformer has a small PCB clipped to it where it's
connections are terminated. There is then a small wiring
harness connecting this small PCB to the Main Board.
I took some Photos which might help.
Ian
ID:	218345   Click image for larger version
ID:	218346   Click image for larger version
Superscope is offline
Old 19th Oct 2020, 3:23 pm   #3
DavidG0MRF
Hi Ian
Thank you very much, those photos are very helpful. I should be able to get everything back into the case now. I just couldn't see 2 mounting points that had the right spacing between them. I do now....
Many thanks - Another AVO saved!
Old 19th Oct 2020, 4:35 pm   #4
Superscope
Hi David,
Always good to save another Avo.
Especially a Mk VII, as they are not as common as the Mk V or VI.
There is no Service Manual for the Mk VII as far as I know, which
is a pain as the construction is quite different from the Mk V for
which there is a Service Manual.
If your Mk VII happens to have a surviving Serial Number,
maybe you could submit it on the Avo Multimeter Survey Sticky Thread.
Ian
