Old 3rd Oct 2020, 2:39 pm   #1
Petedox
Petedox's Avatar
Default Transformer help needed!
I've built a multiplex decoder which I need to power from an isolated source inside a valve FM tuner.
I'm using 6.3v from the end of the heater chain. The circuit draws around 75mA.
Can someone tell me where I can obtain a small cheap 1:1 transformer that will do the trick?
Pete
BVWS Member
Petedox is offline
Old 3rd Oct 2020, 3:29 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Transformer help needed!
Could you perhaps use a transformer that has two independent, equal-voltage secondaries? Since you'd not be using the primary the pri:sec turns-ratio isn't of concern here.
G6Tanuki is offline
Old 3rd Oct 2020, 4:34 pm   #3
At what voltage? And why isolated?
Old 3rd Oct 2020, 5:13 pm   #4
broadgage
Agree, you need a transformer with two independent 6.3 volt windings.
Use one as the input from the existing heater circuit, and the other as the input to the extra circuitry. This arrangement tends to produce a little less than 6.3 volts, but should be acceptable.
Ignore the mains voltage winding.
Make certain that the existing heater supply can handle the extra load.
Alternatively, it might be simpler to fit an additional mains transformer with a standard mains voltage input and a 6.3 volt output.
broadgage is online now
Old 3rd Oct 2020, 5:46 pm   #5
Petedox
Petedox's Avatar
Thanks G6Tanuki, I've just found an old PCB mounting transformer with 6-0-6 secondaries, (both rated at 300mA), and it works fine.
Broadgage, as you say, there is a slight loss (to 5.9v) but that's no problem at all.
It was a relatively simple solution that hadn't occurred to me - thanks for your help!
Pete
BVWS Member
Petedox is offline
Old 3rd Oct 2020, 5:55 pm   #6
Orakle42
I would agree with broadgage, assuming the decoder is a semiconductor device,
a small 1.5VA mains transformer would be a simple solution if an isolated supply is required. It also removes the possibility of overloading the existing heater supply.
Orakle42
Orakle42 is offline
Old 4th Oct 2020, 10:37 pm   #7
bikerhifinut
seconded, why make a simple job complicated. if you're going to use a transformer anyway, cut out the middle man and get one of he many sub min jobs out there
bikerhifinut is offline
