2nd Oct 2020, 12:30 pm | #1 |
Odds and Ends amplifier
I wanted to build a small amplifier to attach to my laptop for watching films etc. I had the transformers already, though I suspect the alleged output transformer was intended as a heater transformer as the secondary is centre tapped!
The only new parts were a piece of Tufnol and some turrets to make the main component board. Otherwise everything was from stock, some used and some unused. I used Pen4A output valves as the power transformer has a centre tapped 4 volt winding. The rectifier is an American type 80 and the other valves EF37A and 6SN7. It's a bit of a conglomeration, but it works well! The additional knob is for a feedback control - it gives the options of feedback from the O/P transformer as shown in the circuit, no feedback or a capacitor bypassing the EF37A cathode resistor for maximum gain. The case was made from a sheet of MDF that I happened to have. I'd originally intended to veneer it, but since I had some sticky-back plastic in stock I used that instead. It looks quite good from a distance... |
2nd Oct 2020, 12:40 pm | #2 |
Re: Odds and Ends amplifier
Anything built from odds and ends is a good thing. Congrats.
Adrian |
2nd Oct 2020, 2:29 pm | #3 |
Made from odds and ends, sticky black plastic..... All it needs is a Blue Peter badge
2nd Oct 2020, 4:17 pm | #4 |
Tone controls as well! Very good.
Cheers Aub
2nd Oct 2020, 4:25 pm | #5 |
Nice work and an interesting circuit. Two things, that's an interesting tone control circuit, did you design it yourself? Not being 100% up this subject why the different value caps? The typical circuits I've seen have equal value filter caps. How many dB loss? Looks lossy hence high gain IP stage and 100k anode resistors on the PS, it's usual to use 47k.
Second the PS is interesting too, it's not a classic LTP, no big tail - 1k and why VR4? AC balance? But note no AC decoupling on the PS 6SN7 second triode grid. Andy.
2nd Oct 2020, 4:58 pm | #6 |
It's not an LTP phase splitter at all Andy. The common cathode resistor is AC bypassed, so there's negligible AC there. Instead the second triode's grid is fed from the output of the first triode, via the VR4 attenuator, which does indeed give you the option of AC balancing the push-pull.
Cheers, GJ
http://www.ampregen.com |
2nd Oct 2020, 5:37 pm | #7 |
Very fine! I've always admired tag board layouts. Is there some knack or formula for laying them out? I want to do it for my preamplifier rebuild but haven't dared drill the holes yet for fear of not having the layout right.
2nd Oct 2020, 5:42 pm | #8 |
problem with the feedback vol and tone controls shown inside the feedback loop!
Never right the feedback will be acting against the controls Other than that cracking amp Trev |
2nd Oct 2020, 6:38 pm | #9 |
Ab Fab project. Love it.
Failing to prepare is preparing to fail ... |
2nd Oct 2020, 9:58 pm | #10 | |
2nd Oct 2020, 10:01 pm | #11 | |
No, sorry, the tone control design was not my own, I lifted it from a Mullard design. For my next amp I have some ideas... |
2nd Oct 2020, 10:21 pm | #12 | |
I sometimes think it should be possible to knock up a box containing a decent 1kHz oscillator and a 2kHz bandpass filter with a detector on the end of it for doing this job on amps with a drive balance adjuster. Cheers, GJ
3rd Oct 2020, 10:17 pm | #13 |
Can't get my head round the EF37A anode volts. Its cathode current looks like about 1.6mA- even if 1.5mA of this is anode current, the anode should be at about 284-16(R5 drop)-150(R2 drop) or about 120V.
5th Oct 2020, 7:23 pm | #14 |
Hi.
I like the phase splitter in the circuit. Well done on the project. Regards. Trevor |
