13th Oct 2020, 2:50 pm | #41 |
Re: PYE R33 Over Voltage.
It sounds similar to a floating grid fault.
Lawrence. |
13th Oct 2020, 5:00 pm | #42 |
Umm, tried looking for floating grid but it was a load of ballcocks!
I'll sleep on it for now but tomorrow it may be sleeping with the fishes.
Regards, Ken. BVWS member |
13th Oct 2020, 5:07 pm | #43 |
I tried.
Lawrence. |
13th Oct 2020, 5:25 pm | #44 |
I'm sorry Lawrence, that wasn't a joke at your expense! I googled floating grid and got lots of advertising for grids that float on water. My sincere apologies.
Wikipedia had some articles on triodes and tetrodes but I struggled with them, the frustration is starting to get to me. What started out eight years ago as an exciting new hobby has turned into something I'm finding hard to enjoy, hence the six month gap. Fresh eyes tomorrow and another readup on floating grid's...
13th Oct 2020, 5:34 pm | #45 |
By floating grid I was meaning no DC path from the control grid to the cathode.
Lawrence. |
13th Oct 2020, 5:41 pm | #46 |
Thank you, I'll do some research.
13th Oct 2020, 7:21 pm | #47 | |
I feel for you and your frustration. Just one Q, why did you replace C7 in the first place? I may have missed something here but these low values are beyond suspicion.
Al |
13th Oct 2020, 8:13 pm | #48 |
Ken, there was a recent thread where someone had a fault in a valve and purchased an eBay replacement which was also faulty.
As long as you're happy with the voltage at the valve pins (and current draw if this can be calculated), I would return the valve you've bought as it's probably faulty too, and get another one. The photosensitivity is probably a red herring; as one of the moderators has mentioned it's a known phenomenon and from my very basic physics knowledge it's not hard to imagine that photons of light energy may excite electrons in the valve in some way or another Is your heater voltage ok? Last edited by Gabe001; 13th Oct 2020 at 8:21 pm. |
13th Oct 2020, 9:17 pm | #49 |
You say an LED torch shone on the valve causes the fault to clear. Have you tried a standard incandescent bulb torch? I'm thinking the LED drive circuitry within the torch may be affecting the circuit. You might find that if the valve IS sensitive to outside electrical interference that a metal screen might help.
14th Oct 2020, 6:15 pm | #50 |
Yes I was going to add that we could see this whole interaction between Ken and the valve as a quantum experiment ...
Al |
14th Oct 2020, 8:55 pm | #51 |
Hi
I'm doubting photo sensitivity. It's more like hand capacitance that's the issue, pointing to instability. Make sure the decouplers in the frequency changer and IF stages have been replaced with the correct values and they are placed exactly the same way as the manufacturer did, leads need to be short. Low value PF wax caps are actually very reliable and never do a blanket swap out of them, it can cause all sorts of troubles.
15th Oct 2020, 7:44 am | #52 |
Ahah, Trevor may have the answer! I'll remove C7, test and replace it without the long leads.
I'll reply to you all after breakfast.
15th Oct 2020, 8:41 am | #53 |
Hi.
I'd not say the leads are too long. Have you replaced any decoupling capacitors in the frequency changer and IF?
15th Oct 2020, 10:12 am | #54 |
Hi Ken , as I also said in post #47 — but why did you replace it in the first place? That might give us a insight into your thinking. And you have a silver mica or similar type, or the original? I’m not sure what type you have there but it isn’t silver mica.
Also I can see you replaced a resistor - what was the wrong there?
Al |
15th Oct 2020, 10:37 am | #55 |
I think you need to replace the silver mica with a silver mica Ken, as the others have said.
15th Oct 2020, 11:38 am | #56 |
Nobody seems to have mentioned that these sets use a PCB. PCB based valve radios of this era often develop 'interesting' faults as the material degrades and becomes conductive. It can be difficult or even impossible to fix them.
15th Oct 2020, 11:49 am | #57 |
Very good Point Paul.
These PCBs are badly effected by damp conditions and can become conductive leading to all sorts of issues. I do believe thinking about it that it could well be the issue.
15th Oct 2020, 1:28 pm | #58 |
Okay, minor improvements.
I replaced C7 flat on the PCB and put a NOS UCH81 in. Started out working but after10 minutes the audio began to have a slight warble as if the old fault is making its way back. C7 was replaced due to an error on my part, using a DMM instead of an analogue meter. I wonder if I've cooked C30 when I was removing C7? The DC path from control grid to cathode - is that via C7, C11 and L3? Cricklewood Electronics don't do mica caps and it looks like I'd have to realign the set, which I have no confidence in, so I might put this to one side for now. Thanks to everyone for the support...
15th Oct 2020, 1:41 pm | #59 | |
V1 oscillator gird is grounded via R3. V1 mixer grid is grounded via R1, R5 and R4. Check the resistors. Check that the valve pins are clean and making good electrical contact with the valveholder sockets.
15th Oct 2020, 2:11 pm | #60 |
Of course! That's an indication of how confused l am.
