3rd Feb 2004, 6:17 pm | #1 |
Balance to Imbalance Transformer
I have a couple of 1940's Philips TV sets, both of which were designed to run from a balanced aerial. On the service data it states that, if a coax feeder is already installed then a " Balance to Imbalance Transformer " should be used. What exactly were these transformers and is anything still available that does the same job.
These sets seem prone to hum when in use and I wonder if it is because one of these tyransformers is needed when using them? |
3rd Feb 2004, 6:34 pm | #2 |
Re: Balance to Imbalance Transformer
If you have a good strong signal then the mismatch caused by not using a transformer does not matter. Since you are likely to have a good signal from a modulator then just put low value caps (1000p, not critical) in series with inner and screen to break the earth loop that may be causing the hum.
A balun, as a balanced to unbalanced transformer is often called, may be available or could be made. THey're not anything special at these frequencies. But it does not really seem necessary. |
19th Apr 2004, 3:13 pm | #3 |
19th Apr 2004, 3:32 pm | #4 |
Hi all
They are available from Maplin Electronics, see link here.. http://www.maplin.co.uk/products/mod...145&Products=1 That and an inline coupler is all you need. Malcolm |
22nd Apr 2004, 8:37 am | #5 |
The correct modern wire would be that horrible 300 ohm ribbon. Often supplied as an aerial for VHF receivers. For the few inches you will be using it does not matter at all. Bell wire will be fine.
I am guessing that the original 300 ohm feeder was much like modern plastic ribbon stuff but with rubber insulation. The geometry must have been the same, with the conductors about 1cm apart, to give the correct impedance. |
5th Nov 2004, 12:01 pm | #6 | |
Re: Philips TV and balanced aerial feed
300 ohm balanced feeders are still the norm in the US, and possibly in other parts of the world to. In Britain it's actually quite difficult to buy 300 ohm feeder cable. Best regards, Paul Last edited by Paul Stenning; 29th Dec 2004 at 1:34 pm. |
5th Nov 2004, 1:19 pm | #7 |
Hi Guys, a late 50's Radio Rentals (Baird) console set we had was fitted with balanced feeder, the had to be unscrewed from a pax panel to move the set. When it was later convered to ITV it then used a coax type.
Ed |
5th Nov 2004, 5:20 pm | #8 |
Administrator
I have a Philips radio (Reverbeo) with a 300R balancd aerial input for FM. I have just connected the centre core of a standard 75R aerial feed to one side of the 300R input and the braid to the AM earth socket. It works fine. In fact I need a 6dB attenuator because the output from my FM booster amp is too much for it, so the 3dB mis-match loss is irrelevat.
I think Maplin still sell baluns if you want to do it properly. |
5th Nov 2004, 5:22 pm | #9 |
Paul's method is the standard trick for connecting co-ax to 300 ohm balanced inputs. It makes the assumption that the balanced input isn't floating. Though if you have plenty of signal then almost anything will work.
10th Nov 2004, 10:47 am | #10 |
I have a number of such sets (including the Philips 385U) and I used to get a lot of hum when is use. After advice from the chaps here I bought some baluns from Maplins and also some 300 ohm balanced feeder cable and the sets performed so much better. I've actually found that Philips, Pye and Ekco used this type of aerial in the late 40's era and using the proper balun and cable makes a much greater improvement than you would imagine. The baluns and cable and very cheap from Maplins.
22nd Feb 2005, 7:47 pm | #11 |
We had a Philips 385U and from what I can remember (I was only 3 at the time) it wasn't an unscreened feeder, the co-ax had two cores red and green
this was taken to a large "H" aerial there was also a single core cable that came down from the aerial and went to earth, I assume this was connected to the screen at the aerial end, inside the house the aerial was terminated using 2amp 3pin plugs and sockets, we could then move the set into another room. |
2nd Mar 2005, 10:42 pm | #12 |
I've found a good pic of this set, I don't know if anyone else has seen it
I think the speaker fret may have been changed, has I remember it was light brown with a large diamond pattened gold inlay? http://members.lycos.nl/patstvmuseum/english385.htm |
