16th Aug 2008, 10:47 am | #41 | |
Re: Advantages of 405 lines?
By the 70's they also switched on a coupleof high powered UHF transmitters, but even today, two system I (wider than continental systems) 625 line services exist predominantly on band III (band 1 is no longer used). So with careful planning, I expect they could have had BBc and ITV on 625 lines, it may have stretched the TV tuner technology in 1955, but by 1960 I'd say it could have been done. |
18th Aug 2008, 2:25 pm | #42 |
Hi.
On the aspect of recording onto video using 405 the overall results are much superior with the VCR not requiring the chroma circuitary required for 625 PAL. The two photos were recordede today using a sony C7 beta machine and you can see the ghost effect caused by the Drop out compensator and also the excellent definition, on test card F there is noticeable Chroma Crawl from my NTSC 405 line source, I would think owing to the good bandwidth from a VCR on 405 that no chroma processing would be required hence machines would have been simpler and cheaper. I will check though to see if it does work on the Decca 405 colour project set the next time I dig it out of the loft (Phew) . Regards. Trevor
