3rd Jul 2021, 7:12 pm | #21 | |
Re: Recap Strategies
I would also second this. With modern capacitors getting smaller, the leads unfortunately don’t always reach. This ends up being a nightmare as you have to extend them or solder onto the old component leads. This can look un-neat. I think it’s important to mention that some early circuit boards also have a lot of oxidisation on them which makes it very hard to solder to. With the amount of heat and flux needed to make a good joint, you could potentially damage the track or the board.
With regards, Ed |
3rd Jul 2021, 7:55 pm | #22 |
Many thanks everyone for the detailed advice. A lot depends on what I find when I start restoring the innards of this (externally pristine) set. It is clear from peering into the chassis that it is quite gunky in there, and because -- for space reasons -- this is likely to be my only vintage set for quite a while, I need to proceed carefully.
I don't know when I will get going but will be sure to start a thread when that happens!
Martin |
4th Jul 2021, 9:23 am | #23 |
Versions were manufactured with twin speakers.
The general chassis goo is mostly wax capacitors that have softened in a warm atmosphere. Quite normal but as you say, messy! Don't attempt any over cleaning until you have it basically working. J. |
4th Jul 2021, 6:57 pm | #24 |
Thank you for that advice, which was needed. I have a distinct tendency to clean stuff first, then restore the electronics, but I can see how that could be counterproductive if the set has not been brought to working order first.
Martin |
4th Jul 2021, 8:17 pm | #25 |
Picture of the timebase printed circuit panel in the Pye CW17 I have upstairs above the shop. A few components were replaced in order to get the set working, it wasn't a full restoration. Note C88, one of the leads of the old part was cut in the manner recommended by the Pye service department.
DFWB. |
5th Jul 2021, 8:40 am | #26 |
I reckon your example David was used from test card to Queen! It really is a well worn chassis. J.
5th Jul 2021, 2:01 pm | #27 |
Odd to think of all the nice clean sets we dumped back in the day, and some of the ones we're restoring now look like theyve spent their lives down a coal mine!
