7th May 2021, 1:36 pm | #1 |
RCA TR-600 Quadruplex Video Recorder. (Actually a 600A)
Hi There, I'm pretty new to this forum. I am currently restoring a RCA TR-600 Quadruplex 2 inch video recorder built in 1973. It's been a mission, I managed to obtain some service information but by no means is it complete and I was also lucky enough to find a load of new old stock parts from a company in Germany.
What I am looking for is more service information, I have the manuals marked Volume 1 and Volume 2 but I am desperately seeking Volume 3 or any other service info, it was usually in red binders, also looking for 2" quad tapes with something recorded on them. If anyone here is in to restoring old broadcast video recorders from the likes of Ampex or Sony I have done a ton of it and can always offer advice to anyone that needs it. Thank You Andy |
7th May 2021, 5:28 pm | #2 |
Re: RCA TR-600 Quadruplex Video Recorder
Are you sure you have a 600 and not the 600A? The plain vanilla 600 was not anywhere near as popular as the A version. I worked on these machines for many years, may I ask where you obtained your machine from as there were not so many in the UK. I can’t help with your missing manual I’m afraid although once I was very familiar with them.
11th May 2021, 9:20 am | #3 |
Hi There,
Yes it is a TR-600A. I bought it from a company that once had a post house in Soho, it had been wrapped up and put in to storage for the last 3 decades and is in really excellent condition. The hours meter shows 1760. I was lucky to find it, I went to purchase four Ampex machines, two VPR3's and two VPR6's and the RCA was there in the same storage container, we did a deal and I ended up leaving with that as well. It came with three heads which all look good and 3 service extender cards. I was lucky that I found an advert from a company in Germany for some service manuals and a box of new old stock spare parts for the machine which I bought, and then another bit of luck was finding a company in America called ZIN Vtr who had just refurbished a TR-70 for the Washington Library Of Congress and in that process had a number of pinch rollers manufactured for it. The 70 and 600 have the same pinch roller so I bought one of those from them to replace the only mechanical component that seemed to have aged. The air system needed overhauling, all the air fittings in the machine needed replacing, they used plastic fittings with brass inserts, almost all the plastic fittings had cracked, all easily obtainable and replaceable. The spool brakes needed re-lining as they had glued themselves to the hubs. Apart from that its been a pretty normal restore of old electronics, capacitors, quite a lot of semiconductors (RCA made their own and apparently at that time weren't the best at it, their chips now suffering from ionic migration) and most difficult was optical sensors on the deck but what I lack now is information on setup and alignment. I have all the schematics and board layouts etc. Its been an interesting, if expensive project so far. Hopefully I can find that elusive volume III of the manual set. Cheers Andy |
11th May 2021, 12:43 pm | #4 |
Re: RCA TR-600 Quadruplex Video Recorder. (Actually a 600A)
Hi to all,
hi AndyPilgrim, Worth a try : Company Vectracom in Paris, France has been operating since 2001 to transfer archives on vintage VTR/VCR formats to newer media. A lot of the work involved 2" Quadruplex tape. The company was founded by 3 ex-SFP engineers, the SFP was the production branch of the three state-owned French television channels (ORTF era). The SFP was a RCA VTR stronghold going back to the TR-22 and TR-70 during the 1960s. They also had some TR-600s. When Vectracom was set up, the 3 founders recuperated the Quad machines from the SFP. On the slideshow of the web site's home page you can see an Ampex AVR-2. Try sending a message through the Contact page asking if they still have documentation on the TR-600, especially the volume you're missing. You never know, they aren't the sort of people who throw things out. http://www.vectracom.fr/en/ in this article about Vectracom, seems they have the machine you're looking for, see photo : https://mediakwest.com/mk35_vectraco...du-patrimoine/ Good Luck & Best Regards jhalphen/Ex-Ampex Last edited by jhalphen; 11th May 2021 at 12:53 pm. |
12th May 2021, 1:24 pm | #5 | |
I will ask around about manuals, but I don’t hold out much hope after all these years. |
12th May 2021, 2:41 pm | #6 |
I wonder if it might be worth asking about this on the Early TV Museum conference call next month? Perhaps one of the US collectors or broadcasting museums might have the documentation you're after.
12th May 2021, 2:55 pm | #7 |
Hi There,
I don't know what the facilities house was called, but the couple that had the machines I guess were retired and had containers full of equipment, I didn't ask too much but they did say they owned and ran a independent post operation in Soho, they certainly had a lot of equipment in storage and were extremely knowledgeable about it all and its history. The brakes on this are released by air pressure and spring return to apply, so when the air / power is removed the brakes are locked on. You are correct that the tension arms drop away without power or air. I think this has the standard servo's, there is an entry guide, about an inch in diameter with no sensing on it and an exit guide that runs the tape timer with optical sensors on it. It does have the little bit of bent metal as you say to make tape loading easier, but it doesn't have the sound deadening thankfully, it would have disintegrated everywhere by now if it had it, both my VPR3's have that on their head covers, it had turned to sticky gunge !! I have some new old stock blank tapes which I have been able to run through the machine during the process of getting it basically up and running, the tapes were still factory sealed and are in A1 condition, I have got someone kindly recording me some tape on a VR2000 which whilst not exactly reference will get me much further down the road. I also bought a recorded tape from the US, which of course is NTSC but it at least enabled me to verify the audio playback and the control pulses. This machine is not fitted with the AE600 although annoyingly I have the manual for that !! Thank you JHalphen for the suggestion of Vectracom in France, I have sent them an email so hopefully they will come back to me. I've attached a few pics of the machine. The close up of the tape path has some bits missing, I was replacing the tape timer optical sensors, every optical sensor in the machine had failed, I managed to buy something workable to replace them from RS components after a bit of experimenting !! Cheers Andy |
12th May 2021, 3:23 pm | #8 |
Hi There,
That is a god idea, though I don't know anything about that, how would I go about getting involved ? Cheers Andy |
13th May 2021, 11:46 am | #9 |
Thanks for those pictures, it really takes me back to happy memories.
Definitely non-Recortec reel servos. A typical headwheel panel would be good for around 800-900 hours before being returned to RCA in the Channel Islands for refurbishment. If you had managed to get 1000 hours out of a panel RCA sent you a certificate as it was quite unusual! We had a few that got past 900+ but never actually got to that limit. Certainly a nice clean example you have there. I have a series of pictures of our last machine being de-commissioned, it was being used for the last knockings of archiving before being trundled out of the building at LWT. I believe the machine was donated to the BFI archiving facility. It’s possible a set of manuals went with it so it might be worth you contacting their facility for a chat - not too far from you, Berkamstead I think? Do, please, keep the thread updated as you progress. |
14th May 2021, 2:59 pm | #10 |
Hi There,
It is a nice clean machine and fortunately I now have 4 head panels for it, hopefully one or more are useable. There is a company in America that refurbish these still so it may be worth having one done when it is finally completed. The whole project has cost big (ish) bucks so far so a bit more may be warranted. I did contact the BFI but they told me they don't have any RCA manuals, only Ampex. They may well not be interested in sharing that kind of material, which I can fully understand. I have a recorded tape coming shortly so the next stage of the restoration will begin. I will keep this updated. When I get the recorded tape I will make a short youtube video of the first run with it and share the link Cheers Andy |
14th May 2021, 5:42 pm | #11 |
Hello Andy,
Don't think we have any TR-600A manuals here, but I'll have a look. We're into working TR70B and also have a lot of Ampex machines waiting their turn! There's a lot of brand new TR70B spares to hand too. It does indeed look like a very clean machine - so much ex-broadcast kit is so filthy! I'll have a look through the RCA documentation. Best regards, Paul Marshall Chairman Broadcast Engineering Conservation Group www.becg.tv |
14th May 2021, 5:51 pm | #12 |
Hi Andy, I've been following this thread this week as I knew I had put away a large red RCA 600 service manual a few years ago and couldn't remember which volume it was and it was only today that I could get to it. I'm sorry to say that it is volume 2 which you already have. I just thought I'd let you know anyway just for the record.
14th May 2021, 7:57 pm | #13 |
I have sent you a PM.
23rd Jun 2021, 8:35 pm | #14 |
Just a little update for anyone following this thread, the project is moving on massively. I'm now at the point where I get a semblance of unlocked picture in playback, to do this I have to force the guide air solenoid on and put the guide to manual at which point I can adjust the guide to get some reasonable RF, I say reasonable as the head wheel has neither velocity or phase lock, hence the guide solenoid not being triggered as theres no velocity lock. Getting deep in to the head wheel servo now, which is scary as I have already discovered it is very easy to blow the head wheel power amplifier boards up delving in to the servo. Fortunately after the last catastrophic failure I bought a large quantity of the various semiconductors involved !!
As get a bit closer I will put a video up of the machine running |
26th Jun 2021, 1:10 pm | #15 | |
Second point. All quad vt machines require head 1 to playback the vertical interval. You can see this by observing the demod pictures on a monitor which is locked to a source of external syncs - put the monitor into delayed “vertical” lock so that you can observe the demod pictures together with the overlaid ‘stability’ dots ( usually shortened to simply ‘stab’ dots). The stab dots tell you where head 1 is - it must be replaying the vertical interval. If it isn’t use the capstan phase control to make it so. If head 1 is not replaying the vertical interval you will get demod pictures, and I suspect you will get pictures out of the TBC, but you definitely will not get pictures post proc amp on the output of the machine because the off tape pictures will be horrendously mis-timed in respect to the external syncs you are feeding to the machine. Hope this helps in some small way. Last edited by red16v; 26th Jun 2021 at 1:15 pm. |
1st Jul 2021, 9:26 pm | #16 |
Hi there, thank you for that info, no my headwheel will not lock up in tonewheel mode. The air guide doesn’t come in either as the head doesn’t achieve velocity lock. I can sort of trick it by reducing the frequency of the pll on the servo reference board, it unlocks the pll and makes it unstable but the slowing of the headwheel sort of makes the velocity lock detector trip and the guide comes in. At that point I’ve got a wobbly sort of picture (you can hear that the headwheel isn’t steady) and on the waveform monitor I’ve got something resembling a video waveform. I’ve removed the link to stop the video being muted when the servo is unlocked. The problem is around the op amp in the tonewheel servo is think, it’s output is stuck low, whatever happens to the inputs and I think this is the cause of this problem. Doubtless there will be others.
This week I have had a bit of luck and I now have a complete set of manuals for the machine including the training manuals. This is a night and day difference. I have to thank Ted and Ken at ZIN VTR works in America for that, they found me a set for PAL and of the correct age for my machine as there were variants. I’m going to move on with it some and then put up a collection of photos and a video of progress. Cheers Andy |
2nd Jul 2021, 10:12 am | #17 | |
You have found some great contacts in the US, I'm sure you'll get it going, 1973 was indeed an earlyish version, the later models were more complicated with the various options fitted - Recortec reel servos, the AE600 and automatic head wheel phasing for editing purposes. PS.Don't forget the point I made about head 1 replaying the vertical interval - if you can see them on the monitor, do check the position of the stab dots. Last edited by red16v; 2nd Jul 2021 at 10:20 am. |
2nd Jul 2021, 11:52 am | #18 |
Hi There,
Thank you, yes I will check that head 1 reads the vertical interval. At the moment the tone wheel dots are all over the place as the servo isn't even velocity locked. It has been an interesting journey so far and I am grateful to have found this forum as there has been really good input from people. I will keep updating here as I go along Cheers Andy |
6th Apr 2023, 4:55 pm | #19 |
Rca tr-600a
Afternoon everyone. A lot of time has gone by and I’ve intermittently worked in the machine with some big gaps while I sourced parts but it’s moved along quite a bit and having sorted some headaches with the headwheel servo, a massive issue with the tachometer disc on one of the spool motors I’m now getting close to a working machine.
I’ve acquired quite a few tapes and some more video heads and I’m facing a push to get it finished now, but I thought I’d post an update here as last time I had a lot of friendly and helpful advice from people. I don’t seem to be able to upload a video here but it in on YouTube at the following link https://youtube.com/shorts/a_m1Iqs3W3s?feature=share There’s still work to do but now I am getting to where most of its issues are down to alignment and I need to sit down and go through it end to end. Last edited by Station X; 16th Apr 2023 at 7:57 pm. Reason: Threads merged. |
7th Apr 2023, 10:18 am | #20 |
Re: Rca tr-600a
Well done for getting this far. It was a long time ago, but to my ears the 'whine' from the headwheel panel is not quite pitched 'high' enough - but you have pictures! It would be interesting to eventually see some pictures of the on-board waveform monitor showing the off-tape FM signal and equaliser outputs (CAC and CAE from memory?) and the output of the TBCs.
Hopefully I've attached a picture of our last machine a few minutes before it was literally pushed out the building to go, I think, to the BFI. The machine was the last version produced by RCA and has a few additions to your machine - Time code editing, automatic head wheel phasing for editing purposes, and Recortec reel servos. Last edited by red16v; 7th Apr 2023 at 10:23 am. |
