17th May 2019, 8:44 pm | #1 |
Teleton vx1110 colour problem
Good evening to you all it has been a long time since i last logged in or posted anything due to serious terminal ill health but i won't go into that now.
however i have just got hold of a Teleton vx1110 cw original handbook. the tv is in great condition,I remember them and the tvc14 and 20 from many moons ago with the strange Toshiba USA type valves. the set powered up great a little tweak of the height control and the grey scale adjusted and gave a very good picture crt is very good. The problems i have noticed is poor convergence which i will get round to at some point but the problem which i did come across,was that after a length of time the set started to lose its colour it would be very low and on a bright scene would be virtually monochrome!as the set stayed on longer the colour has now gone completely, needless to say i would bet if i powered it up now after not being used for over 24 hours the colour will be back. has anyone any experience with the simple pal decoder used in these sets. as i said i only ever saw a couple back in the early eighties but they worked ok. And this set with convergence set up and colour back produces a nice picture even if only using a simple pal setup any advice kindly welcomed thanks in advance Simon
Keep the soldering iron warm and never give up or you will kick yourself. BVWS MEMBER |
18th May 2019, 9:14 am | #2 |
Re: Teleton vx1110 colour problem
Does the colour stay in lock while reducing in amplitude?
If so I would check the colour killer circuit around TR12 and the 2nd colour band pass amp circuit around TR11. I have no experience with these sets, I am just reading the circuit.
Frank |
18th May 2019, 8:35 pm | #3 |
yes it stays locked but loses amplitude until it goes all together.
