15th Mar 2019, 11:56 am | #41 |
Re: GEC Junior Fineline project.
Nothing on the spikes as far as I can see.
15th Mar 2019, 12:09 pm | #42 |
There's a photo in this link showing correction magnets fitted:
https://en.wikipedia.org/wiki/Deflection_yoke Lawrence. |
15th Mar 2019, 6:08 pm | #43 |
Hi GM,
That really looks pretty good in the picture. The picture is very well centred, the only real errors I can see are a slight narrowing of the picture at the top and a slightly wiggly horizontal line at the bottom. You won't correct these errors with the ring magnets. Most manufacturers would not have been concerned with that minor amount of distortion and most viewers would never have noticed. These are not broadcast standard monitors and domestic TV's had many shortcomings. You can download a DVD of proper testcards from this link: https://www.vintage-radio.net/forum/...ad.php?t=71637 Read through the whole thread as the latest files to download are nearer the end. Of course, you need DVD writing capabilities. At least then you could see the set with a correct aspect ratio testcard. Hope that helps Cheers Nick |
15th Mar 2019, 6:24 pm | #44 |
Thanks for the link, i will have a look at that.
I think what bothered me the most about the picture was the fact it was taller on the left than on the right. I watch a lot of subtitles programs and slanty subtitles would have drove me round the bend. Anyhow, I made some very weak magnets today and did a little experimentation. The addition of a single magnet has improved things a lot. I have a test card I am happy with now. Still not perfect but it’s to a point where the imperfections will not be noticeable for tv viewing. SWMBO says there was nothing wrong wit it before and that I am just being fussy. But I think she just wants it off the kitchen table. |
15th Mar 2019, 6:32 pm | #45 |
Very slight rotation of the scan coils would even out those slight discrepancies. TV adjustment is all about minimising the deficiencies in the picture!
Anyway, you will find the wandering black level (when watching a moving picture) far more annoying than slight geometric errors!! Cheers Nick |
15th Mar 2019, 6:45 pm | #46 |
I should have said, I did rotate the coils a tiny bit after taking the photograph.
One step ahead of you on the black level, I have added a diode clamp circuit in the video buffer stage. This may not be an official or approved mod, but it’s my set and I intend to use it so I wanted the picture as good as I could get it. It’s actually a very watchable set now. |
15th Mar 2019, 6:56 pm | #47 | |
Cheers Nick |
15th Mar 2019, 7:49 pm | #48 |
I see no reason why not to add a simple clamp circuit, component cost is next to nothing and it’s such an easy thing to make.
But, I don’t know if you have read my previous posts, the ultimate aim of this project is to have a single box solution to tv viewing. Now I have a fully functional set with a good picture, I plan to add a freeview receiver PCB. The diode clamp on the video buffer is required for this as the signal out of the freeview card is not even close the the signal the set produces at this stage. Now I understand this may be a mod too far for many in the vintage TV world. But this is my plan. This evening I will be building a 2 transistor video amplifier to produce the 3V pk-pk Video signal needed. This will also produce the required offset. Replicating the sets own video signal is I think the best way to ensure that all of the pulses and blanking levels are correct. The audio levels from the freeview card are spot on as they are, which is handy. There will be a small switch somewhere to switch from analogue to digital as I also intend to use this set for watching my old VHS tapes, so the set will still have to function as the factory intended. I have really enjoyed this project so far and there is a distinct danger that I will be on the hunt for another old TV when this one is finished. The help both from members of this forum and VRat have made the whole thing achievable. So my thanks to everybody who has contributed this far. |
16th Mar 2019, 5:04 pm | #49 |
I don't see any problem with your plan - after all this TV will now be used and will be providing a picture better than it was when new! If it were a particularly rare set then the modifications could be made reversible, but that's not really the case here.
I think that if the geometry was way out small magnets of around 1cm square could be put on one or two of the spikes, then rotated to improve matters. However your set would have passed with no correction deemed necessary, I suspect. |
18th Mar 2019, 2:30 pm | #50 |
Project complete.
I now have a nice little freeview enabled Junior Fineline. Some may say this is sacrilege, but I like it. Thanks again for all of the help along the way. Its been an enjoyable little project. Next project I guess is to repair my scope which died half way through. |
18th Mar 2019, 6:54 pm | #51 |
Looks great! Oddly enough I just picked up an old copy of Television magazine from 1976 ans there was a servicing article on the Fineline in it.
Now fixing your 'scope - that's a challenge! |
9th May 2019, 8:25 pm | #52 |
It would seem I am not quite done with this project yet, as it has developed a quirk that needs investigation.
After a few weeks of trouble free operation the picture has started to slowly move to the right as the set is on. It can easily be bought back into centre with the horizontal hold control, but when the set is cold it’s back to the start. It takes about half an hour for a half inch black strip to appear on the left of the screen as the picture moves, if left for long enough it will eventually loose the horizontal lock, but normal service can easily be restored by adjusting the control. Seems like something just does not like the heat (or cold). |
