6th Nov 2016, 5:37 pm | #1 |
Panasonic NV-L25 vs NV-J35
Hey,
Got hold of a J35 to go with my L25 since they are both similar in design. After getting it and using it it's pretty clear it's just the L25 with a facelift. All the functions are the same the display layout is identical and the mechanicals all sound the same. Haven't had the covers off both side by side to compare yet, but do I really have to? The picture quality on the J35 has to be one of the best in my collection for playing back recorded tapes. The colour depth is a bit lacking compared to some of the other machines but it's made up by the clarity on both sp and lp recordings. Shame about the mono sound and like the L25 has a bit of background noise even with the filter on. The only thing that the J35 has that the L25 doesn't is a scary socket and the ability to play my ntsc tapes. Anyone able to clarify if I'm on the right tracks with my presumption? Cheers Steve |
6th Nov 2016, 7:05 pm | #2 |
Re: Panasonic NV-L25 vs NV-J35
A lab I used to work in had an NV-J35 especially for its ability to play back NTSC tapes by creating a sort of 60Hz PAL which most TV sets would display. I would expect there to be significant differences in the servos to allow for the 60Hz field rate and thus different tape speed of NTSC tapes, as well as the extra colour-manipulating gubbins. The circuit boards will probably look noticeably different, I expect.
Chris
6th Nov 2016, 7:10 pm | #3 |
I can get the L25 to play ntsc tapes at the correct speed but they are in black and white.
May be a fault causing that as I can't see the machine playing at the right speed if it wasn't ntsc enabled. I will whip the covers off later and have a look. Just checked the user manual and it claims the L25 can playback ntsc tapes. Looks like I will have to look into the black and white picture... Here's what's happening with the L25, the J35 plays the ntsc tapes perfectly. Heads have been cleaned. https://youtu.be/3xJmRw4hcsA Cheers |
6th Nov 2016, 8:14 pm | #4 |
Spot the difference
6th Nov 2016, 10:57 pm | #5 |
6th Nov 2016, 11:13 pm | #6 |
Unless stated otherwise, machines like this will usually output 'modified' NTSC (NTSC 4.43MHz) when playing back NTSC tapes. I would think a modern LCD would be able to handle it, unless there's something up with the VCR. Maybe try another TV.
Regards, John |
6th Nov 2016, 11:20 pm | #7 |
I have 5 other machines that playback ntsc, they all work fine on this Samsung tv. Altho the L25 is the only machine that is using phono connections as it has no scart.
I've tried using a scart adaptor socket and connecting into the phono inputs of the tv, results are the same. Pre recorded and recorded tapes in pal work perfectly on the L25. |
10th Nov 2016, 2:08 pm | #8 |
The absence of a SCARY-plug is determined by the suffix letter behind the model number. The L25 and J35 were probably only 1 model year apart, and some other L-models indeed have different power supplies and main boards as far as I can remember.
You could have a look at the year and month of manufacture; they are encoded in the first part of the serial number. Last edited by Maarten; 10th Nov 2016 at 2:15 pm. |
10th Nov 2016, 5:09 pm | #9 |
Will have a look tomorrow when I get a chance at the serial numbers.
My phone keeps changing scart to scary lol. No joy in getting the ntsc function sorted on the L25 tho. Must be a duff ic. Not really important, and not worth my while tearing the machine apart to sort. |
