Old 4th Jan 2021, 2:56 pm   #1
em536716
em536716's Avatar
Default My newly found Marconi 707
Hey all!
After years of searching, I’ve finally found myself a pre war TV!
Introducing this years restoration project. A Marconi 707!!!
I have asked for advice and guidance on how to proceed with the restoration, but thought I’d make a separate thread for the actual set. Here it is!
It’s a little tatty, but appears to be all there!
A few months back, someone shared a video from the Land of Lost Content museum, on a Facebook group I am on, in which, was this Marconi 707 I tried my luck and contacted the owner, and after some back and fourth, here it is in my possession!
Attached are some photos, including the serial number. It’s all original apart from 2 smoothing caps which I can see soldered underneath.
The tube has a good heater, as well.
Upon a basic inspection, I have no dc resistance on the mains in side, regardless of how the wave band switch is positioned. The tuning cap doesn’t move with the control, or the dial, but string seems intact - perhaps it’s slipping, and finally, the volume control appears to be slightly bent.
In a few days I will remove the chassis for a proper clean. And inspect components. I’m putting off doing that, I don’t think my back can handle it!
Thanks all
Ed
em536716 is offline
Old 4th Jan 2021, 3:02 pm   #2
em536716
em536716's Avatar
Default Re: My newly found Marconi 707
Here are the photos. Also got the complete manual as well!
ID:	223828   Click image for larger version
ID:	223829   Click image for larger version
ID:	223830   Click image for larger version
em536716 is offline
Old 4th Jan 2021, 3:18 pm   #3
Panrock
Panrock's Avatar
So it's not a 706, it's a 707.
Steve
https://www.radiocraft.co.uk
Panrock is offline
Old 4th Jan 2021, 4:46 pm   #4
em536716
em536716's Avatar
Steve
That’s right Steve, I was unaware of the actual screen size as I hadn’t seen it in person but corrected myself on the last thread
em536716 is offline
Old 4th Jan 2021, 5:42 pm   #5
mark pirate
mark pirate's Avatar
Looks good, I take it that it came with both back & bottom panels?
Chassis looks clean & rust free, always a good sign that it has been stored well.
A couple of replacement parts is to be expected, and the cabinet looks as if it will come up a treat.
I must admit to being rather envious, I have been on the look out for a prewar set for years!
Mark
mark pirate is offline
Old 4th Jan 2021, 5:43 pm   #6
FERNSEH
FERNSEH's Avatar
This is my Marconi 707. In 1996 the CRT was rebuilt and with fitted with a new cathode. The work was carried out by Display Electronics Ltd. in Uxbridge.
Googled "Display Electronics Ltd." and it seems according to Companies House records the company was dissolved in December 2016.
DFWB.
FERNSEH is offline
Old 4th Jan 2021, 6:08 pm   #7
I like it a lot, the radio dominates (as it should!) and considering there where very few hours of telly in 1936 about right in proportion. Much like today where there are very few hours of watchable TV in a day. I do have a sneaking suspicion that SHMBO would protest if it was our main set.
Old 4th Jan 2021, 6:11 pm   #8
Panrock
Panrock's Avatar
Was it re-screened too? If so, how is the ion burn now?
Steve
Panrock is offline
Old 4th Jan 2021, 6:20 pm   #9
FERNSEH
FERNSEH's Avatar
Hi Steve,
I'm sure the tube wasn't rescreened. I do remember there was that problem of making a graded glass seal, Pyrex hard glass to soft glass.
DFWB.
FERNSEH is offline
Old 4th Jan 2021, 6:27 pm   #10
Panrock
Panrock's Avatar
Thanks David.
As shown previously, here's the same type of set in the Flanagan & Allen film "Here Comes The Sun". It looks slim may be inset into the "wall".
Steve
Panrock is offline
Old 4th Jan 2021, 6:31 pm   #11
ChristianFletcher
ChristianFletcher's Avatar
Looks really interesting great find. Good luck.
Every Silver Lining Has Its Cloud https://youtube.com/channel/UCvBpiuUUnErJlNBm6DWb3Ww
ChristianFletcher is offline
Old 4th Jan 2021, 6:46 pm   #12
Lloyd 1985
Lloyd 1985's Avatar
You lucky so and so!!! I’d love to get my mits on one of those, I’ve only ever seen one in the flesh, it was at the NVCF many years ago, but the telly had been replaced with a modern one! Best of luck with the restoration, it certainly looks like a good set to begin with.
Lloyd
Lloyd 1985 is offline
Old 4th Jan 2021, 8:22 pm   #13
em536716
em536716's Avatar
Mark
All there thankfully! And with all screws!
I’m quite nervous too... let’s hope it’s plain sailing!
I’ve been searching for the past few years. I’m so happy to have found this one
em536716 is offline
Old 4th Jan 2021, 8:23 pm   #14
em536716
em536716's Avatar
DFWB.
What a lovely example!
Hmm, I wonder if it’s possible to get the tubes rebuilt still?
em536716 is offline
Old 4th Jan 2021, 8:27 pm   #15
em536716
em536716's Avatar
Thanks all for the positive comments.
Here’s some more photos from the disassembly.
I find it quite amusing to see, the evolution of smoothing caps been added onto and then disconnected still in the chassis lol
The dial appears to be stuck. I think this is to do with dry grease.
Tomorrow eve I will do a slow power up to determine the condition of the Tube, with just EHT supply, without the HT to the rest of it to see if it’s possible for it to produce a blob on the tube face.
I’m not optimistic about plugging it in and reforming now I’ve seen the state of smoothing mess. I’ll need to have a think about my next approach.
em536716 is offline
Old 4th Jan 2021, 8:28 pm   #16
em536716
em536716's Avatar
ID:	223861   Click image for larger version
em536716 is offline
Old 4th Jan 2021, 9:05 pm   #17
FERNSEH
FERNSEH's Avatar
em536716 wrote: " Hmm, I wonder if it’s possible to get the tubes rebuilt still?"
I believe the Emiscope 3/1 and 3/2 tubes were still available from the EMI service department as late as 1960/61.
Ex Comecon countries CRT 17LK18 can be fitted in these 7" sets. It's been done.
The fact that these pre-war Emiscope tubes were made with Pyrex hard glass might scare off any potential CRT rebuilders.
DFWB.
FERNSEH is offline
Old 4th Jan 2021, 11:17 pm   #18
beery
beery's Avatar
Hi Ed,
That is a great find. You would be unlikely to find an untouched chassis in better condition than that.
Reforming pre-war electrolytics, don't bother I'm sure it won't work and it would probably cause damage anyway.
Looking at your chassis, it looks like it escaped the usual EMI post war overhaul. It still has the bolt on low voltage electrolytics, it also has the original multi capacitor box on the top of the chassis. There is a chance then that the tube may not have had much use.
No, the tubes can't be rebuilt any more as there is no one left to do it. I did indeed fit a Russian tube in my HMV905 as I obtained it with no tube at all.
You were clearly very fortunate to obtain it before today's news. I don't think that picking a vintage TV set constitutes an essential journey, though I have often tried to convince the wife that collecting TVs is an essential part of life!
I wish you will with the testing.
BTW, the tuning has a ball reduction drive, it can get clogged up with dirt.
Andy
beery is offline
Old 4th Jan 2021, 11:39 pm   #19
Graham G3ZVT
Graham G3ZVT's Avatar
Hi Ed, well done! like everyone else I am quite envious.
I found this picture of your set languishing at the Craven Arms museum suffering the indignity of being surrounded by all that TV merchandise that came decades later, some of it from [whisper]ITV[/whisper]
https://www.tripadvisor.co.uk/Attrac...7&ff=415001066
Graham.
G3ZVT
Graham G3ZVT is offline
Old 5th Jan 2021, 5:13 am   #20
em536716
em536716's Avatar
Thanks for the encouraging comments guys.
I think it’s actually quite comical to see new smoothing caps tacked onto the bottom, then one side cut out then replaced by different ones, which have been disconnected on one side and replaced by even newer ones... almost like you can physically see how long it was in service for.
Yes now I’ve calmed down a bit, reforming the old tired caps aren’t as much of a good idea as I might have guessed, although I must admit, I have had luck before after physically heating one of those Metal cylinder Metal cylinder type TCC ones with the holes on top.
I’m sure there’s enough space underneath, to mount RS ones, or better still, restuff what I can.
I took sometime to inspect the DC resistance of the focus coil and scanning coils. All appears well. I removed them and the CRT, gave it all a could clean, being cautious not to wreck the Emiscope label...
My tube appears to have odd rings around the face of the tube. Perhaps this is how they just were back then, seems a little weird to me. Also, Is it right that the face of the tube is right up against the glass? Makes me a little nervous...
Unfortunately a fellow collector friend was going to come up here to Guilford next week and collect the cabinet to restore it for me. Obviously ensuring he preserves all of the original finish as possible, but since we are in lockdown now, I can’t see this happening as it isn’t safe - I’m too nervous to attempt any cab repair on my own, souly because of its rarity.
The power switch appears to be 2 poles? Appears to be open on both sides unfortunately. I might have to bypass this for testing purposes when I run it up on the variac later this week.
Light dusting and cleaning, checking of IF coils, and TXs is a priority at the mo.
Thank you Rambo1152 for sharing this. The owner of the museum, Stella, was given the TV set by her husband Dave, for their first Christmas together. That was 35 years ago. It was a very sentimental part of her collection and was hard to part with it. I’ve promised to put it back to its former glory for her, and enjoy it as much as possible.
em536716 is offline
