30th Dec 2015, 1:31 pm | #1 |
Codar CR70A Service Sheet help with missing text.
Hello Folks,
I have a downloaded Service sheet for the CR70A, but there is one particular word which is not clear on the print out or on the download. It is in the paragraph on IF alignment, Line 3 begins "short circuit" then the next word, possibly 4 letters, is faint, followed by "gang section (oscillation)". Does anybody please have an original copy of this sheet, and would they be willing to just tell me what this word is? I should presumably be able to make an educated guess, but since it was a minor miracle that I qualified to become a "Special Operator" in Royal Signals, and then subsequently pass the Radio Amateurs' exam, as my Radio Theory leaves much too be desired, the words 'short circuit' are somewhat worrying. All replies and advice greatly appreciated thanks in advance Dave G0SKK |
30th Dec 2015, 2:16 pm | #2 |
Re: Codar CR70A Service Sheet help with missing bits
Welcome to the Forum Dave. I'm sorry I can't help with this specific enquiry but there have been a number of threads re the Codar Company in the past and various sets including yours. It proved hard to pull out info on either but the CR70A model was better recorded than others. If you do a Codar search via the "top box" there may be other comments that prove useful to you as well!
Dave W Last edited by dave walsh; 30th Dec 2015 at 2:25 pm. |
30th Dec 2015, 2:59 pm | #3 |
The word is probably "rear" or "back".
What is means is that you must short-circuit the local oscillator section of the tuning capacitor to disable the local oscilator during IF alignment. Otherwise stations might break through into the IF circuits.
30th Dec 2015, 4:11 pm | #4 |
Re: Codar CR70A Service Sheet help with missing text.
My word Graham and Dave, that was quick !
Many thanks to both of you, I'm now searching for said sig gen. Thanks again Dave |
