Old 31st Dec 2020, 11:58 am   #1
Xyience
Default Connecting U43 to an Electric Bell
I have just restored and converted a French U43 Ericsson dated 1964.
I was amazed at just how little I needed to do to get this working on our phone line - a BT line cord, two diodes and a quick clean up of some oxidised contacts.
The sound from the earpiece is a bit quiet and the sound from the Mother-In-Law speaker is about 50% too quiet (any ideas? I might remove the added rectifier to see if this helps - I chose random diodes!)
Apart from this the phone looks and performs really well.
But to the main question - I have a vintage electric bell (see attached) that I would like to use as a bellset for the phone. I know it will not give a traditional twin-bell tone, but this car boot find deserves a purpose in life.
I cannot find much in English on the U43, and nothing about bellsets for the model.
Can anyone suggest a circuit that can connect the two?
[The bell dings nicely with a tired 12V battery, but too aggressively with a 12V 2.5A smoothflow model train supply]
HAPPY NEW YEAR TO US ALL
Xyience is offline
Old 31st Dec 2020, 12:41 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: Connecting U43 to an Electric Bell
The problem is that the bell shown is a DC trembler bell (rated, as you say, at 12V), whereas the ringing current from a telephone line is 25Hz AC at around 75V or so.
Incidentally, I am unclear what the diodes described are for.
Dave Moll is offline
Old 31st Dec 2020, 12:52 pm   #3
Xyience
That is an issue. It doesn't sound like compatibility would be easy or cost-effective.
Would the bellset/bell from a junked GPO phone work with the U43? These seem easy to come by.
The diodes are instead of a No 205 rectifier as suggested by https://www.britishtelephones.com/tranchan.htm
Phones are entirely new to me, and I didn't want to blast my families hearing, so I went with the instruction.
Xyience is offline
Old 31st Dec 2020, 1:05 pm   #4
Dave Moll
Dave Moll's Avatar
That sounds like a much better option. You could always use the DC bell as a doorbell.
After posting, I did wonder whether this was what you meant. The way these work is by only conducting above a certain level of signal so that they don't conduct at speech level but the higher-voltage spikes caused by switching are shorted out to prevent "acoustic shock" (loud clicks in the earpiece).
Old 13th Jan 2021, 11:52 am   #5
Xyience
I found a perfect donor telephone for my purposes. A stinky, discoloured cream 706. The smell off this phone actually made me gag once or twice!
I stripped off all of the components and mechanical items one by one until I was assured that I had just enough left to operate the bell. This left the metal chassis, the circuit board, but only to mount the striker mechanism, and the two gongs.
I added a resistor to correct the REN and wired up directly to the U43.
This works perfectly. When I get some more time I will give the bellset its own BT plug and add a nice cover to keep fingers away from the exposed terminals. This is hung high up on a wall so it is safe enough for now.
Everyone in the house loves the sound of the metal bells. Takes me right back to the 70's.
I experimented with the phone by taking out the DIY 205 rectifier. This does allow some unpleasant transients to reach the receiver, so the diodes stay.
Thanks for the tips Dave
Xyience is offline
