26th May 2020, 12:23 pm | #1 |
Cossor valve 220 O.T.
Hello to all. I would be grateful if some Forum Member could give me some advice on this valve. I removed this valve from a Cossor, Model 30 and was puzzled by the area around the base pins. There is a hole there, as if an extra pin had been removed. I am able to insert an insulated wire through this hole, and right up, inside the glass envelope. I was wondering if that is the way it should be. Thanks in advance. All the best. John.
26th May 2020, 12:40 pm | #2 | |
Re: Cossor valve 220 O.T.
John |
26th May 2020, 12:47 pm | #3 |
When you say you can insert a wire and see it in the glass envelope, can you see it in the 'pinch' tube or actually in the envelope with the anode?
What colour is the getter deposit? |
26th May 2020, 1:32 pm | #4 |
The 220 OT is a battery (2v 0.2A) Tetrode on a B5 base, so only has 5 connections.
Nothing has ever been in the 'spare' hole. Why it is there... no idea.
26th May 2020, 2:59 pm | #5 | |
John |
26th May 2020, 2:59 pm | #6 |
Its position is similar to below where the side screw terminal might go on the side of the base of a B5 Pentode.
It might be there to make it easier to connect the side terminal on the base when used on a Pentode during manufacture. Easier to make 1 base rather than many if you don't need the hole nothing lost. Just an observation. Cheers Mike T
26th May 2020, 7:02 pm | #7 |
Hello to all. Thanks for all your advice. I took another photo. Hopefully, the red wire can be seen 'inside' the valve. I just don't know if it should have access to there. All the best' John.
26th May 2020, 7:11 pm | #8 |
Hi John
Yes that's the pinch. If you watch how this style old valve is made it will become obvious. https://www.youtube.com/watch?v=_-JzxX75oYc&t=1116s from about 12 minutes in Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 26th May 2020 at 7:22 pm. Reason: added link |
26th May 2020, 7:37 pm | #9 |
The pins look like they could do with some solder.
26th May 2020, 8:18 pm | #10 |
Hello to all. Thanks for all your various replies and advice. The 'Modern Aladdin's Lamp' video was totally interesting. Thanks to Mike T for highlighting it. All the best. John.
26th May 2020, 8:25 pm | #11 |
At a guess it's to stop an air pocket disturbing the shellac (?) adhesive whilst it cures.
26th May 2020, 9:53 pm | #12 |
As my chidhood neighbour (he was in photo recon in WW2) said to ladies looking at the "pee hole" in old biplanes "What's that hole for?", answer "Lightness madam, lightness". I think the shellac idea is good but the pins have holes down them anyway.
