23rd May 2020, 9:20 pm | #1 |
Interesting Diode AA129
Was the AA129 made out of reject transistors ?
John.
My favourite text message "I'll be there in five minutes, if not read again" |
24th May 2020, 2:40 am | #2 |
Re: Interesting Diode AA129
Can't answer that, but interesting that a few suppliers (eg Cricklewood, Littlediode) still seem to have stock of them, so maybe not a popular item even in it's heyday.
24th May 2020, 9:59 am | #3 |
The fact that they have a Pro-Electron coding despite the OC71 style glass encapsulation suggests they may have been a way of disposing of old stocks or sweating obsolescent production facilities once the AC/AF series of transistors were introduced.
24th May 2020, 10:29 am | #4 |
You are possibly right Paul, it just looks a botched job.
John.
24th May 2020, 10:37 am | #5 |
They do look like an OC71 or OC45 with the base tied to the collector.
24th May 2020, 1:48 pm | #6 |
Gives them a way to convert duds into a revenue stream. Only needs one out of two junctions to be useable.
And can be done to anything found dud right up to post packaging. David
24th May 2020, 2:11 pm | #7 |
24th May 2020, 5:21 pm | #8 |
If you do a Google image search, different manufacturers have used different packages for this diode. Soldered, welded and plain two wire. Intended as a stabiliser diode.
25th May 2020, 1:48 am | #10 |
I seem to remember the temperature characteristic of a transistor would work better for this specific application so it might be intentional design and not a way to get rid of duds.
25th May 2020, 11:50 am | #11 |
Would be interesting to separate the leadouts and test as a transistor to see the characteristics.
Leave me alone - I know what I'm doing. BVWS member, EUG, G-QRP Radio Bygones/Radiophile |
25th May 2020, 1:02 pm | #12 |
Newmarket never made diodes as such, but I have seen a welded lead transistor used in this way.
25th May 2020, 1:17 pm | #13 |
The more common version of this as I recall was the AC128 used on convergence panels of the Philips G8
I don't suffer from Insanity. I enjoy every minute of it. |
