Old 22nd May 2020, 1:49 pm   #1
ValvoStef
ValvoStef's Avatar
Default Rotary switch and 7 segment
This is bugging me. I want a 7 segment display indicating the position of a rotary switch. So on switch position 1 the display should read 1, on position 2 two the display should read 2 and so on. What decoder is required? This is just an afternoon’s play on my bread board, no real purpose. Is there such a decoder IC?
Failing to prepare is preparing to fail ...
ValvoStef is offline
Old 22nd May 2020, 3:28 pm   #2
Default Re: Rotary switch and 7 segment
I have used a bunch of diodes to do this in the past, assuming you have a spare gang on the switch all you do is have segments (via a resistor each) for each required segment for each digit. Mine was for a Suzuki motorcycle gear indicator which was a 6 way single pole switch, six speed box with neutral a separate lamp in the speedo. ICs, you want a decimal to BCD encoder 74147 and then a bcd to 7 segment decoder 7447. Diodes would be more fun as you can decide on the numerals look and it would work on any available voltage.
Old 22nd May 2020, 3:57 pm   #3
ValvoStef
ValvoStef's Avatar
Yes, right, two ICs. Thanks, merlinmaxwell.
