Old 19th Feb 2020, 12:48 am   #1
Oldcodger
Default Bit of a longshot
As per title. And one for the aged GPO/PO blokes, who might have access to the station codes for CEL 6/6A stations in the highlands. Anyone got a location for TRS OB/C OR OB/D.
Oldcodger is offline
Old 22nd Feb 2020, 6:58 pm   #2
bc312
bc312's Avatar
Default Re: Bit of a longshot
I have a copy of the Directory of Repeater Stations (E-in-C 3210) from the 1960's which lists three Oban TRS's - Oban/A, Oban/B and Oban/E. These were staffed stations and terminals for TAT1 and Cantat cables. If Oban/C and Oban/D carried CEL 6A 4Mhz coaxial line systems, then they would have been unattended - and these were not always listed in the directory.
Might be worth contacting the Telecom Heritage Group (THG) who may have access to archives of coaxial line systems in the Oban area. From my transmission days with PO/BT, we didn't always wish to publish details of unattended buildings for obvious reasons. Sorry to be of no more help.
Mike
Leave me alone - I know what I'm doing.
BVWS member, EUG, G-QRP
Radio Bygones/Radiophile
bc312 is offline
Old 24th Feb 2020, 3:27 pm   #3
Oldcodger
Thanks, bc .OB/A was the original TRS for oban exchange. OB/B was the TAT terminal buried deep in a hillside and fed via through routes to London International . Two of the routes were fed on CEL6 (6A?) , one via Inverness and the other via Glasgow. I'd then suggest that since CEL 6 unattended surface stations were ( from memory) placed at most circa 4 miles apart that both were so close to Oban as to be given Oban designations. that would leave the next TRS to be designated as OB/E which was the CANTAT UK landfall station, on the same site (above ground as OB/B).
From my transmission days with GPO/PO, I remember the security as even in the early 70's , photography around OB/B, was frowned on. What ,on reflection, amuses me is that whilst the equipment in OB/B was protected by large steel doors and clean air systems, no provision was made for welfare facilities within that area. And again, all the unattended stations were out in the open.
