Old 11th Dec 2019, 10:38 am   #1
Sacul12
Default BT Decor 1200 handset
I bought this Decor 1200 secondhand and have stopped the play around the connectors which tended to make it cut out. However, it still cuts out occasionally whilst on a call, solved by tapping the headset on a hard surface. I suspect a loose connection inside the headset.
Does anyone know how to open it up? There is a central screw but when I remove it, the two halves won't shift, and I don't want to damage the slightly brittle casing.
Sacul12 is offline
Old 11th Dec 2019, 3:25 pm   #2
Graham G3ZVT
Graham G3ZVT's Avatar
Default Re: BT Decor 1200 handset
Hello and welcome.
I have a recollection of opening a similar handset by placing it face down on a solid surface and pushing down. The flexing of the plastic shells tend to release the clips at the two ends allowing you to pry them apart with a tool or maybe just your fingers. Obviously if it's brittle, it will be a judgment call as to how much pressure to apply.
Graham.
G3ZVT
Graham G3ZVT is online now
Old 11th Dec 2019, 3:59 pm   #3
Nickthedentist
Nickthedentist's Avatar
Doing it while it's warm will reduce the risk of things breaking.
Nickthedentist is offline
Old 12th Dec 2019, 9:42 pm   #4
Sacul12
Thanks, will work on these suggestions.
Sacul12 is offline
