27th Jan 2023, 7:23 pm | #1 |
Kokusai mechanical filter question
Hello to all,
I tried to find info about a Kokusai mechanical filter type "MF-455-12GZ". There is a lot of info about the MF-455-10GZ but nothing about the 12GZ. Who can help me? TIA Erwin, PA3DAF |
27th Jan 2023, 7:39 pm | #2 |
Re: Kokusai mechanical filter question
MF-455K Series Specifications Min. Band- width at 6 dB Attenuation (kHz) 2.0 3.0 Max. band- Standard Gain width at 60 dB at 4 Millimhos Working Temperature Range (QC) O to +70 O to +70 TYPE MF-455-10CK MF-455-15CK Center Max.
All I could find, they all sound a bit similar.
G8JET BVWS Archivist and Member V.M.A.R.S Last edited by HamishBoxer; 27th Jan 2023 at 7:44 pm. |
27th Jan 2023, 7:39 pm | #3 |
I wonder if the "10" or "12" defines the bandwidth?
27th Jan 2023, 7:57 pm | #4 |
On Radiomuseum 10 = 2kHz BW, and 15 = 3kHz, so I wonder if 12 is the very popular
2.7kHz BW. |
28th Jan 2023, 12:08 am | #5 |
This is as much as I have been able to find so far "12-element mechanical filter called MF-455-12GZ is also listed in the standard table" from here https://ala1530s.blogspot.com/2013/05/blog-post_22.html
It's in Japanese so you will need to translate it. |
