14th Jan 2023, 11:08 pm | #1 |
TEAC T-H500 Memory Battery
My TEAC T-H500 tuner does not store radio stations. I imagine that the battery needs replacement. Is this something that I could do myself?
15th Jan 2023, 1:32 pm | #2 |
Re: TEAC T-H500 Memory Battery
I have only had experience of replacing the battery in a Linn amp. It was quite straightforward, but did require the leads to be soldered in.
Paul |
17th Jan 2023, 12:56 pm | #3 |
The battery is available from CPC.
It needs soldering to the circuit board (after de-soldering the old one). Getting the top of the case off is a bit of a faff due to a strip of double sided tape along the front edge! Regards Martin
BVWS Member (lapsed!) Last edited by martiR2R; 17th Jan 2023 at 1:08 pm. |
19th Jan 2023, 7:50 pm | #4 |
Thank you, both. I really appreciate the information about the battery and I have contacted CPC. I'll let you know how it goes.
28th Jan 2023, 3:09 pm | #5 |
Well, I did it! I found my trusty old soldering iron and made the replacement. I really enjoyed taking something that was pretty useless and giving it a new lease of life. I wish that I knew more about electronics as I would do it more often if I did.
Thank you for the information above. It is most appreciated |
28th Jan 2023, 5:29 pm | #6 |
Good that you got it working again
Paul |
29th Jan 2023, 5:20 pm | #7 |
Glad you managed to sort it - the H-500 series is nice kit.
Martin
BVWS Member (lapsed!) |
