Old 13th Jan 2023, 9:41 pm   #21
EnyaFox
Default Re: Bush A774
They both look very familiar. I think the first one looks better cosmetically. I will need to swap the tuners over if I use the first cabinet. The tube, this new one has a long deepish scratch on it. I will hook my tester onto them at some point after a bit of playing around.
Another thing, can the DY802 be replaced with the DY86 or 87?
EnyaFox is offline
Old 13th Jan 2023, 9:53 pm   #22
EnyaFox
Here's another photo of its current view.
EnyaFox is offline
Old 15th Jan 2023, 3:03 am   #23
EnyaFox
With higher wattage bulbs in my limiter, the TV seems to show a full picture and is working quite well.
EnyaFox is offline
Old 15th Jan 2023, 10:52 am   #24
slidertogrid
slidertogrid's Avatar
That looks good! I would say it is OK now to give it full mains, run it for a while and keep an eye on it. Then check the main capacitor can and the LOPT for any signs of heating above what would be normal. If the set still has its yellow or grey plastic TCC capacitors you are doing well as they are usually leaky to the point that they affect the frame lin etc. looks like you may have a set that has been stored in a dry environment.
As you probably know the chassis is easy to swap over into the other set if you want to see what the tube is like, better to picture test a mono tube than to trust a tester as the recent thread on the field find Sobell has demonstrated...
slidertogrid is offline
Old 15th Jan 2023, 11:07 am   #25
its ur aerial
its ur aerial's Avatar
Re. DY86/87/ Dy802, there is a difference, can't remember what: shrug: but back in the day we put in either, I believe the DY802 was the modern equivalent .
Running that set through your Lamp limiter, (and I understand why) may affect the supply to your set and thus the Heater and HT volts probably more than you might think and affecting its performance
A common obscure fault with these sets was, dry joints and cracks on the chassis were it is soldered to the earth print on the main PCB, this gives you weak sync and other weird faults .
Any way you have done very well, they were never a big favourite in the Trade.
Life is not Hollywood, life is Cricklewood.
its ur aerial is online now
Old 15th Jan 2023, 11:28 am   #26
slidertogrid
I think the DY802 was a higher rated valve for later sets with higher EHT so it will replace the DY86/87 . the 87 was just a later version of the 86 with better insulation I think... as a rule 86/87 for earlier 19" sets 802 for later 20/24" 'Square screen' sets.
Old 15th Jan 2023, 1:40 pm   #27
EnyaFox
I had tried each tube, one kept ballooning but the one I prefer does not thankfully. I had been measuring the output voltage on the limiter with a multimeter, it sits around 220v.
EnyaFox is offline
Old 17th Jan 2023, 11:01 am   #28
Hybrid tellies
Hybrid tellies's Avatar
Glad it's come to life. Make sure you resolder all the earthing or chassis joints to the PCB. You can avoid a lot of problems doing this.
If the mains filter capacitor has been snipped out I would make sure you replace it as it can result in the on off switch contacts arcing over when you switch the set off.
Simon
BVWS member
Hybrid tellies is offline
Old 19th Jan 2023, 1:57 am   #29
EnyaFox
The mains filter capacitor was the first thing I changed. I will resolder all the chassis joints when I work on it next.
I have replaced most of the electrolytics and that has helped with all the stability issues I think.
What steps, if there's any, should I take that could possibly make the TV less likely to fail in the future?
EnyaFox is offline
Old 19th Jan 2023, 3:09 pm   #30
Welsh Anorak
Welsh Anorak's Avatar
As Simon says get a big iron and resolder the earthing frame to the PCB at all the points. It may be necessary to remove the solder, clean and add flux, but it's worth the effort.
Also run the boost voltage as low as you can with acceptable width so the LOPT doesn't struggle too much.
Otherwise they were pretty reliable TVs let down by the LOPT. The picturess aren't bad compared with, say a Thorn 1500, but the previous A640/793 and later A816 did put them in the shade.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 19th Jan 2023, 3:52 pm   #31
flyingtech55
Agree with the comments about resoldering the PCB 'earthing pads'. Some technicians used to wire them all together with insulated copper wire. Some made a better job of it than others it has to be said.
TimR
All those moments will be lost in time, like tears in rain.
flyingtech55 is offline
Old 19th Jan 2023, 6:00 pm   #32
its ur aerial
This was my Modus operandi, for the more troublesome examples, and as neat as possible, given the circumstances, of the customers dwelling, many only lit by a 15W Pygmy lamp Ah, the memories of, Field service, wasn't it a joy! Wiping your feet on the way out
Ken, G6HZG.
Old 19th Jan 2023, 6:48 pm   #33
EnyaFox
Otherwise they were pretty reliable TVs let down by the LOPT. The pictures's aren't bad compared with, say a Thorn 1500, but the previous A640/793 and later A816 did put them in the shade.
Will continue on it tonight hopefully.
EnyaFox is offline
Old 19th Jan 2023, 7:08 pm   #34
flyingtech55
....... Wiping your feet on the way out
Ken, G6HZG.
Oh yes...got that t-shirt. The ones you lifted but kept the set away from your body while you carried it out to the van 'cause you didn't want it to touch any part of you. Just your hands was bad enough!
TimR
Old 20th Jan 2023, 7:16 am   #35
its ur aerial
Tim.....Kept the set away from your body
Or sometimes, you didn't even want to touch the mains plug !! .
Ken G6HZG.
Old 20th Jan 2023, 2:38 pm   #36
Welsh Anorak
Those days aren't over for some of us...
Glyn
