22nd Jan 2023, 5:19 pm | #1 |
Faulty mono 1/4" Jack Plug to Phono socket Adaptor
I ordered 4 of these. Three were as expected and good quality too, but the fourth was a bit troublesome.
Have you spotted the fault? Has anyone seen this before? You learn every day don't you! Kind regards, Andy
Now where on earth did I remove that from? |
22nd Jan 2023, 5:22 pm | #2 |
Re: Faulty mono 1/4" Jack Plug to Phono socket Adaptor
Where's the (usually black plastic) insulating bit between tip and ring?
22nd Jan 2023, 5:30 pm | #3 |
Top marks go to dazzlevision for first correct responder!
It makes you wonder how this can possibly happen on a production line. It makes an effective zero ohm dummy load!
22nd Jan 2023, 5:39 pm | #4 |
Fasc-i-Nating!
I guess they were cheap, and that's reflected in the manufacturer leaving final QA checks to the customer. [I once bought some 90-degree PL259 adapters that went open-circuit when expected to handle more than about 100 Watts; the 90-degree-ness was, it turned out, implemented by a springy bit of brass soldered to the centre-pin one side, which simply pressed against the brass centre-pin on the other side. Push significant RF through it, the springy brass strip got hot and unsoldered itself from its mounting - resulting in internal fireworks]
22nd Jan 2023, 5:56 pm | #5 |
I wonder if it's intended to be a shorting plug for test purposes that ended up in the wrong stock bin, gathered for dispatch with the others by uninformed staff?
22nd Jan 2023, 6:21 pm | #6 |
If it's a shorting plug, why would it have a phono socket on the other end?
22nd Jan 2023, 7:02 pm | #7 |
I don't understand how this could happen. Presumably the tip and body are two separate parts which are assembled during manufacture. The photo shows the tip and body as a single metal part.
I don't suppose Mr Photoshop has been busy by any chance? |
22nd Jan 2023, 8:01 pm | #8 | |
It could be that the manufacturer has spent the money on good-quality bits, abd saved it on final testing, on the basis that it's not safety-critical, and any problems they'll just replace, no quibbles. |
22nd Jan 2023, 9:39 pm | #9 |
Interesting about the PL259s. Just goes to show.
I too am mystified as to how this could have happened. Take a look at the good ones in the photo below - they have three distinct parts to them. The defective one is all one machined piece. It's all very strange. Perhaps it's a bit of a game - you know the sort of thing, find the golden cornflake in a packet of cereal and win £100?! As you say, the defective one will make a good shorting plug, but then I agree, why fit the phono?
24th Jan 2023, 2:04 pm | #10 |
Maybe the factory has a 'short testing apparatus' to check the adaptors for faults.
A dummy adaptor would then be useful for testing the 'short testing apparatus' to make sure it is still working. The dummy then found its way into the finished product box. |
25th Jan 2023, 1:33 pm | #11 |
Yes maybe that's what it is. Interesting!
25th Jan 2023, 3:56 pm | #12 |
It seems a lot of work though to create separate tooling for it rather than just have a standard plug with the terminals wired together (and suitably labelled).
25th Jan 2023, 7:55 pm | #13 |
It sure does.
