Old 5th Dec 2022, 10:05 am   #1
DMcMahon
DMcMahon's Avatar
Default Coomber 393 Cassette Player/Recorder No Playback Sound
Early 1990' s vintage solid state mono cassette recorder with SofTouch logic solenoid control.
It can be used with up to 6 headphones for group listening such as in schools/colleges.
I purchased very recently and it was sold as "fully working".
Mechanically everything works well, but there is no playback sound when playing tapes, the same on internal loudspeaker, external loudspeaker, line out and headphones.
There is hiss sound but not tape hiss, because the hiss stays the same when tape playing back is paused or if no tape is present when play is selected.
The volume of the hiss can be varied with the volume control, but the level of the hiss can be different for the same volume setting, e.g. with volume set to mid position the hiss may be quite loud or quite quiet at different times.
Apart from the User instructions was not able to locate any other documentation so posted a documentation request here -
https://www.vintage-radio.net/forum/...d.php?t=196526 and received some very helpful and useful information.
DMcMahon is offline
Old 5th Dec 2022, 10:23 am   #2
DMcMahon
DMcMahon's Avatar
Default Re: Coomber 393 Cassette Player/Recorder No Playback Sound
Did a test recording using the internal microphone, just the same hiss on when recording played back. This version of the 393 only has automatic recording level control.
Trying the tape in another cassette machine the 393 recording had erased the previous recording on the tape but no new recording.
So looks like Erase works, will need to go inside to investigate further.
DMcMahon is offline
Old 5th Dec 2022, 10:40 am   #3
ben
ben's Avatar
That is the first 393 model dating from 1990.
First thing is check the leads are soldered on the head.
Ben.
ben is offline
Old 5th Dec 2022, 3:57 pm   #4
G6ONEDave
G6ONEDave's Avatar
After checking head wiring continuity, also check that the rec/playback switch has contact continuity in both modes. Might possibly be a dirty switch contact, exercising the switch will prove that and if so hopefully a case of cleaning it.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
Old 5th Dec 2022, 5:29 pm   #5
DMcMahon
DMcMahon's Avatar
Got inside, without further stripping cannot see let alone access the PB/Record head wiring, looks like black frame plus maybe the metal bits below as per photo 3 would have to be removed.
Did a good visual of all the various wires connecting to the 2 main boards, including the board on the mechanism itself. Nothing untoward seen.
Decided to power up and try flexing the various wires and lightly taping the various items to see if could get playback sound to work.
But low and behold without doing anything else, it now is working and cannot get the sound to stop working.
Will give the Record/Playback switch a spray of contact cleaner and clean the heads (which look pretty clean already) and reassemble to see if it then still works.
ID:	269395   Click image for larger version
ID:	269396   Click image for larger version
DMcMahon is offline
Old 5th Dec 2022, 10:53 pm   #6
ben
ben's Avatar
While you're in there, check the soldering on the output sockets. I have worked on dozens of these and in most of them there were cracked joints.
The no audio problem that resolved itself rings a bell, I think I had one with a capacitor in the amp that had turned into a resistor and muted the audio. Will see if I made a note. Oddly enough the rec-pb sliders rarely gave trouble in my experience.
Another thing to check is the condition of the belt. Ensure there is no slipping when you put the deck into record as well as play - a loose belt will not manage to drive the flywheel under load, or will do so intermittently. Likewise, there should be full auto shut off in all transport modes - if it doesn't happen, new belts are needed.
Ben.
ben is offline
Old 5th Dec 2022, 11:47 pm   #7
sourbiscuits
Hi David! I actually happen to own this exact model. It's actually my very first tape recorder I got about three years ago from our local thrift store. I have repainted it since I got it and added some extras like an on/off switch and a custom speed knob with a switch between stock and custom speed so I can actually go back to normal playback/record speeds
When you engage playback, does the volume knob make any difference on the hiss, does it adjust the levels at all if you have to judge? I would ask the same about the tone knob - does that change the hiss frequency at all? SInce I can actually shut the motor off on mine, even with the motor off, there is still a hiss coming out from the outputs which is being affected by the volume/tone knobs. Even with the volume knob all the way down, I can still hear a bit of it and the tone knob affects it if I listen carefully. so maybe check the pots I guess?
ID:	269412   Click image for larger version
sourbiscuits is offline
Old 6th Dec 2022, 12:33 am   #8
DMcMahon
DMcMahon's Avatar
Cleaned the heads (pretty clean already) and general tape path area, also sprayed contact cleaner on the Play/Record switch and exercised it by selecting Record (selecting record also automatically selects Play).
Reassembled and it is still working well on playback, sounds pretty good actually with a fair bit of volume available.
Did test recording using the internal microphone and it worked fine. Still to check external microphone and line recording.
Cannot explain why the original problem, can only assume a bad connection somewhere that went bad during shipping, hopefully it will stay good now, time will tell.
It was all reassembled by the time I read Ben's post 6, next time I look inside I will check out his suggestions.
DMcMahon is offline
Old 6th Dec 2022, 12:37 am   #9
DMcMahon
DMcMahon's Avatar
Now it is working correctly there no longer is a hiss issue.
When I had the problem of just hiss on Playback (even when tape was paused) the volume control did affect the hiss level (no hiss if volume fully ACW) and the tone control did have some affect on the hiss frequency.
DMcMahon is offline
Old 6th Dec 2022, 11:10 am   #10
ben
ben's Avatar
A few extracts form the Jan 1992 catalogue.
ID:	269421   Click image for larger version
ID:	269422   Click image for larger version
ID:	269423   Click image for larger version
Ben.
ben is offline
Old 6th Dec 2022, 1:56 pm   #11
TonyDuell
They're cheaper than I would have expected given that, presumably, it was a limited market and that 'educational' items always seem to be overpriced.
I'd wondered why the speaker was mounted on the back of the cabinet, now it makes sense.
TonyDuell is online now
Old 6th Dec 2022, 2:12 pm   #12
sourbiscuits
I wonder if it's possible to actually add a knob to control the input level? Would it be as easy as adding a audio pot between the input line and the circuit 🤔?
Old 6th Dec 2022, 2:33 pm   #13
sourbiscuits
Old 6th Dec 2022, 5:03 pm   #14
TonyDuell
The 393 has automatic recording level control, so simply attenuating the input signal probably won't do what you want.
Take a look at the sevice manual, in particular the added circuitry for the 395 (which has manual level control as well). It adds a level control potentiometer, 4 LEDs + comparators to judge the level and a switch to disable the automatic level circuit. Needless to say this is not a trivial additon but you might not need all of it (e.g. the level LEDs and drivers)
Old 6th Dec 2022, 8:01 pm   #15
DMcMahon
DMcMahon's Avatar
Was this a Coomber specific catalogue? i.e. their own catalogue.
DMcMahon is offline
Old 6th Dec 2022, 8:05 pm   #16
DMcMahon
DMcMahon's Avatar
What is the reason for wanting to do this?
DMcMahon is offline
Old 6th Dec 2022, 8:18 pm   #17
sourbiscuits
Well, so I can have control over the input signal. Mainly concerning the line input. Coming to think of it, I can probably just adjust the output signal I am feeding in I guess? Is that what you're on to?
Old 6th Dec 2022, 8:46 pm   #18
ben
ben's Avatar
Yes.
Ben.
ben is offline
Old 6th Dec 2022, 8:58 pm   #19
DMcMahon
DMcMahon's Avatar
I have yet to test line recording with the Coomber.
Personally, normally all I use for line signals are either the Tape/Rec Out phono's on Hi-Fi amps or the Audio Out phono's on CD player, normally these are fixed level line level signals. I would assume the Coomber auto recording level control should be able to cope with line level signals.
With some manual recording recorders that have DIN line inputs I do find that sometimes the phono line level signals are too strong, in that case I fit fixed resistor droppers in the phono to DIN cable.
DMcMahon is offline
Old 6th Dec 2022, 10:05 pm   #20
ben
ben's Avatar
On these first and second versions of the 393, The DIN socket on the front is switched. When a plug is connected the internal mic is muted.
This DIN was replaced in later versions (393/7) by a quarter inch jack socket which was line input in rec and line output in play. Last time I saw that setup was in a Grundig dictaphone!
The ALC is quite gentle in these, acceptable results with music can be obtained. Mono, of course!
Ben.
ben is offline
