Hints, Tips and Solutions (Do NOT post requests for help here) If you have any useful general hints and tips for vintage technology repair and restoration, please share them here. PLEASE DO NOT POST REQUESTS FOR HELP HERE! |
5th Apr 2021, 7:07 pm | #61 | |
Re: Leaking batteries. A reminder, a warning.
"The remote-control doesn't work - the batteries have burst" being a good reason for most people to replace their five-year-old TV with a newer, higher-spec, more-energy-efficient model. |
5th Apr 2021, 9:51 pm | #62 |
Pragmatically, I've today consigned to the local burn-pit a couple of recent "Uniross" 1300mAH NiMH AA cells that had started to 'sweat' worryingly.
My experience with rechargeables is that the-higher-the-capacity-the-shorter-the-service-life: a bunch of Energizer-brand 2000mAH or 2400mAH AA cells bought a few years back have all failed, as have a bunch of Maplin's own-brand 2000mAH bought when the stores were closing-down - whereas I've got some older AA Uniross 1300mAH that are still going fine after near-on a decade. |
6th Apr 2021, 7:34 am | #63 |
For all of Amstrad's cost cutting one thing they did right was putting the clock batteries in the top of the case and not inside like others. Means naturally that it's less likely for any leakage to damage the motherboard.
For once value engineering that created improvements! |
7th May 2021, 12:05 pm | #64 |
Another brand to keep an eye on. The AAA seems to have seeped from the -ue end but stains are visible on the side. The AA has grown rust at it's +ue end. (Although it's 1.5 years over it's BB date)
Both these Philips cells were in car or shed equipment, so fluctuating temperatures were probably an issue over time. Dave |
7th May 2021, 1:53 pm | #65 |
They all leak. But I suppose some brands are worse than others. The problem is, so called 'brands' are often farmed out to be manufactured at different locations by different battery manufacturers. So the batteries you buy this week may not be the same as those you bought last year and were good. This was what Which? found many years ago.
7th May 2021, 4:32 pm | #66 |
I can well believe it, and i'm sure we get the same cells wearing different jackets/branding from time to time.
Inevitably i am having a purge, and have now found 3 or 4 of the *Philips AAA (09-2021) batch that have leaked whilst still holding a charge. The Panasonic C pictured deserves a mention (05-2020) as it is growing rust spots on it's +ue. That's only a year over, so a bit naughty. Less destructive than these* though. One type which hasn't given me any gip yet (famous last words) is the bronze jacketed Alkaline Panasonic AAA,AA,C,D and PP3 variants. The AAA range aren't very gutsy, but that's not an issue to me if they can stay in one piece until their time's up. If i can't get them next week it's going to be Varta.. Dave |
7th May 2021, 4:45 pm | #67 | |
7th May 2021, 10:26 pm | #68 |
Well I have just examined an item of test gear fitted with RS C type Alkalines. These
have a distinctive silver/black case which indicates Made in Japan. Not only are these 1991 cells perfectly lively but there is no leakage. Something not mentioned is that older equipment used off/on switches that isolate the battery whereas more recent designs are really on standby when turned off, this leads to slow discharge and leakage - remote controls are a good example of this. |
7th May 2021, 11:01 pm | #69 |
The new "boombox" my neighbour recently bought for his son's birthday won't work on mains unless it has a set of batteries. He asked me to look at it before taking it back as it wouldn't work. It needed 8 "C" cells and he was lucky I had just bought a pack of 12 in my last order from CPC and could let him have a set. The one it replaced didn't need batteries for mains use.
8th May 2021, 3:28 am | #70 |
Make a note of the make of that boom box so that we can avoid it.
Clearly the batteries are only there to rot it down so that you have to buy another. |
8th May 2021, 3:43 am | #71 |
I'd measure the current that boombox draws from the batteries both with the mains lead unplugged and with it plugged in. I wonder if the mains supply does anything at all.
8th May 2021, 7:09 pm | #72 |
(I recall looking inside a sixties transistor radio that wouldn't operate on mains without a trickle from four D cells..The finer points were lost on me as i was 10 at the time.)
These are the Panasonic alkaline type which are -so far- behaving. I have used them in all five common sizes, and as mentioned the PP3 and AAA cannot compete with others regarding capacity. There are six of these D cells inside my maglite, all are 1.555v-1.556v off load, no dropouts. BB date is 2024 so it's too early for cast iron recommendation. Dave |
9th May 2021, 1:54 pm | #73 |
Interesting- most of those featured in Post No. 64 onwards are made in China, a few in Poland. The bronze coloured Panasonic however- Belgium.
Varta PP3- Malaysia Varta AAA- Germany! |
22nd May 2021, 1:54 pm | #74 |
Hi!
The batteries my work buys ("Progizer" (!!) and red–and–silver "RS Pro" alkalines) are so short–lived there's virtually no chance of them getting old enough to leak! My LED magnifying glass goes through two "AAs" in three days and the Fluke 287 official meter I use at work eats 6 "AAs" every week! Chris Williams
22nd May 2021, 2:37 pm | #75 | |
Regards, Ken. BVWS member |
23rd May 2021, 11:13 am | #76 |
23rd May 2021, 2:43 pm | #77 |
Attached pictures of our favourite culprits - 6No Duracell U2's recently prised out of a nearly wrecked (well .... it already was!) Akkord Penguin u62 Deluxe .... together with a cloud of copper sulphate etc. The battery rack has been restored and the set converted to run on re-chargeable AA's ..... Mein gott ... as they say in der Fatherland!
Red to red, black to black. Throw the switch and stand well back! |
23rd May 2021, 7:39 pm | #78 |
I have always been fond of Varta batteries - mainly because my grandfather always used them. He worked in a car parts store that sold them and so he could buy them cheap. He was a man who taught me a lot about mechanic and electricity so somehow I feel comfortable in using a product that he approved of.
I can't remember any mishaps with any Varta batteries. They are also made made in Germany which appeals to me as a worker in manufacturing. I don't know how available they are in UK though. GP is another favourite of mine. |
23rd May 2021, 7:51 pm | #79 |
I wonder why the (Duracell) factory in Begium simply can't work out a permanent fix for their wretched leaking batteries... the amount of equipment damaged or destroyed by them must surely be an indication that they are simply getting something fundamentally wrong... it's not like they are the cheapest batteries on the market.
...where on earth did that spring/screw go?? |
24th May 2021, 5:54 pm | #80 |
Varta has become my go-to brand for alkaline batteries in recent years; Screwfix often have them on special-offer.
I've never yet had one go leaky on me. Panasonic are also good - as are Tesco own-brand ones! |
