Old 31st Jul 2022, 5:32 pm   #1
David Simpson
Default Military Compass Repeater
Just acquired this 8" dia. compass display item from a silent key dispersal. The circular card has been changed from a 0 to 360 degree one to a nautical bearing one.
Stamped into the matt black faceplate is a crow's foot & 5T/238 below the needle spigot, and "DEPRESSION" (lhs) & "ELEVATION" (rhs) above. OS 2000 is stamped into the rear bakelite casing. Haven't got round to feeding an AC source into the T/F, will wait for expert advice. The 5 wire rear terminal plate looks similar to the connector on my ex military Desyn Test Set, but that takes 24V DC. As does the wee compass repeater shown in my Desyn thread - what - 3 or 4 years ago. Maybe a display for a motorised antenna, or perhaps the old chap was planning an RDF display to work with his (grotty looking) 1155 Rx. I've no idea.
Any advice most appreciated, please.
Regards, David
Name:	Bill's Compass (a).jpg
ID:	261907   Click image for larger version
Name:	Bill's Compass (b).jpg
David Simpson is offline
Old 31st Jul 2022, 6:16 pm   #2
Dennis M
Default Re: Military Compass Repeater
Looks similar to the selsyn transmitter and receiver set up I used on a home made aeriel rotator over 50 years ago.(I still have the transmitter and receiver in the garage loft).My pole sat on a Mini car brake hub and was driven by an old Creed teleprinter motor, top bracket had a surplus bearing sleeved down to fit the 2" pole.
If it is it should run on 400Hz, running it on 50Hz will not give accurate bearings on the display.
Dennis M is offline
Old 31st Jul 2022, 6:44 pm   #3
Ed_Dinning
Hi David, yes looks like a Selsyn type of device.In MIL guise they normally worked at 400Hz, but I believe some were designed for 50Hz, what does it say on the unit?
Ed
Ed_Dinning is offline
Old 31st Jul 2022, 7:32 pm   #4
ex seismic
Depression and Elevation indicates gunnery origins.
ex seismic is offline
Old 31st Jul 2022, 8:07 pm   #5
jamesinnewcastl
jamesinnewcastl's Avatar
Hi
This is a really good read on such devices!
https://reports.aerade.cranfield.ac....=1&isAllowed=y
James
jamesinnewcastl is offline
Old 31st Jul 2022, 8:51 pm   #6
David Simpson
Thanks James for the link. 'Fraid Ed, nothing etched or printed anywhere relating to frequency, 400c/s or otherwise.
The T/F is made by The Douglas Coil Company, & the i/p primary tapping's are at 0 & 250V. Powered up on my Variac - & the secondary o/p measures 27.3V.
Hopefully some military ref. no. guru can identify the 5T/238 reference number ? Will put a thread post on the VMARS Forum site as well.
Regards, David
Old 31st Jul 2022, 10:46 pm   #7
M0FYA Andy
I'm struggling to find any reference to Section 5T in the Air Ministry Stores Reference list, AP1086. The Index I have doesn't include Section 5T, so I don't even have a title.
However I have found the attached picture in my archive, 5T/237, obviously closely related, but with no further details.
Very puzzling!
Andy
M0FYA Andy is offline
Old 1st Aug 2022, 1:08 am   #8
majoconz
majoconz's Avatar
If it was an aircraft device, I would expect the transformer to be for 115v 400Hz, so a lot smaller than the iron you have. The only time at sea that I recall the 'course to steer' as a bearing on the bridge chalkboard was on a Geordie collier in the 60's, peculiar things like "NE by N 1/2 N" - on our RNVR Minesweeper it was definitely degrees. Interesting that it shows bearings rather than degrees and in a nice wooden box, I'm wondering if your synchro repeater was from a training school, the bearing scale looks hand printed.
Cheers - Martin ZL2MC
majoconz is offline
Old 1st Aug 2022, 11:12 am   #9
David Simpson
Hey Guys, that's identical, and certainly the varnished wooden case lends itself to a military classroom. Wish my memory was sharper - the NAV. Inst. training section was just next door to the practical workshops where I was an instructor, 50 years ago at RAF Cosford, & our duties sometimes crossed over.
When I acquired it on Saturday, not having un-screwed the back cover, I'd hoped it might compliment my Desyn testing set-up.
For maritime usage, maybe I'll put a post on the "Ship's Nostalgia" "Radio Room" Forum. Guys there have been jolly helpful over the years.
The deceased chap(late 80's) whose kit I acquired, hadn't been seriously active in amateur radio pursuits(he was a "G3") since the 70's. So perhaps this repeater was a shelved "to do" project. His only rig was a full KW2000/1000 set-up, (in great cosmetic condition, & now residing on the only spare space I now have - a woodworking bench, but well covered in a big dust sheet).There was no corresponding antenna DF kit with the KW stuff. It's now destined for a G8 VMARS local pal, who has been laid low with covid. However, I've acquired the old chap's IC-22, & its working great after all these years, with a magnetic whip plonked on my Yeti roof.
Regards, David
Old 1st Aug 2022, 11:35 am   #10
M0FYA Andy
David,
Is there any chance of a picture showing the 5T/238 marking for my photo archive, please?
Many thanks,
Andy
Old 2nd Aug 2022, 12:27 pm   #11
David Simpson
I'll try Andy, but don't be too hopeful. The markings are only faintly stamped into the matt-black face plate & I needed a bright circular bench-light plus a wee magnifying glass to read them. I'll maybe try a lead-pencil "rubbing".
Regards, David
Old 2nd Aug 2022, 4:11 pm   #12
M0FYA Andy
OK, thanks for looking!
Andy
Old 6th Aug 2022, 9:59 pm   #13
David Simpson
Well Andy, bit of trial & error, but this is the best I can do. I'm not actually needing the repeater, and shall ask around our wee gang up here if someone wants it. If they don't, then its yours backsheesh if you want it.
Regards, David
Old 6th Aug 2022, 10:00 pm   #14
David Simpson
Forgot the picture
Name:	Selsyn Faceplate.jpg
Old 6th Aug 2022, 10:41 pm   #15
M0FYA Andy
David,
Many thanks for persevering!
I can't think of a use for the unit, so give priority to anyone who can use it, although I'll give it a home rather than you skip it!
Thanks again,
Andy
Old 7th Aug 2022, 7:06 am   #16
G3VKM_Roger
G3VKM_Roger's Avatar
That's a possibility, maybe the people who run the RAF Langham Dome might know more?
https://langhamdome.org/
Roger
G3VKM_Roger is offline
Old 7th Aug 2022, 10:01 am   #17
David Simpson
Hey Roger, I guess I should be ashamed of not knowing what the RAF Langham Dome is. Having spent a total of 6 years at RAF Cosford, I ken all aboot their Museum. Have also been in touch with the Communications Museum at RAF Henlow, several times. But Langham ?
Don't worry Andy, there is no chance of me skipping the selsyn repeater.
Regards, David
PS. Just Googled it - By sheer coincidence, RAF Cosford was one of the other stations which had an identical Dome. It was situated between the A41 road junction & Cosford Halt and its railway bridge. Demolished in the late 60's.
Old 7th Aug 2022, 10:52 am   #18
pmmunro
While elevation and depression would be strong indicators of gunnery applications, would it not have had to be in a training establishment?
A large glass fronted instrument in a plywood box would not have stood a chance of survival beside a gun which had to move rapidly and be laid in the vicinity of large heavy shells being handled with some considerable urgency! Even on a ship it would have been rather delicate.
The need for an electrical supply suggests that at least some motor vehicles must have been around when it was used, but more likely a building of some kind.
PMM
pmmunro is offline
