24th Jul 2022, 9:06 am | #21 |
Re: Grundig TK24 belts location
Rechecked the EL 95 results and unless I am going stupid (hopefully not ) the results are not drawn correctly.
On the valve, pins 1 (G1) and 7 (G1) are internally linked but 0V is shown on pin 1 and 20.7V on pin 7, i.e. pins 1 and 7 should read the same. 181V is shown on pin 2 (Cathode/Grid 3) which is far too high. 202V is shown on pin 3, pin 3 is a heater filament connection so will not have DC voltage on it. 0V is shown on pin 5 (Anode), the anode will have a high HT voltage on it via the output transformer secondary winding. 21V is shown on pin 6 (Grid 2) this is far too low Please recheck the EL 95 results. David |
24th Jul 2022, 9:31 am | #22 |
To remove the chassis from the case as you know involves disconnecting the loudspeaker wires.
When powering up the chassis when it is out of the case, it is not good to leave the speaker disconnected, so either reconnect the speaker wires or switch in the 20 Ohm dummy speaker load resistor (R48) by pulling up the volume control until you hear its switch click. David |
6th Nov 2022, 11:43 am | #23 |
Hi , sorry ,but this got put at the bottom of a large pile , I think the confusion was I couldn't get to the pins on the bottom so I pulled the valve out slightly and measured from the top and must have drawn them wrong , although I put this back together today and didn't realise the on /off knob is also an internal speaker off ,,,, ...
So it appeared to be working ok , I left it playing for a while but the volume seems to get less and less until nothing over a couple minutes or so . sorry again for the late reply . |
6th Nov 2022, 1:41 pm | #24 |
Does not sound good, does the output transformer get noticeably warm/hot during the volume fading ?
See what happens to the main HT voltage at C31 (as per Post 19) when the volume fades. David |
7th Nov 2022, 9:36 pm | #25 |
Hi , so I removed the chassis again and rigged up the speaker with some extension cables but cannot get it repeat the volume fading issue , had it playing for an hour or so and it appears to be working fine , !
