27th Oct 2020, 11:25 pm | #1 |
Coil question
I wind a coil on a plastic former and add wire till it reaches, say, 100uH. All fine. If I insert an iron rod or something the uH goes up. Infact, winding coils on iron or ferrite formers is well understood (maybe not by me!).
Out of curiosity today I HALF wound a coil then wound the remainder back on itself, effectively winding it on a copper core and lo and behold the inductance went UP, a lot in fact. To achieve the same end I used less copper wire and a shorter former. Remember this was just on the bench. Question...why dont we wind all coils back on themselves? There must be a good reason, but I havent found it yet... On a similar vein, in many vintage radios I see coils wound tight spaced, then a big gap and another coil wound. Obviously winding many coils on one former...yet they are all in series! How does this work and why is it done? I have also seen many different forms of windings - the most exotic I thing being basket wound coils...but then my head explodes and I offer great respect to engineers of old. David
David, G4YVM. |
28th Oct 2020, 12:07 am | #2 |
Re: Coil question
General comments - based on my understandings.
First, the sense of any overwind matters: does it aid the inductive coupling or decrease it? Second, the capacitance between each turn for a single layer coil limits Q and thus bandwidth. Same applies to multi-layer coils. Third, the capacitance between two windings on same former is relevant: mutual coupling must also be considered. Fourth, when measuring inductance, the capacitance of the measuring device is relevant as is the inductance of the connecting wires, coil to instrument. (There is also the question of 'How accurate is my measuring device?' of course). Finally, inserting a core with into any coil often changes the flux density, depending on the material of that core. Ferrous materials increase that density; brass, OTOH, decreases it. The greater the flux density, the more magnetic lines of force cut the coil, thus increasing its inductance. In summary, it's mutual inductance and inherent capacitance that must be considered in coil design, not just number of turns, length of coil and spacing between coil turns. As we all have experience of, amongst the three physical factors in analogue design - resistance, capacitive reactance and inductive reactance - its the latter that causes the most uncertainties. Al. |
28th Oct 2020, 8:03 am | #3 |
Re: Coil question
That is why medium and long wave coils were wave wound - to reduce winding capacitance. You'll see that on rod ariels and IF transformers. Lots of information on what is needed and at what frequencies in the Radiotron Designer's Handbook, 4th Ed.
The other technique, used from the year dot in the first generation of radio receivers is basket winding. Same idea - reduce the winding capacitance and increase the self-resonant frequency. Craig |
28th Oct 2020, 8:47 am | #4 |
Re: Coil question
Ah...i KNEW id get answers here. Thanks
D
David, G4YVM. |
28th Oct 2020, 9:33 am | #5 |
Re: Coil question
You'll also see vintage chokes where the winding is broken up into a number of separated sections, all connected in series, each section wave-wound. The aim is to reduce internal stray capacitance and to limit how much inductance that capacitance effectively connects across. Instead of one stonking big self-resonance at an inconveniently low frequency, this pushes the resonance up in frequency. Really wily designers would make the sections dissimilar so the resonance broke up into several on higher frequencies, but all slightly different.
The amateur radio world needed broadband chokes to feed DC power to the anodes of their transmitting valves. These were a right devil to design and tales abound of smoke, flashes and bangs when someone tuned to a resonance. So chokes got broken up into sections, artfully chosen to dodge the bands they would be used on. Bang up to date and at GHz, there are chokes made wound on a conical mandrel which spreads out self-resonance. You can get tiny surface mount ones. So the old principles live on and still get exploited today. David
28th Oct 2020, 3:35 pm | #6 | |
Re: Coil question
Like this National one perhaps? Kind regards Dave |
28th Oct 2020, 6:41 pm | #7 |
Re: Coil question
Did any common rig (or even linear amp) bandswitch down the sections of the anode choke?
It seems that you could arrange it to do that. I can't recall having seen it.. Maybe due to added capacitances it causes more problems than it solves? Last edited by Jon_G4MDC; 28th Oct 2020 at 7:06 pm. |
28th Oct 2020, 7:29 pm | #8 | ||
Re: Coil question
Gotta doff yer cap to some of these fellas. D
David, G4YVM. |
29th Oct 2020, 4:10 pm | #9 | |
Re: Coil question
Much amateur-radio gear failed to learn from some US WWII Military gear which was to put the PA anode-choke on the _output_ of the pi-stage: this has the great advantage that when properly tuned the Pi-tank acts as a LPF and isolates unwanted choke-resonances from the PA. It also generally moves the choke from a high impedance to a low impedance point in the circuit, again reducing losses. [Only downside is that the entire Pi-tank infrastructure sits at HT+ so you need good insulation - and wider air-gaps in the tuning capacitors since these are now subjected to the combined RF-voltage-plus-HT on peaks] |
29th Oct 2020, 8:40 pm | #10 |
Re: Coil question
The little nanovna would be a great (and cheap!) tool to use to explore the various resonance modes in inductors wound for the HF bands. To get the best results the nanovna would have to be used with a PC as this allows some powerful options.
The only issue would be which version of the nanaovna to buy. I think many people are opting for the genuine V2 with the larger display. I'm not sure what they cost or how long the delivery time is though. One other demanding design task (for coils) is the design of a high power HPF. If the filter needs to operate over a wide bandwidth then the design of the coils can be quite challenging. A typical design at work might start at 25MHz and operate to 1GHz or so. This requires careful design of the coils to achieve adequate Q and also to avoid resonance modes falling into band at the top of the band. Things start to get challenging above about a 10W power level for this frequency range.
Regards, Jeremy G0HZU |
