26th Oct 2020, 7:28 pm | #1 |
Digital Tuner to analog converter?
I understand that you can buy the above? I’m enjoying my old vcrs for playback but would love to record on them again. Had good look on web and there seems to be loads but I just want one with RF connections. Thanks for reading Mark |
26th Oct 2020, 7:52 pm | #2 |
Re: Digital Tuner to analog converter?
Most of them don't have an RF modulator these days, some older ones are listed in post #7 of this thread: https://www.vintage-radio.net/forum/...72#post1193472
Another possibility would be if the VCR has video and audio inputs. |
26th Oct 2020, 8:13 pm | #3 |
Thank you. Unfortunately I don’t have permission to look at the link. The video recorder has a bnc video out and a din plug for sound.Could this work?
26th Oct 2020, 8:33 pm | #4 |
If it's video out then I'd have thought not as it'd be the output to the monitor or TV, probably monitor if it's BNC.
You could also, slightly more complicated but more versatile, get a stand-alone RF modulator with RF out and other inputs. Amazon usually have a few for sale. Some have SCART only, AV only, or both. Just another option to think about? '77 |
26th Oct 2020, 8:51 pm | #5 |
Thank you very much. Have seen one on Amazon that accepts AV input could I put an bnc to av adapter on it?
26th Oct 2020, 9:00 pm | #6 |
If you want to record to VHS on the same VCR, which is how I take it from what you've written, then to put it shortly, no.
You'd want to connect the RF output of the modulator to the RF aerial input of the VCR, and then connect a source to the modulator via AV, tune the VCR to the RF input and then record like that. '77 |
26th Oct 2020, 9:15 pm | #7 |
It's in the Modern Technology section, only two more posts to go and you will be able to see it! In the meantime here is the list:
Goodmans GDR10 , GDR11 Digital TV Receiver Humax F2-Fox-T , PVR9200T , the latter has a hard drive for recording programmes Icecrypt T5000 , T2300HD * Thomson DTi2300 * , DTi6300 Top Up TV * modulator may be disabled by default TVOnics MFR-200 , MFR-300 Early Ferguson FS01SDB Does the VCR have a BNC video input? |
26th Oct 2020, 9:15 pm | #8 |
Unusual for a video recorder to have video out via a BNC and audio via DIN. Just in case we are missing something, please advise machine make and model.
In addition, you mention video recorders in plural. Are these of different formats and again. some indication of what they are. Earlier threads identify old DVB set top boxes with an RF Modulator, the Goodmans GDR11 being one, but caution that they may need a few parts in the power supply to be replaced as they are well past their service life. My one was working fine last time I used it, so fingers crossed..... Chris |
26th Oct 2020, 9:51 pm | #9 | |
To record off-air TV any Freeview, Freesat, Sky set-top box will do as a source, you just need a cable with a SCART plug on one end and BNC & phono plugs at the other, or a standard SCART to SCART with an adapter. No digital to analogue converter required. The only gotya you may encounter is you need the lead to connect to the output pins of the SCART, not the inputs; so get an adapter that is switchable.
-- Graham. G3ZVT Last edited by Graham G3ZVT; 26th Oct 2020 at 9:57 pm. |
26th Oct 2020, 9:58 pm | #10 |
What you need is a Multiview D35 or a D2B Multibox 6T. They were used in hotels to allow analogue only TVs to still work after switch over to digital .
The D35 and D2B convert a selected digital channel and transmits the analogue conversions on to any UHF channel 21-68 at once. The D35 converts 5 digital channels with Teletext. The D2B converts 6 digital channels with Nicam stereo sound. They do appear on a well known auction site quite often. |
26th Oct 2020, 10:03 pm | #11 |
Thank you all for education. The vcrs are all top loading Ferguson clones and JVC. Ferguson model number 3v30. BNC Video in and out 2 of them and din audio in/out 1 of them
Thanks again |
