Old 21st Feb 2021, 12:25 pm   #141
Travellingwave
Default Re: My first telly TV22
Thanks Helder . Should be able to make something similar
Travellingwave is offline
Old 21st Feb 2021, 12:27 pm   #142
Helder Crespo
Helder Crespo's Avatar
Originally Posted by Travellingwave View Post
Think I’ll reconnect the EY now and see how it looks
Good idea. The photos of the part are in my previous two posts.
Helder
Helder Crespo is offline
Old 21st Feb 2021, 12:45 pm   #143
Helder Crespo
A quick question: when you use the diode(s), do you still get changes in image size with brightness?
Old 21st Feb 2021, 1:58 pm   #144
beery
beery's Avatar
The missing part, the cam follower needs to be made from brass or aluminium, not steel.
I know that I have some spare TV22 focus units, but probably only at my parents house, so I can't get to them at the moment.
I will have a quick look around here though.
Andy
beery is offline
Old 21st Feb 2021, 2:32 pm   #145
Travellingwave
I think the brightness and contrast are now behaving as I would expect and don’t affect the image size
Old 21st Feb 2021, 2:40 pm   #146
Helder Crespo
Ok, but do you mean with the diodes in place, or with the EY51 alone?
Old 21st Feb 2021, 3:23 pm   #147
Travellingwave
With the diodes , will refit the EY51 this PM
Old 21st Feb 2021, 3:26 pm   #148
Helder Crespo
Ok. If without the diodes your raster changes with brightness, then the EY51 is probably at fault.
Old 21st Feb 2021, 3:58 pm   #149
Travellingwave
Diodes out , EY51 back in and it works just fine. The brightness still affects the size a bit but nothing like it did . And it actually functions as a brightness control now.
Old 21st Feb 2021, 4:11 pm   #150
Helder Crespo
Very impressive! it must feel great. Can your set resolve the finer gratings now?
The size dependence on brightness is normal, provided it is not excessive. If you adjust the contrast to enable viewing in a well-lit room, like with a more modern set, you will probably get more changes with brightness. Adjusting the contrast to a lower position usually minimises this issue. The TV22 is comparatively less bright than anything from the 60s or 70s. So even though the change with brightness can be indicative of a worn EY51, one should resist the temptation of getting the contrast too high up, which of course will give you a brighter image, but you see changes whenever an image goes from dark to bright and vice-versa, including a loss of sharp focus.
Old 21st Feb 2021, 4:13 pm   #151
Helder Crespo
Judging from your image, your line sync is rock solid. It would be great to see a closeup of the raster. I think your camera lens may need some cleaning to remove the glow. Otherwise the picture is fantastic.
Old 21st Feb 2021, 4:18 pm   #152
Helder Crespo
You can also adjust the horizontal form (see photo) to get better horizontal linearity. This adjustment, the horizontal width and the focus are somewhat interdependent.
Helder
Old 21st Feb 2021, 4:25 pm   #153
Helder Crespo
I have another question: what do you think was the most important change that resulted in a smaller dependence of image size on brightness?
Old 21st Feb 2021, 4:29 pm   #154
Travellingwave
Realising that the focus magnet was not working is what solved it, the set is pretty much back to how it was when I first switched on , apart from fixing the brightness pot and a bit of twiddling
Old 21st Feb 2021, 4:29 pm   #155
Travellingwave
I won’t get focus spot on till I make a new cam follower pin for the magnet
Old 21st Feb 2021, 5:05 pm   #156
Travellingwave
I’ve bodged up a pin for the focus , not pretty bu it works
Attached a close up of the picture, I can see the vertical lines on all but one of the gratings now
ID:	227288   Click image for larger version
Old 21st Feb 2021, 5:15 pm   #157
Helder Crespo
Looks great really. Thanks.
Old 21st Feb 2021, 5:22 pm   #158
Travellingwave
Thanks for all the help and interest from everybody.
I guess next step is to put it back in the case and hook up something to watch on it.
Old 21st Feb 2021, 6:11 pm   #159
Sideband
Sideband's Avatar
I doubt that you will see the vertical lines clearly on the last grating even with optimal focus. It's excellent as it is and you've done a great job.
Sideband is offline
Old 21st Feb 2021, 7:15 pm   #160
Helder Crespo
It is possible to see them, but it requires excellent alignment. A good example can be found here (photo on the last post of this thread's page): https://www.vintage-radio.net/forum/...ht=tv22&page=4
