9th Jul 2020, 12:43 pm | #21 |
Re: Cold cathode voltage stabilizers, OA2 and the like.
There are plenty of explanations around if you look up "Relaxation Oscillator"
It does indeed use hysteresis and an R-C time constant. They are not terribly good voltage regulators, but are an awful lot better than unregulated supplies open to mains variations as well as load changes. As has been pointed out, manu types had traces of radioactive material included to seed ionisation and give lower and more stable striking voltages, but much of thhis material will have decayed by now, affecting characteristics Little neon bulbs can also be used as voltage references for low current use. Babani published an entire small book on trick circuits for neon bulbs... many of them relaxation oscillators. Squegging is another form of relaxation oscillation where the hysteresis comes from the sratr-up and stop characteristics of an intentional oscillator. David
9th Jul 2020, 12:50 pm | #22 |
Good point, I may have been misremembering my measurements but I seem to recall Am-241 giving off a small amount of gamma but probably not enough (or at least too infrequent) for this application
9th Jul 2020, 1:17 pm | #23 | |
(I can conceive of a situation where with several in series, none of them strike, if the supply isn't high enough (must equal the sum of all the striking voltages). But once one has struck, then the voltage across it will immediately drop to the maintaining voltage, thereby putting a higher voltage on the remaining few, which are then encouraged to strike... Or so it seems to me). |
9th Jul 2020, 1:20 pm | #24 | |
https://w5jgv.com/downloads/General%...%20Edition.pdf John |
9th Jul 2020, 2:06 pm | #25 | |
Anyway the only tubes out of the eight I have that seems to raise the background count is two Brimar OA2 style with a ribbed central column, and the one that works can take the count to around 120 to 150 counts per minute. The faulty of the same style takes the count to around 50 to 60 counts per minute. Is this a lot? No idea, if I put some 2% Thoriated TIG electrodes near the counter I can get over 110 counts per minute. Of the other 6 OA2 of which all are all straight sided central tubes, non, as I say seem to increase the count and these include Brimar RCA (some marked for HP) and one marked with a Makers 'E' & 'WH'. of these that make no discernable difference 3 (Brimar, RCA-HP & E) work and three do odd things (RCA and 2x RCA-HP). The tubes were all placed along side the detector, move the tube away from the detector a few inches and I am back to background levels. Not something I will be getting upset about. Adrian Last edited by AdrianH; 9th Jul 2020 at 2:14 pm. Reason: add pictures |
9th Jul 2020, 2:10 pm | #26 |
Thanks John I will save and have a read.
9th Jul 2020, 2:11 pm | #27 |
You're right not to be worried as long as the valves are intact. The big issue with alpha emitters, and to a lesser extent with betas, is if you manage to ingest any particles of radioactive material, either by swallowing it or breathing it in. This can really only happen if the valve is smashed.
Cheers, GJ
http://www.ampregen.com |
9th Jul 2020, 2:19 pm | #28 |
GJ;
I have to be careful when I grind the TIG Electrodes to a point not to inhale the dust, the correct thing now would be to get another non-radioactive style. I think somewhere, I have some old gas mantle's that could take my counter into the hundreds. Adrian |
9th Jul 2020, 4:04 pm | #29 |
HI
Back in the day I recall some telemetry equipment that used three electrode cold cathode devices as logic elements. They had to have a small fluorescent tube in the box to light them otherwise they became unreliable. So the standard phone call to the remote site was "has the small lamp gone off?" "then leave the cabinet door open and leave the room light on." Ian |
10th Jul 2020, 7:10 am | #30 |
If i understood/translated note 1 on the second page of this datasheet for the ZZ1040 correctly, it says that if you make use the auxiliary electrode you can shunt the main electrode to ground with as much capacitance as you like without the risk of oscillations.
https://frank.pocnet.net/sheets/128/z/ZZ1040.pdf Greetings, Robert |
10th Jul 2020, 7:17 am | #31 |
Translations skills for me are very poor is that the same style device as the GR16?
https://frank.pocnet.net/sheets/174/g/GR16.pdf In which case it is the trigger pin that can be done with a cap and is used for things such as relay triggers etc. Have one somewhere came in a batch of 70 valves from the bay but not utried anything with it. Adrian |
10th Jul 2020, 8:27 am | #32 | |
In theory you need with two voltage reg tubes in series the running voltage of one plus the striking voltage of the other and then of course, plus some more to be the running drop across the series resistor which powers whatever is downstream. The idea is that you have high value resistors to unbalance the voltage distribution across the two tubes. The one you give the lion's share of the voltage to strikes, and now the other tube gets a higher voltage to light it up. As a simple string of tubes, you would in theory need the sum of the striking voltages, plus some drop in the series resistor (load current) but by getting all artful, you can bring it down. The drawback is that you need enough current to keep the lit ones lit while the later ones are thinking about lighting. As a number of half-lives of the radioactive assistance have ticked by, the difference between striking and running voltage will have increased, making these things harder to use. Principally the striking voltage will hav gone up. It should be possible to make a little solid state shunt regulator to replace these valves if they ever become too rare or too intractable, but I'd miss that glow at the back of my AR88. David
10th Jul 2020, 8:46 am | #33 | |
I recently used two ZZ1040's in series to get 200 V for feeding the screengrids of two EL86's in push-pull. But I did not shunt the main electrode(s) with capacitance because I first wanted to know/hear how it would work without capacitance. Because the amplifier works fine like it is, I will leave it like this. https://www.vintage-radio.net/forum/...d.php?t=168442 Greetings, Robert Last edited by Robert Gribnau; 10th Jul 2020 at 9:04 am. |
10th Jul 2020, 11:13 am | #34 | |
Yes, the attractive violet glow through the top grille on the Eddystone 750 here makes a fetching "HT present" pilot light! |
10th Jul 2020, 11:54 am | #35 |
I only just realised that I have this document (and found the link to it): https://frank.pocnet.net/other/Telef...isers_1966.pdf
10th Jul 2020, 1:40 pm | #36 |
Regarding the addition of radioactive materials to assist in ionisation, this was not confined to voltage regulator tubes.
Some older types of fluorescent lamp starters, intended for 110 volt to 127 volt circuits (or for two lamps in series on 220 to 277 volts) were slightly radioactive. |
10th Jul 2020, 6:50 pm | #37 |
So are Gas Discharge Tubes for surge arresting.
Beware that these tend to show reduced striking Voltage after every "thump". GDTs were fitted on the input side of many SWmode PSUs by that very good company based in Yorkshire. On one railway job they were subjected to a lot of mis-treatment. Eventually the GDTs were firing at the peak of mains Voltage thereby taking out the fuses. Maybe in 100 years they would recover and be OK again! |
10th Jul 2020, 7:44 pm | #38 |
the issue of 'getting enough voltage to strike series-strings of VR-tubes but not using a low-value series-resistor which will overload them on startup" was addressed in the 1960s: here's a narrative by G3VA [from his 'technical topics' series]
[apologies for the horrible image-quality]. |
10th Jul 2020, 7:56 pm | #39 |
And here's another circuit from the same series, detailing how to get a glow-tube regulator to 'strike' despite the voltage-drop across its series-resistor (under load) being somewhat low.
In times-past I've done a similar thing but feeding the 'starter' resistor directly from the rectifier-cathodes [yes, it;s got lots of ripple but it always worked!] |
10th Jul 2020, 9:24 pm | #40 |
Hi!
Can I point the OP in the direction of Practical Wireless, July 1962, to the article, "Neons in The Experimenter's Power Pack", by Martin L Michaelis, from A.R.H./W.R.H? Mr. Michaelis goes into the theory behind, and the correct usage of, neon regulator tubes in great detail and I strongly recommend any Member always has the data–sheet for any n.o.s. neon or other gas–filled regulator tube on hand, together with Mr. Micheaelis's article before attempting to use them in a new or experimental circuit. I also strongly recommend a minimum anode current of about 15–20% more than the minimum quoted in the datasheet for the tube, this should be adequate to bring the tube into the "normal glow" region of it's characteristics. As Member GMB quite correctly states, any radio–active material originally incorporated in the gas–filling at the time the tube was manufactured would, by the natural law of exponential decay, typically would have only 3–5% of the radioactivity present when the material was fresh, assuming the tube was manufactured in the 1960s, therefore there would be much fewer ions available to "prime" the discharge. Theoretically, the tube manufacturers should have compensated for the natural decay in radioactivity from the primer incorporated with the gas–filling, by providing more radioactive material than theory suggests was needed, but this may not have been possible due to safety regulations associated with handling and storing it. It's for this reason that certain types of cold–cathode regulator tube were manufactured as "triodes", with an auxiliary priming anode or cathode in the electrode system, that only needs a very small current across the priming gap needed to assist the main gap in the tube to strike. J.B. Dance's book, "Cold Cathode Tubes", (Illiffe, 1966), free from the Internet Archive, is well worth a study as well! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 10th Jul 2020 at 9:37 pm. |
