Old 24th Nov 2021, 4:00 pm   #21
safetyfirst
Default Re: Panasonic DMR-E75V dead
Thank you. You are correct in the need for caution. I have very limited experience - call me a complete beginner - i have a simple multimeter with some experience of its usage.
safetyfirst is offline
Old 24th Nov 2021, 4:30 pm   #22
agardiner
agardiner's Avatar
OK, have you got the service manual / schematic for your unit. The next stage is going to be powering it up while exposed - CAUTION - and measuring the voltages coming from the power supply.
I would suspect that the power supply is probably not running and not therefore outputting any voltages. There maybe people here on the forum who would take a look at just the power supply for you if you are not comfortable working on live equipment.
agardiner is offline
Old 24th Nov 2021, 4:59 pm   #23
safetyfirst
Thank you agardiner et al. I think you are correct in that there is no power output at all. I think before i start working on any live equipment, i will replace the output IC as i mentioned in a previous post. I can get one with the same reference number online and at least i am then cutting down the possibilities! i have seen some people undertaking testing and measurement but i dont have any circuit diagrams etc
Old 24th Nov 2021, 5:26 pm   #24
af024
I don't know whether this is for the DMR-E75V or not. It's labelled as being the PSU for the DMR-EX75V. Is this one in the same device perhaps?
Now where on earth did I remove that from?
af024 is offline
Old 24th Nov 2021, 5:29 pm   #25
af024
Oh perhaps it's not. The DMR-E75V (no 'x') does look like a different machine externally. Sorry if I've introduced a red herring!
af024 is offline
Old 24th Nov 2021, 5:31 pm   #26
agardiner
agardiner's Avatar
Most of these types of supply have a high value resistor, (typically 1M) to 'start' the supply. Basically they provide power for the switching IC before it starts to oscillate, whereupon it usually gets its power from a secondary winding on the main transformer. These high value resistors frequently go open, particularly as the associated small electrolytic goes high ESR. So worth checking these resistors in the primary.
When the switching IC fails, it is usually fairly obvious, as they generally fail short circuit, so blowing fuses etc.
Old 25th Nov 2021, 2:23 pm   #27
Welsh Anorak
Welsh Anorak's Avatar
If the resistor has gone open circuit the main electrolytic will hold its charge and be ready to bite you! Check it with your meter.
As a very rough rule of thumb, I find if the board's been disconnected from the mains for a short while, a high voltage on the main smoother means the PSU isn't doing anything (the start-up resistor/capacitor or the switching IC at fault), a small voltage points to a secondary fault and absolutely nothing points to rectified mains not getting to the circuit.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 25th Nov 2021, 3:37 pm   #28
safetyfirst
Thank you all. I have had a good look at the power side this morning and cannot find anything labelled as a resistor - or that looks like one. Plenty of capacitors, inductors, diodes, the IC but only two very small pink resistors elsewhere on the board ie not close to the power side
Old 12th Dec 2021, 3:50 pm   #29
safetyfirst
Thank you for all your help.
I have changed the IC on the power side and now i actually have some power and a display!!! However, it comes up with a U99 error and there does not seem to be anything happening on the DVD recorder side.
Any advice?
Old 12th Dec 2021, 4:43 pm   #30
dj_fivos_sak
According to the service manual, the U99 error code is displayed when a communication error has occurred between the main microprocessor and the timer microprocessor.
dj_fivos_sak is offline
Old 13th Dec 2021, 11:02 am   #31
Welsh Anorak
U99 is not a good error code, and tends to be a fault on the MPEG board which interfaces with the DVD or, as Fivos says, a general communication error.
Try several hard resets and double check you haven't disturbed any wiring (weve all done it!).
Now you've reminded me to get back to that EZ48 with U99 on the display - thanks!!!
Glyn
Old 14th Dec 2021, 5:03 pm   #32
safetyfirst
I think I have the problem. I replaced the ribbon cable from the DVD to its processor because the original was damaged. I have now noticed that the replacement is not the same. On the original, I think it is the first line crosses over and joins somewhere about the third line (on both edges and at each end). I cant seem to find any replacements that match this configuration so I think I am well and truly thwarted unless anyone has any suggestions. I have learned a lot from you chaps though so not all wasted time.
Old 14th Dec 2021, 5:54 pm   #33
Welsh Anorak
Can you post a picture? I have quite a few scrap EZ seies machines and might have the cable you need.
Glyn
Old 15th Dec 2021, 11:26 am   #34
safetyfirst
Picture attached. The cable is like this at both ends and is about 29cms long
Old 15th Dec 2021, 1:48 pm   #35
Eidolon
This sounds very similar to what's going on with my machine
Eidolon is offline
Old 15th Dec 2021, 6:20 pm   #36
Welsh Anorak
Any chance of the width? It's critical obviously and you'd be surprised how many close variations there are. Also is it a straight piece or is there a bend in it?
PS That crossover is bizarre. I'll look tomorrow and see what I have.
Glyn
Old 15th Dec 2021, 10:04 pm   #37
Michael Maurice
Michael Maurice's Avatar
Originally Posted by Norman Raeburn View Post
Hi David, I get my Panasonic capacitors from Alan Harrison ex CHS, good prices and service. I can pm his number as I am not sure I can post it on here. All tge best, Norman
You can post his details on here, phone number / Website.
Forum Moderator
Michael Maurice is offline
Old 16th Dec 2021, 11:57 am   #38
safetyfirst
The cable is 13/16th of an inch or 21mm wide. It has three right-angled bends in it to enable it to go from the left hand side of the recorder (as you face the tray front), under the recorder and then turn to 90 degrees to enter the top of the micro-processor!
Old 16th Dec 2021, 1:40 pm   #39
safetyfirst
This machine records onto DVD-RAM and DVD-R. It strikes me that other Panasonic models that do the same eg DMR E55 might have a similar type of cable/microprocessor
Old 16th Dec 2021, 1:54 pm   #40
Welsh Anorak
The one I have is 22.5 mm wide and only has one bend. Crucially it doesn't have that weird corossover in your picture.
I'll keep looking.
Glyn
