27th Mar 2020, 7:36 pm | #61 |
Re: 1946 Why 405 lines?
Picture taken this afternoon on a 17" Murphy V310, probably one of the best 405 line receivers of the mid 50's period.
The off screen shot does not do justice to the superb picture that sports 100% interlace. It is pin sharp with a high level of usable contrast making it difficult to resolve at full speed with digital cameras. The original Mazda CRM172 aluminised tube certainly gives a good account of itself. One of the better Mazda CRTs. This service area model does not incorporate vision AGC, gain being controlled via two preset sensitivity controls. One for Band 1 and one for Band 3. The DC conditions are maintained and it shows! 52 years old. Amazing. John. |
27th Mar 2020, 8:01 pm | #62 | ||
27th Mar 2020, 8:51 pm | #63 |
The Pilkington Committee was much more than 405/635 colour TV standards although that was an important item. I was a teenager when it was in session and didn’t take any notice of it, probably didn’t understand the consequences of its decision either.
A short version of the report, it’s about 50 pages. https://archive.org/details/op1265876-1001/mode/2up
Frank |
28th Mar 2020, 11:13 am | #64 | |
Peter Last edited by peter_scott; 28th Mar 2020 at 11:20 am. |
28th Mar 2020, 12:36 pm | #65 |
I agree it does look good but it would probably look a lot sharper looking at the screen. The firm I worked for before I went self employed were Bush agents and those early sets really did give a pin sharp picture.
Some CRT's were better than others and I always thought that the magnetically focused ones gave a sharper picture than the electrostatic ones, the EHT made quite a difference too, I remember a Baird 13 channel set with very high supply, the lines were like razor blades and you couldn't defocus it at any brightness level. Bring back simplicity - please! Peter |
28th Mar 2020, 3:15 pm | #66 |
Ideally you need a camera with a 1/50 or 1/25 shutter setting. Before my JVC DV camcoder developed an unrepairable fault that prevented me from accessing the manual settings menu, I was able to record from the screen of CRT tv's without flicker or interrupted raster. It was necesssary to use trial and error to attain the latter by turning off and on again until the camera was synched with the TV so that no line was visible part way down the frame. I used this method to record from French TV when we were at my late brother-in-law's in France to see the 1999 eclipse.
I recall managing to get reasonable results from 405 line TV in the 1960's using my Halina 35X 35mm and Ensign 120 folding cameras, whose shutter speed ranges used the older series of multiples of 1/25 sec, but the later models of most cameras use the series with 1/15, 1/30 sec etc. |
28th Mar 2020, 4:51 pm | #67 |
If we are talking still cameras then 1/50 or 1/25 is not very helpful because you are unlikely to get both half frames with equal brightness even with 1/25 just because of the relative phasing of the shutter release and the frame sync pulses. You need a longer exposure so that you integrate over several frames.
With cine you really need genlock to avoid aliasing effects although some cameras with digital slow shutter ability can give quite good results. Peter |
28th Mar 2020, 6:10 pm | #68 |
Most new digital cameras will "auto sync" to an "AC" scene, all my Panasonic Micro 4/3rd's jobs do it, you can see them syncing in the (electronic) viewfinder. Rather impressive.
