Old 23rd Mar 2020, 8:41 pm   #1
IKC2E51R8
Default Identify Resistor (Dansai portable)
Hi Everyone
Can someone help me identify the value of this resistor.
Its part of the Vertical Circut in my Dansai 9313A. Lost Vertical Deflection and this resistor is on the Vertical output of the Vertical IC (which was also cooked) and replaced.
I need to replace this in an attempt to restore vertical deflection but Im getting stuck with the value and this Chassis is kinda strange in that there seems to be many variations of it so finding a service manul with parts list is next to impossible.
Colours look to be RED RED GOLD GOLD BLUE
Appreciate any help
ID:	201497   Click image for larger version
Luke
IKC2E51R8 is offline
Old 23rd Mar 2020, 8:50 pm   #2
peter_scott
peter_scott's Avatar
Default Re: Identify Resistor
I think the gold third band indicates x0.1 so I guess 2.2 ohms. 5% tolerance, Temp coefficient 10 ppm/C
Peter
peter_scott is offline
Old 23rd Mar 2020, 8:52 pm   #3
high_vacuum_house
high_vacuum_house's Avatar
Good evening,
Not sure of the value though it Looks like a fusible resistor rather than a standard resistor. It is designed to fail open circuit in the event of an overload without generating too much heat and causing a fire risk in the process.
Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television
high_vacuum_house is offline
Old 23rd Mar 2020, 9:06 pm   #4
David G4EBT
David G4EBT's Avatar
I stand to be corrected, but it looks a bit like a 1 Watt 2R2 Ohmmetal film resistor to me.
Red, red = 22, first gold band is the multiplier, which is 0.1, so that make it 2R2 Ohms.
Second gold band is the tolerance, for which gold is 5%. (strangely enough!).
See:
https://www.google.com/search?q=resi...wY-yzF5-JptLM:
Hope that helps.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 23rd Mar 2020, 11:05 pm   #5
IKC2E51R8
Thanks Everyone, found a spare and replaced it still no vertical. The investigation continues....
Luke
Old 28th Mar 2020, 4:40 pm   #6
its ur aerial
its ur aerial's Avatar
I would also go with the 2.2 ohms Fusible resi opinion.
Ken G6HZG
Life is not Hollywood, life is Cricklewood.
its ur aerial is offline
Old 28th Mar 2020, 5:01 pm   #7
Refugee
Refugee's Avatar
In the first photo it looks like there is some of that brown poison on the board.
It will need to be cleaned off and any components it has come into contact with replaced or at least thoroughly tested.
Both of those caps will have to come off and be cleaned at least.
Refugee is offline
Old 4th Apr 2020, 9:50 am   #8
JonSnell
JonSnell's Avatar
Check you have supply on pin7 and frame pulses on pin4.
Output pulses on pin2 and the 2R2 resistor is on the return from the vertical deflection coil. My schematic is so poor, I cannot make out the ID number. R409? 2R2 1W fire proof.
Don't forget to replace the coupling, boot strap and decoupling electrolytics on that stage!
JonSnell is offline
Old 4th Apr 2020, 4:52 pm   #9
Sideband
Sideband's Avatar
Don't know the set but it probably follows normal conventions. As suggested above by Jon, change those suggested capacitors.....any of those drying out will contribute to the chips demise. The supply to pin 7 is probably fed via a low value fusible resistor which will likely have failed and while you're at it, check the diode that feeds the supply to pin 7 via the fusible.
Sideband is offline
Old 12th Apr 2020, 4:04 pm   #10
IKC2E51R8
Hi all
Have taken a break from my Philips set im working on and gone back to my very first TV of my own, my little portable Dansai.
So I havnt changed any of the electrolytics yet cause I wanted to find that fuseable resisitor that caused the vertical collapse. Found it, R408, comes off Pin 5 of the Flyback, a little 68ohm fuseable was open. Replaced and vertical is mostly back, I have the same issue here that I had with my Sharp 8PSR set a few weeks ago, vertical foldover, the solution on the sharp was a Diode gone bad beside the bootstrap cap, im thinking its a similar situation with this
Luke
