Old 23rd May 2020, 4:42 pm   #1
Mr Etronic
Default Manganin coil resistance box by Pye and Co
This arrived today. I'll test it later, but screws have not been tampered with, so should have original coils.
Mr Etronic is offline
Old 24th May 2020, 11:52 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Manganin coil Brige by Pye and Co
Looks like a resistance box, not a bridge though it could be used as part of a bridge circuit if you wanted. Manganin has a decently low TCR too.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 25th May 2020, 10:50 am   #3
Mr Etronic
You are totally right, variable resistance box, I would have to add it in a tiny circuit, but you're right.
I'll try it this week, I'll get the room to 17 centigrade and it should give great accuracy.
I'm tempted to open it. Screws look untouched so maybe best left alone. The same goes for restoring the top, where it has lost some shine, due to use.
Old 25th May 2020, 11:41 am   #4
factory
Default Re: Manganin coil resistance box by Pye and Co
Here is the Pye Wheatstone bridge I have, it looks a bit later then your resistance decade box, but has the same style controls for the Manganin coils.
ID:	206722   Click image for larger version
ID:	206723   Click image for larger version
factory is offline
Old 25th May 2020, 10:20 pm   #5
Mr Etronic
Got to get one of those...love it. Mint inside. Was it expensive?
Old 26th May 2020, 1:10 am   #6
trobbins
trobbins's Avatar
I have a PYE 7440/G wheatsone as well. It was interesting to check how the coil resistances had aged over the last 70 years or so. It seems that the 1kohm resistors have had a harder time of it, given they use the finest gauge wire, and may have been exposed to the highest power loss during equipment use.
https://www.dalmura.com.au/static/PY...dge%207440.pdf
trobbins is online now
Old 26th May 2020, 10:06 pm   #7
factory
Will have to investigate to see if the resistances have aged, thanks for the link to the manual, I couldn't find anything like that when I searched a while back.
I also got a single Pye Manganin resistance at .1 ohm along with a selection of decade resistors & capacitors and a couple of meters from other makes. There was another similar Pye resistance (different value) but someone bought it before me.
All of these were from Southampton University.
I can't remember how much they cost, but I did make a note, just can't find it.
ID:	206873   Click image for larger version
factory is offline
Old 26th May 2020, 11:59 pm   #8
Herald1360
Herald1360's Avatar
That's a nice four terminal shunt you have there!
It would be interesting to know what its max current rating is.
....__________
Old 27th May 2020, 7:02 am   #9
Diabolical Artificer
Diabolical Artificer's Avatar
"It would be interesting to know what its max current rating is. " 13A, bottom RH corner Chris.
Andy.
Diabolical Artificer is online now
Old 27th May 2020, 11:37 am   #10
Mr Etronic
I just tried mine. At first meter was all over the place. Just twiddled the knobs and it settled and was spot on. Must be dirt or something sticking. It is about 100 years old, probably has not been used much lately. But outstanding quality. Out at higher values but seems to get better as I use the knobs?
Old 27th May 2020, 12:02 pm   #11
Mr Etronic
A few results.
ID:	206900   Click image for larger version
ID:	206901   Click image for larger version
ID:	206902   Click image for larger version
Old 29th May 2020, 11:27 pm   #12
factory
Well mine seems to check out good as a resistance box (one of the uses in the manual), I was going to use a 4.5 digit meter but it didn't want to work (intermittent fault).
ID:	207187 Click image for larger version
factory is offline
Old 31st May 2020, 1:56 am   #13
Mr Etronic
Yours looks pretty damn flash.
Old 31st May 2020, 3:49 pm   #14
Herald1360
Herald1360's Avatar
Andy.
So it is. Had to peer closely though- it says .1 OHM in the bottom RH corner
....__________
