25th May 2020, 9:28 am | #121 |
Re: Superstar 6900N V6 - Fault with SSB mode
I am beginning to think that the original matched pair fitted in this radio had a VT towards the very high end and the bias was set accordingly, so whenever you fit a pair with average or low VT the original bias setting is turning the outputs on too hard.
I would imagine the 'right' bias voltage for any single device is somewhere above its 'VT' because otherwise the device would not be turned on (biased) at all, but the higher it is above VT, the harder the devices are turned on and the greater the standing current. How about this for an approach: While the devices are out / disconnected, turn the bias down to the lowest it will go (and verify that that is the case by measuring the gate pad voltages, so you know you have turned it all the way down and not all the way up - sometimes controls work in the opposite direction to the way you might expect). Take an output pair which are well matched according to the tester, fit only -one- of them, remove L10 and insert a multimeter on its 10 amps range in place of L10. Put the radio into SSB TX, power turned fully up, no audio drive. With the bias set to minimum the fitted device should not be turned on, no current flowing. (There may be a tiny current being drawn by Q12 and its surrounding components). Carefully increase the bias preset until the current first starts to increase and then keep going until the current being drawn is 1 Amp. Try to do this in a fairly short space of time because you need the device to stay cool. Let it it cool down for a while, check that the current is still 1A, readjust if necessary. Then, fit the second output device in the second position and measure the current again. If the current being drawn is now about 2 Amps, the devices are as well matched as the tester says they are. If the total current is noticeably less than 2A or noticeably more than 2A, they are not well matched. If they do seem to be well matched, you can then go on to set the final combined current to whatever everyone agrees is a good likely value. |
25th May 2020, 10:08 am | #122 |
Edit: I've just read what mike w said in #111, for some reason that post was not visible to me earlier. Maybe it was edited after I originally read it. Agree that devices with VT of ~1.9 or whatever would suffer if put in the radio if the bias was not then readjusted from its current rather high level of about 3.7V.
25th May 2020, 10:31 am | #123 |
Found this thread on Tranmission1 https://www.transmission1.net/viewtopic.php?t=30718
What do you think of the process in post https://www.transmission1.net/viewto...434a00#p267180 Mike |
25th May 2020, 10:45 am | #124 |
If you mean the one where it says just set the bias voltages to certain fixed values, I don't think that is good enough because there is such wide variation in the VT figures between individual devices. You really will have to set the bias specifically to suit whichever pair of matched devices you fit. Consider trying the approach in #120?
25th May 2020, 12:07 pm | #125 |
25th May 2020, 12:20 pm | #126 |
100mA sounds low for a pair, maybe that's a 1W rig, or it is meant to be a lot closer to Class C than Class A bias.
Certainly the IRF510 is stable at about 100 mA. In the absence of any definitive current figure there are only 2 options: 1) Calculate what seems like a reasonable DC standing current for AM high power. 2) Start at minimum and increase till 2nd Harmonics or distortion is just gone, but in any case less than the current in (1). You have to do something like this for the Driver anyway as we don't know what power it should be. Likely it's the same or slightly lower current. Setting gate to a particular voltage is never going to be right. |
25th May 2020, 12:59 pm | #127 | |
As you seem to prefer to set the bias in AM TX mode, can you outline the process, step by step, in terms that crackle can follow, bearing in mind the limitations in terms of available test gear? I don't think he has a spectrum analyser, for example, but he might be able to observe the shape of the RF envelope on his scope (to look for distortion on AM). |
25th May 2020, 1:02 pm | #128 | |
But if someone can come up with an easy to follow numbered step by step guide, without too much background information and history that would make it much easier for me to follow. Thanks Mike |
25th May 2020, 1:07 pm | #129 |
I understand that. If only we knew someone who had a working one of these we could ask them to make measurements. Anyone got one, with a V6 chassis?
25th May 2020, 1:26 pm | #130 |
The scope will filter off distortion. I thought of that. You need at least a 100MHz scope that's still good at 120MHz to see much distortion of 28MHz. It's a 15 MHz scope.
I suggest AM because: 1) Gross distortion due to 2nd harmonic (clipping, think full wave rectifier gives lots of 100Hz from 50), will be obvious on an Air band receiver, (carrier x 4). 2) We know AM is 50% efficient at best, in Class A. Thus for a recommend power and 6V supply (the series regulator is AM modulator so must sit at about 1/2 supply), we know the maximum ideal current is an upper limit. 3) FM high power is logically x4 the AM power. 4) SSB by default has no carrier, no drive to FETs, this is more unstable for parasitic oscillation, fortunately when we were restoring the 200W Racal military HF sets we had a good few spare transistors included with all the other spares. For O/P or Driver current measuring: Lift one end of the RF chokes that are wire links in ferrite tubes, judging from the photos. Tack 1nF ceramic there to a nearby earth with short leads. We don't want RF in the test meter! Twist test meter leads. The calculated (2 x AM Power)/(PA stage supply volts) is an absolute maximum. The driver stage maximum is 1/2 this, likely less. Start at minimum gate volts, no you can't measure it without a probe that blocks RF!, max resistance of pot. Increase till the harmonics reduce, but not more than the calculated maximum. I'd guess the real current setting is maybe 50% to 80% of the theory for Class A AM at that power and voltage. Do they even claim any level of out of channel emission? The driver maximum current has to be no more than (output stage current)/2. Again start at minimum and increase to reduce distortion / harmonics, up to the maximum. Maybe GDO/ Dip Meter in passive receive only mode set to 56 MHz would help. Or a 56 MHz tuned circuit feeding an RF peak detector. Adjust either of those for maximum when o/p currents are at minimum. |
25th May 2020, 1:34 pm | #131 | |
Also there is no assurance that a one owner from new was correctly set in the factory or hasn't drifted, or a S/H one wasn't twiddled earlier. Measuring one example of something isn't as reliable as theory. |
25th May 2020, 8:48 pm | #132 |
Ok here is where we are now.
The radio is back together and working on all bands. So it just goes to prove the theory about the OP pair of IRF520 mosfets going into oscillation. I found a document online https://www.youscribe.com/BookReader...mentId=3249959 The relevant page in question is this one, which I have included here in case the other link disappears. Superstar_6900_V3_TX_adjustment.pdf I fitted the MOSFETS back into the radio but left out the 2 links L11 & L10. With the jumpers J3 & J4 refitted, switched to USB and keyed the mic. I set the driver bias to 3.8v and the output pair bias to 3.6v. I refitted the 2 links L11 & L10 and the final readings were slightly different across the different modes. All were measured with no audio signal. Driver Bias whilst working AM, FM, & SSB 3.8v OP pair Bias whilst working AM 3.77v FM 4.55v SSB 3.6v The final results and test transmissions gave good results, power on FM was 38 watts, AM about 10 watts, USB about 12 watts. It would seem there is a little scope for further adjusting of some of the other settings, but as I dont have a 13.8v PSU or specialist analysing equipment I will probably leave things as they are for now. The chassis and heat sinks do not seem to be getting quite so hot now. Just as a note the TIP36 supply to the transmitter voltages are as follows, bearing in mind my supply is only 12.3v AM 6.1v FM 9.91v SSB 11.64v I would like to say a big thank you to all who helped me, especially Graham, David and Mike W. Mike. |
25th May 2020, 8:53 pm | #133 |
I have just had the following reply back from RP Comms, I asked them if they had any specific information about setting the bias for the 6900 v6.
Hi Mike I used the Galaxy\Ranger IRF520 notes http://www.cbtricks.com/miscellaneou...ssb_mosfet.pdf check psu set 13.8VDC Turn Mic gain to zero before proceeding Set AM mode Driver 3.8V DC on Gate PushPull pair each one on Gate 3.6V DC (Gate) after test check AM clean with test tone 85-90% Mod 1khz test tone PDF sheet link handy Kind Regards Rob |
25th May 2020, 9:10 pm | #134 |
So simply a matter of bias setting after all?
I'm glad you have it working and to be honest it sounds like you eventually arrived at a solution more or less by yourself. I've noted the documents you linked to, and thanks for making a note of the specific bias voltage settings which worked for you. As a matter of interest, what current does the radio now draw when in SSB TX mode but with no audio drive? |
25th May 2020, 9:24 pm | #135 |
Hi
On TX with no audio it draws 0.5 amp rising to nearly 6 amps with a loud whistle. That is showing as just over 25 watts of RF on my power meter. (suspect accuracy) Mike |
25th May 2020, 9:33 pm | #136 |
Ok that's great, I'll file that away for future reference. Don't know if you got it working in time but there has been a bit of summer skip ongoing today, heard a lot of continentals coming in on CEPT / Midband today even up to mid-evening. (All this working on your radio inspired me to fire up one of mine).
25th May 2020, 9:36 pm | #137 | |
Full supply volts to the drain feeds for SSB is right. About 50% supply volts on AM allows it to get up to 70 or 80% modulation And the FM mode somewhere between the two is good, because FM is constant power while AM and SSB have peaks. On SSB and AM the voltages and currents have to peak at what it takes to make the peak power, but the average is lass than this, but FM power has to be throttled back to keep the heat within the capabilities of sinks designed for AM and SSB. David
25th May 2020, 9:38 pm | #138 |
Yes the skip was interfering a bit with my USB tests to a friend the other side of the Thames in Rochester.
I am planing to compile all those images on that web site link into a PDF I will send you a copy if you wish, at the moment they are all individual images. Thanks for your help and patience. Mike |
25th May 2020, 9:42 pm | #139 | |
25th May 2020, 10:19 pm | #140 |
Thanks,
If the PDF comes out small enough to attach to a post here, please do that and then anyone who surfs onto this thread looking for information about these will be able to find it here. It may save other people a lot of time in future. |
