Reply
Old 17th May 2020, 4:32 pm   #21
pip5678
Default Re: Quiet or no dial tone in a GPO 706
Originally Posted by Sparks View Post
Sorry pip and Dave. This is the bit where my lack of tech savvy comes in. Whereabouts do I need to be placing my probes to look for these values and continuity ? Also, is the induction coil the thing in this picture below ? Thankyou.
Yes that's the one, I haven't got a 706 to hand but you should be able to trace the wire from T1 to the coil tag 3 (probably numbered on the coil) and if you can find tag 2 you should see the winding resistance between them which says 6Ω on the diagram. Tag 2 goes to to R1 which should be 150Ω and the other end of that goes back to T2.
So to recap put one end your ohmmeter on T1, find tag 3 on the coil, this should be 0Ω to there then go to tag 2 should be c6Ω follow the wire on tag 2 to R1 it should read the same, then go on the other side of the resistor another 150Ω in addition. Leave your second probe there on the resistor and move your first probe from T1 to T2 should be 0Ω.
Phew I hope this makes sense.
pip5678 is offline   Reply With Quote
Old 17th May 2020, 4:33 pm   #22
Sparks
178 ohms Wayne. I am getting this reading with the switch on OR off.
Sparks is offline   Reply With Quote
Old 17th May 2020, 4:50 pm   #23
Sparks
Pip, hope I understood.
T1 to coil Tag 3 is 0.5 ohms
T1 to coil Tag 2 is 6.1 ohms
Coil Tag 2 to R1 (left hand side) is 0.5 ohms
Coil Tag 2 to R1 (right hand side) is 173 ohms
T2 to R1 (right hand side) is 0.5 ohms.
Old 17th May 2020, 5:10 pm   #24
pip5678
That sounds ok, better than we got before 'T1 to T2 is open circuit with the handset disconnected.'
I'll stand down a while as Wayne is giving some good advice and I don't want to cause confusion or duplication.
Old 17th May 2020, 5:11 pm   #25
Sparks
Thanks pip.
Old 17th May 2020, 5:27 pm   #26
WayneL74
As Pip says all those readings look good.
There are 2 final parts of the ASTIC we haven't tested. Can you please test pins 1 & 2 and then 4 & 5. Do this with the switch hooks down & the regulator board removed
WayneL74 is offline   Reply With Quote
Old 17th May 2020, 5:41 pm   #27
Sparks
Pin 1 to Pin 2 is 8.1 ohms
Pin 4 to Pin 5 is 20.3 ohms.
Old 17th May 2020, 5:53 pm   #28
WayneL74
That's good. That means the ASTIC is fine.
Can you put the regulator back in"upside down" as it were. This is so we bypass all the compnecnts on there should there be a problem.
Then can you test from T19 to T3. Should be around 22 ohms
Old 17th May 2020, 6:03 pm   #29
Sparks
I'm getting nothing between T19 and T3. Whether I have the switch on or off or whichever probe is on which terminal, the display on the meter doesn't change from '1'.
Old 17th May 2020, 6:17 pm   #30
TonyDuell
OK, you do have the regulator PCB fitted in its socket 'upside down'. That is with the end that connects the 3 middle contacts on the socket with a simple PCB trace in the socket.
Connect one multimeter probe to T19 and leave it there.
Put the other probe on terminal 4 of the ASTIC. Should be 0 ohms or close to it (this checks the gravity switch contact and associated wiring).
Move the probe to terminal 5 of the ASTIC. Should be 22 ohms (this checks the ASTIC winding, even though you've already done so)
Move the probe to that PCB trace on the regulator that I mentioned. Should still be 22 ohms (this checks the wiring from ASTIC pin 5 to the regualtor terminal C).
Move the probe to T3. Should stll be 22 ohms (this checks the wiring from regulator termnal B to T3).
TonyDuell is online now   Reply With Quote
Old 17th May 2020, 6:26 pm   #31
WayneL74
Hi Sparks.
Sounds like it could be the regulator or its wiring.
Can you just confirm it is fitted as per the attached photo?
Old 17th May 2020, 7:12 pm   #32
Sparks
Wayne and Tony. I confirm the regulator is fitted upside down.
T19 to Pin 4 of the ASTIC is 0 ohms. All the other readings Tony asked for are also 0 ohms. As per my post 29, the meter doesn't change from '1' at all.
Old 17th May 2020, 7:22 pm   #33
WayneL74
Can you try from T3 to terminal B on the regulator connector - This is the 2nd one from the left.
Old 17th May 2020, 7:23 pm   #34
Sparks
I have just swapped regulators with my other 706 and there was no change with either phone. The existing one is as good as ever, the newer one with its known faults.
Old 17th May 2020, 7:26 pm   #35
Sparks
Wayne, 0.4 ohms.
Old 17th May 2020, 7:30 pm   #36
WayneL74
OK measure from the regulator connector C (the centre one) to pin 5 on the ASTIC
Old 17th May 2020, 7:38 pm   #37
Sparks
0.4 ohms again. I'm just going to have some dinner now so I'll look in again soon. In the meantime thankyou enormously for your help.
Old 17th May 2020, 8:00 pm   #38
WayneL74
Hi Sparks.
There is something not quite rights here.
You said there was no continuity from T3 to T19, but since then we have proved there shoud be as we have tested each stage one by one.
Can you try the following with the regulator in upside down & the switchhooks up:
Hold 1 probe on T3. Hold the other probe on regulator contact B, then move it to regulator contact C, then to ASTIC pin 5, then to ASTIC pin 4, then to T19.
You should get continuity all the way, with the resistance increasing as it goes.
Old 17th May 2020, 8:11 pm   #39
Sparks
I'll give that a try shortly Wayne and come back to you.
Old 17th May 2020, 8:25 pm   #40
Sparks
T3 to Regulator B is 0.5 ohms with continuity
T3 to Regulator C as above
T3 to ASTIC 5 as above
T3 to ASTIC 4 is 20.2 ohms with continuity
T3 to T19 is still absolutely nothing. Apart from the straps from T19/18/17/16, the only connection from T19 is a green wire going to a (I think) capacitor.
Reply
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
