2nd May 2020, 5:41 pm | #21 |
Re: HP8640B Signal Generator
As regards the allen key sizes, 1.27mm is exactly 0.050" (50 thou). In fact I think the smallest 3 (common) imperial Allen keys (0.028", 0.035", 0.050") are the same as the smallest 3 metric allen keys (even if some companies sell both imperial and metric versions under different part numbers!)
2nd May 2020, 8:36 pm | #22 | ||
I took the easy solution & ordered the brass gears that an ebay seller was making, only problem is I haven't got round to fitting them yet. I did think about getting standard brass gears & brazing them together, but I seem to remember the cost was similar or more than the ready made set. Note: they cost more than your 8640 including shipping & fees from India, ebay listing https://www.ebay.co.uk/itm/153024403695, the seller is currently away, it's probably best to fix the other problems first anyway. David Last edited by factory; 2nd May 2020 at 8:47 pm. |
2nd May 2020, 10:49 pm | #23 |
Check your output amp is OK before spending much.
Those gears look gorgeous! David
3rd May 2020, 10:50 am | #24 |
Location: South coast near Ringwood/Christchurch, Dorset, UK.
My gears look exactly like those David (the plastic ones with splits!).
I still need to remove the attenuator and tuning knobs before I can proceed, but someone has been there before me. Other gears (eg tuning) are also splitting. I could close the cracks and glue thin washers to the back surfaces but maybe this has to be done in-situ as dismantling might result in more damage. I suspect the tuning gears have been forced and jumped a tooth or three which might explain the reluctance of the knob to turn more than about 450 degrees. Maybe the two round devices geared to the tuning have reached their end stops? Today, I'm going to fix the bridge rectifiers. I reckon the original diodes might be equivalent to the 1N4999 3A 200v. Some (but not all) fixing holes are about 1mm dia so I need to work out how to fit 1N5408 diodes (I have a bag of those with 1.3mm dia legs) that should just about allow the board to fit back in place. If 5 diodes are duff (3 open circuit and 2 with high forward drop) you'd expect other equipments will have the same fault? If I can see an RF signal it will make further effort worthwhile so cross fingers. Allan G3PIY |
3rd May 2020, 2:22 pm | #25 |
Progress has taken a step backwards so not too good at present.
I repaired board A12 with new diodes, fitted it and saw all zeroes in the display. Switched off and read up on all zeroes on the display and decided to check the 5.2 volt supply because one red lamp was dimmer than the rest. Plugged in the kettle lead and was just about to switch on when there was a flash and a loud bang. The 1.25A fuse was completely black. The mains switch is in the off position but works normally. Fitted a new 1A fuse and measured the input with an ohmeter. Around 10 ohms with 250Kohm to ground. Checked the voltage setting pcb. This is in the 240v position and is OK. Looks like the mains filter has shorted to ground leaving a leak. Mains measured at 249.5 volts. I hadn't fitted a new C6 yet. It looks like the mains input assembly is held in place by stainless steel clips? One set accessible the other hidden by the PSU motherboard. Allan G3PIY |
3rd May 2020, 2:34 pm | #26 | |
The A12 rectifier board has different parts listed depending on the age of the unit. The older 1974 manual lists all 20 diodes as being 1901-0418 (SR1846-12) rated at 400V 1.5A. But the later 1991 manual gives 16 diodes (CR1 to CR16) as being 1901-0693 (1N4934) rated at 100V 1A & the last four diodes (CR17 to CR20) as being 1901-0662 (MR751) 100V 6A. David |
3rd May 2020, 2:49 pm | #27 | |
David |
3rd May 2020, 4:07 pm | #28 |
I managed with a lot of levering to detach the filter/mains setting panel. The leads are very short and the whole thing is enclosed in a pop riveted metal cover.
The easiest solution is to fit a new panel with an IEC connector (maybe with a built-in filter if I can find one in the junk box) and fuse and to hardwire the transformer tappings, back at the tags on the transformer, for 240 volts. My A12 board has 20 identical diodes which I think are 1N4999. Allan |
3rd May 2020, 4:28 pm | #29 |
I've got one of those line connectors in the spares box (part no #0960-0443), never realised it was a line filter too, most of the connections unplug apart from the three mains wires.
What is the HP part number on those diodes? neither of the two manuals I've looked at have 1N4999 as the part, but it is in the same package style as those, just higher rated (except the four 6A diodes used in the 1991 version, see previous post). David |
3rd May 2020, 5:10 pm | #30 |
There appears to be at least three versions of the A12 rectifier board;
SN prefix 1229A to 1249A uses 08640-60003, this is the oldest & has a crowbar circuit across the first bridge rectifier. Yours uses 08640-60326, no idea which prefix range they cover as two free PDF manuals don't mention this part, the crowbar components are not present but the parts are still labelled on your board. SN prefix 2520A to 2923A uses 08640-60375, this is shown in the 1991 manual, it does away with the can style diodes for more modern ones, the 1991 manual also has a mistake as it shows 08640-60326 on the circuit diagram. With most HP stuff you really need the correct manual for the SN prefix of your unit, it can sometimes cause problems & confusion if you don't. David |
3rd May 2020, 5:20 pm | #31 |
I decided I'd nothing to lose removing the pop rivets David.
Inside the case is a small ferrite ring wound with a few turns for live and neutral wired to the two feed-through capacitors (those brown things sticking out the case). One of these had broken down. I put the C6 failure and the filter failure to the use of 250 volt working components. My mains supply can be well over 250 so the plan now is to solder wires direct to the mains socket connections, add a couple of decoupling capacitors, and run a pair of wires through the holes left by the feed throughs to an external mains filter using better filter capacitors. Self tapping screws in place of the pop rivets. It saves messing with the transformer wiring and leaves the voltage selector intact. cheers Allan |
3rd May 2020, 5:29 pm | #32 |
That explains why it went bang then.
The RIFA capacitors don't fail for that reason, they fail because they are metallised paper in an epoxy case, the two materials expand at different rates, ageing then causes the casing to crack and moisture can get to the paper part, a few decades later they turn into a horrible stink-bomb. A forum search for RIFA Y, X or X2 capacitor should find lots of threads about these crap capacitors. Always check for them before powering up old equipment. In my 8640B, a previous owner let the smoke out of this one; David |
3rd May 2020, 5:59 pm | #33 | |
I'm sorry you are having a torrid time of it getting the old girl up and running. I got some replacement brass gears from a guy in the USA who regularly posted on the HP forum when it was on Yahoo. That was quite a while ago. They moved the forum to groups.io but I've no idea if the chap is still able to offer new gears. https://groups.io/g/HP-Agilent-Keysi...pment/messages 73, Alan G3XAQ |
3rd May 2020, 6:42 pm | #34 |
Favourite thing with a disappointing display on an 8640 was the external 10MHz ref switch being knocked into the ext position when someone carrying the thing slipped a hand round the back for extra support. Amazing what hyper-intelligent pan-dimensional beings got caught out by that one
Most 8640 electronic problems are in the power supplies. David
4th May 2020, 10:43 am | #35 |
I managed to replace the filter feed-through capacitors with ceramic feed throughs and fit a pair of 400VAC filter capacitors external to the filter and refitted the assembly. All told a really horrible job.
Removed the plug-in 2N3055 and cleaned tarnish/corrosion from its legs and refitted it. Switched on and saw all zeroes (again). Checked the voltages which were all respectable. Pressed various buttons and the bottom left of the group of six (without a label) resulted in a numeric display. As the top section of the panel wasn't fitted I hadn't spotted it said INT/EXT. The limited rotation of the tuning knob gives me a reading 3352 to 4168. Almost as if the last owner had been using it on the 80m band before it expired?? The knobs except tuning and attenuation are detached so its not easy to check the range switch setting and that shaft is very stiff so I refrained from forcing it. The meter reads zero but turning off the 8640 makes the needle jump so the movement is OK. Progress! Allan |
4th May 2020, 12:20 pm | #36 |
Ah, that's the int/ext input for the counter to count. On the back panel is a little toggle that switches the counter gate from the internal crystal reference to an external one. Flipping this is more subtle to find than the one on the front panel. But that's good it's counting.
Proves the cavity oscillator and dividers are going. David
4th May 2020, 1:20 pm | #37 |
A few faults to sort out.
I'm a bit concerned about the zero meter reading in the RF position and very little reading in FM settings. The AM mod switch is seized with the lever not engaged but that probably isn't important yet.. If I turn the range switch the frequency reading doesn't change it stays at 04168x with x variable with fine tune. When the tuning knob is turned clockwise it stops dead and you can see all the plastic tabs lined up. fuzzy picture-sorry As the knob turns anticlock the back edge of the first tab blocks further movement after something a little more than one revolution. slightly better picture...Is it just a case of it being forced in the past? Frequency changes from 4168 to 3352 (or vice versa... I can't remember) Allan |
4th May 2020, 1:56 pm | #38 |
Just to mention that on mine, the output level is only indicated when the 'RF output' switch is operated (adjacent to the output N-type).
"What a depressingly stupid machine." [Marvin: HHGTTG] |
4th May 2020, 2:31 pm | #39 |
That switch is very rough but it does actually work and still no reading on the meter.
I'll see if I can trace where the wires go from the switch I thought I'd check the RF output and the thing delivers a nice sinewave at 4MHz at about 5volt RMS and the attenuator is OK, so the RF output must be working... Allan Last edited by allan; 4th May 2020 at 2:49 pm. |
4th May 2020, 3:10 pm | #40 |
Working RF output is brilliant.
Does the frequency coming out tune with the main tuning control, and does it change when you move the range switch? David
