Old 1st May 2020, 2:34 pm   #1
KW2000A
Default Ancient Miele Dryer
Greetings all
Having a senior moment. This is an ancient Miele dryer which has ceased to power up. There are two thermostats in the heating element tray. On the attached picture the left hand one is the 140 degree sensor....simple 2 connection switch. I have a spare. The RHS sensor has three connections....two are temperature switched but what is the third ( brown) connection? It seems not to change state when heat or cold are applied. Naturally I do not have a spare and the part number is illegible
Many thanks!
KW2000A is offline
Old 1st May 2020, 9:12 pm   #2
Joe_Lorenz
Default Re: Ancient Miele Dryer
Hello,
do you know what was connected to it? Do you have a model #? This might help. Three connections indicate it is a COM-NO-NC arrangement.
Regards, Joe
Joe_Lorenz is offline
Old 1st May 2020, 9:30 pm   #3
IanBland
This is probably a stupid comment, but is it a changeover switch with a common terminal?
IanBland is offline
Old 2nd May 2020, 10:59 am   #4
KW2000A
Many thanks.... your replies focussed my mind that it could only be a changeover arrangement. And so it is. What was that about short term memory?
Mods: with thanks this thread can now be closed. All stay safe!
KW2000A is offline
