17th May 2020, 10:51 am | #161 |
Re: Recreating the Bywood Scrumpi
Why is it when you look at something you notice it is wrong - the board is wired correctly I just drew it wrong - here is the detail of my use of the three position switch: I.e. the Center (R/W and Pullup) connects to neither (in the middle) one side to GND (when pushed DOWN in reality) and one side to NWDS.
17th May 2020, 11:01 am | #162 |
Hopefully the above helps - one thing I did notice when I was routing the Flags and Serial is that the Serial is the wrong end on the LED's - I think maybe a trace must go under the CPU behind F1 and F2 and under the link from F0 to present it that end... You had not got that far on the last one you showed. I am getting this layout from the Box picture at SunMoonStars and its labels. He labels it as SENSE which did not make sense (no pun intended). As SENSE A is interrupt I wondered if he showed the status of the SA switch there? Can't see how to route it though looking quickly as it would have to cross the data bus - so I am sure he just labelled it wrong.
17th May 2020, 2:08 pm | #163 |
send me a too vague not clear schema and the switch enable has changed?
17th May 2020, 2:12 pm | #164 |
No the wiring on the original is correct that is just ME on my veroboard - just use the one from the original DJD article so that PROTECT and LOAD switches are as original - that design is unique to my Prototype
17th May 2020, 2:14 pm | #165 |
On the circuit above the Pin numbers hand written in RED are the ones for the PCB - the black ones are the ones I used so ignore.
17th May 2020, 2:42 pm | #166 |
You are correct it is messy - here is what I think is the final labelled diagram for the PCB version with the correct Pin numbers
18th May 2020, 12:13 pm | #167 |
Hello
to finalize our restoration it would be necessary to write a notice of use can you take care of it the pcb is being completed |
18th May 2020, 6:16 pm | #168 |
I had been thinking I would write a manual and short technical history - I will see what I can do!
19th May 2020, 7:19 pm | #169 |
I presume in your diagram the top end of R3 is connected to pin 5 of the 555 (CHARGE)
19th May 2020, 8:44 pm | #170 |
No it is connected to pin 4 and 8 as in the label. Pin 5 CTRL has a small capacitor to Ground although that seems to be absent on the schematic from DJD or indeed on the board. I have put one on mine.
19th May 2020, 9:30 pm | #171 |
Ah sorry I didn't read the label as being associated with the resistor.
20th May 2020, 11:31 am | #172 |
a picture of the pcb still some modification
20th May 2020, 7:01 pm | #173 |
Looking really good - perhaps a little cramped above IC5 to put the links across? The real board has more room as IC2 is in line with the switches so IC1 can move over a little bit. I assume you have yet to add the Data Bus holes in line with the address ones (as I can see the ones around the IO chips are also yet to be added).
You will have finished this soon. I am doing well on a support document but, I wish I could fix the memory write problem... my 2112 chips are still "stuck in transit" according to FedEx... |
20th May 2020, 10:13 pm | #174 |
Hello I correct it is a long work all by hand without highway keeping the spirit pcb artisanal of the time rounded tracks brief that of the cosmetique
I also have to replay the pcb on kicad because the text is not in the right direction see SCRUMPI upside down and the switch text good I must also thicken the tracks more work to do |
20th May 2020, 10:19 pm | #175 |
Yes I am in awe of the work you are putting in to draw this PCB as so authentic - it is a massive amount of work on your part and really appreciated that you want such attention to detail.
Hopefully we can make a good manual and programming guide to go with it once I get my memory working. Here is a draft of the booklet see what you think. TheSoulOfAnOldMachineDRAFTv0.pdf |
20th May 2020, 10:51 pm | #176 |
21st May 2020, 8:57 am | #177 |
hello thank you for it is compliment your document is very very good nevertheless be more impersonal a forum is a sharing of other read our discussions and interested in our creation
soon in a second part we will attack the scrumpi 2 |
21st May 2020, 9:02 am | #178 |
more work
21st May 2020, 9:18 am | #179 |
really great this document
verified the list R4 R5 reversed see photo 74c04 or 74c07? I received the memory AM9112 I wait for the switches and led with resistance included may be that this virus ..... had served to bring men closer together |
21st May 2020, 10:12 am | #180 |
It has certainly given many people more time to spend on interesting projects like this.
Tim, very nice draft document but I have barely been involved in this thread so you can probably remove me from the 'credits'. This is definitely your and Phil's 'baby', with useful contributions from Slothie. All I've done is grumble about how primitive the system is. Looking forward to seeing the finished article though. Last edited by SiriusHardware; 21st May 2020 at 10:38 am. Reason: Spelling Mitsake |
