Old 2nd Jun 2020, 5:28 pm   #261
Timbucus
Default Re: Recreating the Bywood Scrumpi
Wow looks good - those switches will be a bit small for you! If Sirius is happy with that then so am I.
Timbucus is offline
Old 2nd Jun 2020, 6:30 pm   #262
SiriusHardware
Hello Phil - I am sad to say that there is no room in my life for a Scrumpi at this time but I appreciated the offer, thank you.
I will send another one of the Slothie PCBs to Tim and then he can swap it with you for one of your Scrumpi PCBs, if that will suit everybody?
SiriusHardware is offline
Old 2nd Jun 2020, 6:42 pm   #263
Timbucus
Sounds like a great option - Phil - there will be a PCB on its way to you if you PM your address - will be nice to have another MK14 user around here...
Timbucus is offline
Old 2nd Jun 2020, 7:19 pm   #264
philoupat83
ok thanks friends I have good news for the scrumpi 2
and look at this article
philoupat83 is offline
Old 2nd Jun 2020, 7:52 pm   #265
Timbucus
Originally Posted by philoupat83 View Post
ok thanks friends I have good news for the scrumpi 2 and look at this article
Yes that is a great one (I have the ETI issue): Do you see it hiding:
But, it is for the SCRUMPI 3? I have been quietly working on reverse engineering that one as well. I have pretty much worked out the memory map (see below) and how the keyboard works and have built one for my SCRUMPI 1.5 (tm) breadboard to experiment with it.
I have already added an EPROM socket to my SCRUMPI 1.5 and an extra socket to start looking at how we can make the minor changes to re-create that one first. I assume the PROM content is lost but, we have some information from the 3 and notes I have gathered to make something very similar. I expect he used a lot of KITBUG as it was published.
I am still trying to get the circuit diagram for the VDU section from the journal article I bought (at significant cost) but Elsevier are giving me the runaround. But, I have started to work out the component list form the description - it is all rough notes at the moment but, I will tidy it up and publish what I have. Slothie seemed interested in helping reverse engineer that VDU as it could be used on an MK14 as well...
Code:
Memory Map - from various sources:
0000-01FF - Monitor PROM (the first 48 bytes are visible in the screenshot in the manual pages...)
0000 3F C4 7F 36 C4 90 32 C4
0008 77 37 C4 DC 33 3F 01 53
0010 43 52 55 4D 50 49 20 33
0018 0D 04 C4 77 37 C4 DC 33
0020 3F 0D 43 4F 4D 4D 41 4E
0028 44 3F 20 04 C4 76 37 C4
Bywood Leaflet says PROM A holds:
PUTVDU - which also does scrolling
The software drivers only implement 32-127 and 01 CLS, 08 Backspace and 0D CR/LF
GETKBD - scans keyboard and INT keys - branches to PUTVDU
PUTTY and GETTY for TTYIN and TTYOUT connectors using Send B and Flag 110Baud 20mA - likley from KITBUG
PUTART and GETART for serial I/O on the UART at 960 Baud (as the 15.625KHz clock is used)
Article mentions 8 I/O routines listing these (ass:
Display message
Display accumulator as HEX number with or without trailing space...
Read a hex number from the Keyboard.
Four bytes from user stack to display a six digit number with SIGN.
It says they can be entered by exchanging the program counter and pointer 3????
0200-03FF - This must be the two empty slots on the right of the board...
Monitor will detect if there is a PROM here if it reads a 00 at 0200
A disassembler PROM was also available from BYWOOD to expand the system.
0400-05FF
0600-07FF - User IO PROM routines (must be the right most PROM)
I assume the displayed image from 77D0-77F8 represents a Ghost of this PROM as well...
77D0 E0 9C F3 C4 De? C9 00 C2
77D8 FD 31 90 87 3F C7 01 C4
77E0 77 37 35 CA FE C4 68 33
77E8 31 CA FF C5 01 3F C1 FF
77F0 E4 04 9C F7 C2 FF 31 33
77F8 C2 FE 35 37 C7 FF 90 DC
Bywood leaflet says PROM B is:
G xxxx - GO execute
H xxxx - HEXDUMP
I xxxx - IMPLANT displays the address and data , INT will move to following add
=n (0-7) will store lowest two chars (a byte)
?n will provide the two characters (byte) back calculated as an offset from where you are
> return to command mode - or hit reset... {{{ WHERE IS RESET BUTTON ? }}}
L      - Display the 8 label bytes
Breakpoints use XPPC 3
C continue from where the last breakpoint was.
0800-09FF - RAM expansion Space as in the 8 chips to the left of the PROM area
0A00-0BFF
0C00-0CFF - Keyboard
The User key is mapped to Bit 7 of the keyboard port at 0C00
Note that the INT key is mapped to SC/MP SENSE A (software decode as X'0D'.)
64 chars can be generated with the 19 keys 16 main + 3 shift so I am going to
guess that
7    6     5     4     3210 (Lower four are a ROW but will be wired backwards...)
User Alph1 Alph2 /Func 0-15
0    0     0     0     0000-1111(0-15) - this should be 30-3F i..e 0011 in upper
The primary keys are 0-? (48-63, 30-3F) - (i.e. 0011) the review moans it should be 0-9,A-F!
With Alph 1 I guess  @-O (64-79, 40-4F) - (i.e. 0100)
and  Alph 2 I guess  P-_ (80-95, 50-5F) - (i.e. 0101)
then Func would do  SP-/ (32-47, 20-2F) - (i.e. 0010) - could hw pull down a high on d4?
which could be done by grounding one of the buffer chips held high...
This bit trick is used on ASCII keyboards for setting lower case in the 60-7F range...
This must be used with address lines to scan each key row with the shift keys just
direct connected.  We could do the Bit changing in software (which is implied by the article rather than using gates to make the keys do stuff - there are two chips next to it though perhaps one is a buffer as it is quite big.)
0D00-0DFF - UART... 16x Clock derived from 15.625KHz VDU making it 960 baud
I am going to hazard a guess he uses the S68 STTY card decoding regime that places the
signals on consequtive addresses using A2-A0
00 - READ DATA from UART
01 - READ STATUS from UART ( 5-7 unused, 4 DAV, 3 TBMT, 2 Over, 1 Framing Err, 0 Parity Err)
02 - WRITE DATA to UART
03 - WRITE PARAMS to UART (7 Parity, 6 Stop, 5/4 No of bits, 3 Even/Odd parity)
04 - RESET DAV line on UART (just access to the address data ignored)
0E00-0EFF - VDU RAM (from photo of manual)
Memory mapped with 256 bytes 8 rows by 32 chars
Bit 7 is inverse - Black on White chars
A whole screen inversion can be done setting SC/MP Flag 0 to Logic 1.
0F00-0F7F - This will be the std INS registers
I/O Ports
  00-24 are control registers
    00-07 - Clear BIT port A
    08-0F - Clear BIT port B
    10-17 - Set BIT port A
    18-1F - Set BIT port B
    20 Read/Write Port A
    21 Read/Write Port B
    22 Port A direction register D BUS (ACC) to ODA (1 = Output, 0 = Input)
    23 Port B direction register D BUS (ACC) to ODB (1 = Output, 0 = Input)
    23 Port B Mode Definition Reg D BUS (ACC) to MDR
        7 6 5 4-0  (Port B Bit 7 Input, Bit 6 - Output to use this mode)
        x x 0 xxxxx - BASIC I/O
        x 0 1 xxxxx - STROBED INPUT
        0 1 1 xxxxx - STROBED OUTPUT
        1 1 1 xxxxx - STROBED OUTPUT WITH TRI-STATE
  25-7F undefined
0F80-0FFF - 128Bytes of RAM on the I/O chip
64 for User, 32 User Stack, 8 Bytes for Labels (I assume for the =n function in
the monitor for calculating offsets) and finally 8 bytes for the Monitor
The picture in the review shows:
SCRUMPI 3 STATUS DUMP
 P3   P2   P1  EX ST AC
0000 0000 0000 00 30 00
0FC8 F4 03 DC 0B 8B C4 8B 34
0FD0 FC 4A 74 8B 0F 84 87 F0
0FD8 D7 0B F4 0F 59 B6 FB D5
COMMAND ? ^
0FE0-0FEF	-
So I guess (from another comment that the user stack is shown - he says 32 bytes
but only 24 are visible and he has likely moved the memory pointer?)
So labels 0FF0-0FF7 ???
Guess: If he based the Monitor on Kitbug (likely as he retains the TTY code and method for compatability):
Top bytes are used by ROM monitor for register store for GO
FF9	 P1 High
FFA	 P1 Low
FFB	 P2 High
FFC	 P3 Low
FFD	 A
FFE	 E
FFF	 S
Timbucus is offline
Old 2nd Jun 2020, 9:28 pm   #266
philoupat83
great work have recognize the professional really impressed
in bywood ads a rom and sold as vdubug for the s68 can be it took information.
for power supply I ordered power supply SRW-65-4001 Chassis mount.
I followed marc. I would modify for -7v and -9v.
https://www.curiousmarc.com/computin...microprocessor
I also work on an eprom programmer mm5204
Old 5th Jun 2020, 10:30 pm   #267
philoupat83
hello
an interesting article on the scrumpi 2
File Type: pdf Practical-Electronics-1978-02_scrumpi2.pdf (2.71 MB, 88 views)
Old 5th Jun 2020, 10:56 pm   #268
Timbucus
hello
Nice find - I missed that when I went through them all... it seems that the PROM on the SCRUMPI2 was empty for your own use so we do not have to worry what we put in it!
Timbucus is offline
Old 6th Jun 2020, 8:42 pm   #269
philoupat83
salu tim
yes well seen can be KITBUG
or VDUBUG was proposed
power supply was forecast in -7v and -12v
the Eprom a 5204 I also work on a programmer of 1702 and 5204
Old 13th Jun 2020, 9:50 pm   #270
Timbucus
Well I received the Board from Phil (Thanks) so set about building it and a suitable PSU.
Struggled to work out why the PSU board started smoking (not connected don't panic)... I will leave finding the short as an exercise for the reader. I actually could not work it out at first and unsoldered half the bridge rectifier...
Anyway all tests seem to indicate it would work with IC2,3 and 4 in I could generate reset, single step and slow pulse running. D7 with RUN/HALT down is held HIGH and can be pulled low by the switch etc.
All the pins on IC1 socket test as correct and I get a rock stable +5v and -7.01v from the PSU. So I plugged in IC1 and all others except the Memory. On Power on all the data lines are lit but no address lines (I have only wired up two as the in line resistors on the LED's are a bit fiddly to make...)
anyway RESET does not create address one. D0-D5 are 5v high but, D6 and D7 look like barely 2v. No clock signal on the X1 line from the capacitor either.
Anyway 40 odd mins of head scratching and probing seems to have achieved little - then there is a 5v or so oscillation on pin 40 and pin20 - IC1 gets very hot and so do the two regulators. Seems it may be game over for this chip... maybe it was faulty anyway.
PSU and all other chips test fine once IC1 is removed. So I will check the wiring very carefully. It is of course complicated by the need to have made a switch board as I did not have any of the little mini PCB switches that would fit.
Maybe I need to order a few more SC/MP chips - that is assuming they are not SC/MP II that have been skimmed and reprinted... in which case I could be burning out good ones of those in pursuit of the SCRUMPI.
Timbucus is offline
Old 13th Jun 2020, 9:58 pm   #271
SiriusHardware
Was it one of the screw heads? (The short)?
I doubt that anyone would rebrand SC/MP IIs as SC/MP Is because the IIs are themselves quite valuable. It would make more sense to rebrand an ultra common 40-pin DIP IC of any sort, after all if you are doing something like that the last thing you care about is whether it will actually work.
Old 13th Jun 2020, 10:09 pm   #272
Timbucus
Nope - keep looking
Yes that occurred to me - the signals seemed to be as I would expect mostly so I suspect faulty as I am sure -7v and 5v would fry a normal 40 pin chip PDQ - it is of course the risk with these chips - in the last batch I had two bad RAM's as well and some 74LS32 that are actually 74HC32 - so not so bad. Still working my way through them as they are for various projects that are at different stages so hard to test some of them.
Timbucus is offline
Old 13th Jun 2020, 10:14 pm   #273
SiriusHardware
Bl**dy H*ll, all the tracks are shorted together at the end nearest the camera! In what world would that be a sensible thing to do? Where did you find that stripboard?
Old 13th Jun 2020, 10:16 pm   #274
Timbucus
Bingo... in my box of stock which dates back from the 80's in this case - was just the first one off the stack... I even ran some wet and dry over it as it was a bit tarnished. Just checked the last two in the packet are not like that.
Timbucus is offline
Old 13th Jun 2020, 10:18 pm   #275
Timbucus
Actually in this case I just cut some holes in front of the electronics and it is all one big ground plane now... seems pretty safe way to go.
Timbucus is offline
Old 14th Jun 2020, 7:29 am   #276
Mark1960
I was wondering if the sc/mp chip that Tim had problems with might be an ins8050 the nat semi version of the intel 8050 and not an sc/mp at all.
Mark
Mark1960 is offline
Old 14th Jun 2020, 9:41 am   #277
SiriusHardware
That's quite a good observation actually Mark, looking at Tim's last image in #271 I can't read the number on the IC but it is obviously a plastic rather than ceramic package. The only SC/MP I ICs I ever saw myself were in ceramic packages.
Googling INS8050 brings up a lot of hits for programmers which can programme those which implies that they have internal ROM, so obviously a different family of devices to the SC/MP - I assume they must be part of the same family as the Intel 8048/8049 etc.
Tim had his prototype working didn't he, but that was with an SC/MP II fitted I think?
Old 14th Jun 2020, 2:02 pm   #278
Timbucus
Mark
I think you are probably correct - I have a batch of them and they are marked INS8050 only - my fault, I extrapolated from the INS8060N alternate name on the ISP-8A/600N to find one...
That means I have a large number of unknown factory Mask programmed chips... I did say on other threads that this was an expensive hobby to make mistakes on.
Timbucus is offline
Old 14th Jun 2020, 2:03 pm   #279
Timbucus
Yes my prototype used an SC/MP II.
Timbucus is offline
Old 14th Jun 2020, 2:14 pm   #280
Timbucus
I think in order to proceed I will hack this card to use the SC/MP II as I am unlikely to find an SC/MP - this will at least allow us to confirm the PCB should work without risking Phil's original Ceramic one initially and allow progression to a finished PCB that could take the switches and maybe has a few little tweaks to allow the SC/MP II hacks to be done easier for people interested in building one.
Or maybe just finish the SCRUMPI II card as that is more useful with its EPROM anyway. I will await the view of Phil. Finishing a SCRUMPI 1 card seems useful in case some SC/MP stock turns up.
I am anxious to get onto the SCRUMPI 3 as its VDU looks like an interesting challenge...
Timbucus is offline
