19th Oct 2019, 2:31 pm | #1 |
English Electric cooker
This cooker was apparently installed in 1961 and was with the original owner until a couple of years ago. I acquired it for the princely sum of 99p on ebay, apparently in full working order, with the exception of the clock. It is unbelievably dirty, decades of Sunday roasts having left their mark.. Shame no one realised in all that time that the oven side and bottom panels simply lift out for cleaning!
In fact the whole cooker is beautifully 'modular' in terms of restoration. Every bit of it is removable in a remarkably user-friendly way. The glass oven door and main door simply lift off their peg hinges, the entire cooker top lifts off and the rings and elements simply unplug. All of this makes cleaning a lot less of a headache than it would appear on first inspection. Points of interest are the large 'flat' cooking ring and the heating elements of the oven, exposed when the panels are lifted out. No fan assistance here! The hob light is a nice period touch. Fluorescent lamps tended to be fitted a bit later on so I expect that this one will comprise one or maybe two 15w pygmy bulbs. Its so greasy I can't tell from the external appearance. Oddly this cooker was acquired whilst on a mission to pick up a slightly later 60s cooker (also English Electric) way down in Surrey. An ebay browse on the laptop whilst idling away an overnight stop in a hotel revealed this earlier model up for grabs in Leicester, a lot closer to home. So now I have two 1960s EE cookers at a total outlay of £5.99 (excluding travel expenses). Why do we do these things? It's all good fun! Steve |
19th Oct 2019, 2:34 pm | #2 |
Re: English Electric cooker
And some more showing the pluggable rings, oven with the panels out and finally the cleaned panels (the grimy one in photo 5 is the bottom panel shown afer a clean in photo 4)
19th Oct 2019, 3:03 pm | #3 |
Fascinating! Looks like you're going to need some cauistic soda to get rid of all that carbonised grease.
And I remember those 'flat' spiral elements - my parents had a somewhat similar "Revo" cooker in the 60s which used them - alas the outer jacket of one wore through with continuous heavy use, resulting in a Bang! a Flash! and downstairs being plunged into darkness until MEB came out to replace the appropriate supply fuse (we had 3-phase), followed by my mother demanding (and getting) a new cooker. |
19th Oct 2019, 8:42 pm | #4 |
I used to love those Smiths clocks when I was a kid. The way the red arc indicates the cooking period is a brilliant design.
-- Graham. G3ZVT |
19th Oct 2019, 11:39 pm | #5 |
Hi Steve,
I just knew when I saw the thread title that it must have something to do with you! I'm glad you have finally found not one, but two cookers! What are the chances of that? It's interesting to see the plug in elements- very novel idea. Have you tested each one with an insulation tester (Megger) yet? That's always the biggest problem with old cookers- leakage to earth in the elements. Hope they all prove to be OK as I guess you are planning to put this into daily use? Good luck Cheers Nick |
20th Oct 2019, 9:52 am | #6 |
Hi Nick
In truth this cooker is not the one of the two that I'll ultimately be using. I bought it to save it, as I had a feeling if it didn't make it's 99p opening bid it may be heading for the tip and that would have been a real shame. Alas I don't have a megger, just the previous owner's assertion that it all worked (in it's grim state) before being disconnected. Time will tell but there's an awful lot of cleaning to do first! Steve |
20th Oct 2019, 11:18 am | #7 |
Similar era to our English Electric 'fridge, only retired because the blue liner had cracked and was deemed a bit unhygienic.
Even an old 500 volt wee megger is well worth getting, and they are cheap. The chances are if you get two of the same spec. one of them will be either working or salvageable. I don't really know how i got on without one for so long. I would say that cooker was well worthy of being saved- partly because so few people are of the mindset (and have the room) to be willing and able to. Dave |
20th Oct 2019, 12:51 pm | #8 | |
A cooker in that state might still be used acceptably safely if you could be bothered with the expense of a 3kW or so isolating transformer.
20th Oct 2019, 1:17 pm | #9 |
Plug-in elements were common at one time, my parents had a 'Falco Royal' cooker where evertthing plugged in (and which had a bank of rewireable fuses inside, the rings, oven, grill, timer motor, etc each had their own fuse).
The plug-in rings are close-to-unobtainable now. I tried to get one 25 years ago, no luck. You can sometimes modify the plug-in part to take one of the screw-fixed spiral ring elements used in 1970's cookers (which are a little easier to find). I think I still have one 'large' plug-in element and 2 or so smaller screw-fixed ones on the shelf. If anyone is interested they are welcome to them but they have to be collected from me I'm afraid. |
20th Oct 2019, 1:32 pm | #10 | |
20th Oct 2019, 9:41 pm | #11 |
Come to think of it, I may have actually have an ancient bakelite megger somewhere.
The work continues and diligent cleaning is the way. I've not needed to resort to anything more aggressive than Jif liquid cleaner, a wooden spatula for scraping, scourer pads and a lot of elbow grease. Compare the cleaned grill area with photo 4 in the first post of this thread. Photos below show before and after images of the light glass and chrome surround from the hob light, which turned out to contain a single filament strip light, rather than a pair of pygmy bulbs. Still a long way to go! Every screw is being removed, cleaned with a small wire brush and replaced. A bit of a labour of love.... Steve |
21st Oct 2019, 2:49 am | #12 | |
I never owned an Electric range, so when I bought one, I bought one with the glass cook surface. I don't cook very often, but it is easier to keep clean. Dave, USradcoll1. |
21st Oct 2019, 6:31 am | #13 |
Agreed the glass top "ceramic" hobs are a world away from solid hobs.
As for restoring a cooker, the closest I have got to is stripping down the control panel on the Belling Format my Gran owns, looked much better afterwards. Means it still looks really good (near new) after over 30 years of use (admittedly the glass top was replaced at some point but years ago), it's always nice cleaning up an older piece of equipment and making it look like new. Our Zanussi looks less nice despite the fact that it is much newer, most of that is due to having legends printed on the surface and most of them having been rubbed off, annoyingly a single legend ring is £13! The Belling has all the legends on the back of a piece of glass/behind glass so no amount of cleaning of the front will rub off the legends. |
21st Oct 2019, 9:55 am | #14 |
this takes me back to being a small kid and spending a lot of time at grandparents/aunties houses in the summer holidays etc. they always seemed to have either a pan of chips or slowly simmering boiled spuds on the go, and I knew my nan was getting old, old, when the tins of cakes in the pantry stopped getting topped up, i was always fascinated with the look of these cookers.
21st Oct 2019, 12:46 pm | #15 | |
No Longer a Member
I`ve always had a bit of a fascination with Belling cookers, which I think stems from my grandparents buying one of the very first Belling fan ovens in the 1970`s, and it lasted right up until about 10 years ago and had to be scrapped only because I couldn`t get a thermostat for it |
21st Oct 2019, 1:44 pm | #16 |
My parents had a similar but newer cooker until the mid 1980s, when they replaced it with a Tricity with halogen hob & fan oven.
I think it was a New World, but not sure about it.
22nd Oct 2019, 1:59 pm | #17 |
Five posts split to a new thread: https://www.vintage-radio.net/forum/...d.php?t=160732
30th Apr 2020, 8:34 pm | #18 |
English Electric cooker Part 2
I'm happy to say this cooker is now installed and working. The only problem I came across was with the grill. Like the two rings, it's a plug-in unit and a hefty one at that. The connecting pins are not fixed, but simply stand quite loosely in porcelain blocks, held in position by the stiffness of the element wire, the assembly being retained under a metal cover. Unfortunately the wire had broken just before one of the pins. There was not enough wire left to extend and re-make the connection, which simply involves the wire wrapping around a nut at the end of the pin. The wire is loosely threaded with tiny porcelain or clay beads for insulation. Its not the best design and the only thing I could do was dig out some old fuse wire (probably as old as the cooker) and make a tight twisted connection, ensuring the insulating beads were threaded over it. Very fiddly but to my surprise the grill works- I just hope it holds out.
The hob light was sorted out after I found a NOS tungsten lamp of the original size- unlike the LED replacement I had to hand which was a few mm short of the original length, enough for the holder not to be able to retain it. The cooker looks great lit up in the evening- to my surprise even the Smiths clock works! Steve Last edited by Station X; 30th Apr 2020 at 9:41 pm. Reason: Threads merged. |
2nd May 2020, 10:43 am | #19 |
That looks really great, Steve!! You must have spent an age doing all that cleaning!
It's an odd design with that hotplate at the front and the two rings at the back. What actual benefit is the hotplate? I assume it takes an age to heat up and then to cool down again? Out of interest, is it on a circuit protected by an RCD? Old cooker elements have a habit of being a bit 'leaky' and tend to trip RCD's so I'm surprised you have not had problems if you do have an RCD. I like the period cooker control unit just visible behind the cooker. Presumable next on the list is a period washing machine to go with it! All the best Nick |
2nd May 2020, 10:54 am | #20 |
That's really nice, Steve! Fabulous restoration job.
Yes, the vintage MK cooker control unit caught my eye too. I had one just like it in my kitchen until a few months ago.
Best Regards, Peter. Last edited by Lancs Lad; 2nd May 2020 at 10:59 am. |
