Old 8th May 2021, 2:35 pm   #1
Steve Gibson
Default Huge Stanley Patent Volt Meter
Does anyone know what these were used for, or what they are worth?
I can't think of anything I could use it for, and no matter how lovely it looks, it is not the wife's taste in decoration, so I'll probably have to let it go.
Steve Gibson is offline
Old 8th May 2021, 2:50 pm   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Huge Stanley Patent Volt Meter
They were used for measuring voltage of course. Anywhere for any purpose, but the range marked gives some idea of where it would be useful.
The scale would fit the sort of voltages seen on a 24v battery bank. There would be no interest below 10v that would mean dead flat. The nominal voltage on charge would be around 28V, so the scale has some range for fault conditions.
The even spaced markings would fit with a d'Arsonval moving coil mechanism, which would read DC.
AC was measured with DC instruments using little copper oxide rectifiers, and the meters would not read well until the rectifiers were being driven adequately, so a blank bit of scale at the bottom was not unusual. So that opens up other possibilities. Judging the spacing from zero to 10v, which is disproportionate to the rest of the scale, maybe it was used for AC with a rectifier
It's in the nice quality rather than extra rugged category, so it was probably for a fixed use.
Lots and lots of possibilities, so few clues.
Worth? not a great deal, unless it had some specific and important history.
Radio Wrangler is online now
Old 8th May 2021, 3:48 pm   #3
Steve Gibson
Thanks David, great feedback as always.
I suspect its main worth may now be in the 'Steam Punk' decoration market now.
Old 8th May 2021, 5:05 pm   #4
Radio Wrangler
Singing: "Just glue some gears on it....
Old 8th May 2021, 5:17 pm   #5
Steve Gibson
Old 8th May 2021, 9:01 pm   #6
Ed_Dinning
Hi Steve, looks like a switchboard instrument rather than the type fitted to a traction engine, which would see more severe duty
Ed
Ed_Dinning is offline
Old 8th May 2021, 9:52 pm   #7
Silicon
Some of these large meters may have been used in a classroom or lecture hall.
Silicon is offline
