Old 4th May 2021, 4:42 pm   #1
saddlestone-man
Default NCV Live Test
Hello All
I was scanning some DMMs for sale on eBay and some have a NCV live position on the range switch.
What is this test?
Best rgds. Stef.
saddlestone-man is offline
Old 4th May 2021, 5:11 pm   #2
peter_scott
peter_scott's Avatar
Default Re: NCV Live Test
https://youtu.be/koVPjSOZzUs
peter_scott is offline
Old 4th May 2021, 5:12 pm   #3
dglcomp
Its for Non-Contact voltage sensing, there will be a sensor (usually on the top of the multimeter) that allows it to sense voltage (usually mains potential) and will sound/flash a warning if voltage is detected.
Generally used by electricians so they can check if a wire/cable is live before working on it without needing to access the conductors.
dglcomp is offline
Old 4th May 2021, 6:04 pm   #4
And rather handy to find where cables are in walls, saves that "drill, oops, bang" moment. Another use is locating a failed bub in a series Christmas (sorry, Saturnalia) light string.
Old 4th May 2021, 6:06 pm   #5
saddlestone-man
Ah yes a cable tracer/finder. Useful to have it built into your DMM.
