25th Apr 2021, 4:30 pm | #1 |
K6 phone booth help needed
Good afternoon all. I’m trying to find the dimensions of the hardwood door surround for a K6 ‘Jubilee’ phone kiosk. I have the cast iron window frame insert and have long thought of making a timber surround for it so that it looks more like a phone box door.
Try as I might and short of driving around the countryside tape measure in hand, I can’t find the dimensions... Just the external dimensions of the timber door surround would do it (as I can work out the internal dimensions from the window frame). Any clues? |
25th Apr 2021, 6:36 pm | #2 | |
Re: K6 phone booth help needed
26th Apr 2021, 7:51 am | #3 |
There is a red phone box without a door lying in a field near me, sounds like it should be married to your door.
If you are interested I can ask the land owner if he wants to part with it. Peter |
27th Apr 2021, 3:49 pm | #4 |
I've attached an extract from Drawing 60905 which gives the dimensions of the hardwood door frame.
27th Apr 2021, 4:30 pm | #5 |
I got the wrong door frame, I thought door lining. I love the proper drawing from steve102, teak isn't cheap.
12th May 2021, 4:19 pm | #6 |
Folks!
I’m sorry for my silence. I signed up for email alerts and didn’t receive any so I assumed no replies... Silly mistake. Thanks for all your help and advice and I’m now quite well along with the project. - Though I’ve abandoned the hardwood door surround as too expensive and am now using CLS timber, cut to the appropriate size (or as near as damn it) and painted to match. I’ve just received a replacement handle but I’m disappointed to find that it appears to be silver painted mild steel (or cast metal) and not of the quality or finish that I expected. So if anyone has a spare genuine door handle...! (And this one was sold as genuine). The box without a door lying in a field is tempting but I think I have enough to be getting on with! Thanks again. |
12th May 2021, 4:44 pm | #7 |
What is CLS?
12th May 2021, 7:40 pm | #8 |
Canadian Lumber Standard.
It's the sort of timber commonly used for studwork. Cheers Mike T
12th May 2021, 8:24 pm | #9 |
Hi.
Yes CLS timber very good for studwork and other projects. I've just finished building a small workshop with 3x2 CLS (actual size 63 x 38mm). It has the great advantage of having rounded corners and generally well planed to minimise the risk of splinters. Just ordered some more to build a sturdy workbench for the workshop. Regards, Symon |
12th May 2021, 8:42 pm | #10 |
It's also amqzingly cheap for what it is!
12th May 2021, 9:47 pm | #11 |
Found on FB
https://www.facebook.com/Red-Telepho...28634855485800 Also on FB in groups ( either Openreach (BT/GPO) Friends or Ex BT people ) there a few blokes who's hobby is K6 boxes. |
