Old 25th Mar 2021, 9:29 pm   #1
Martyn K
Default GPO 332 conversion to plug and socket.
Hi, I hope you can give me some advice. I HAVE NO EXPERIENCE AT ALL, but doing a Lockdown project with my son.
We are trying to get a GPO 332L working on a BT line.
I am NOT trying a Ringtone Conversion
I am trying to get it working on the old Pulse signal
So far we can:-
Ring in to the 332L from my mobile phone
The bells ring on the 332L
I can hear the person on the 332L speak to me clearly
BUT:-
The person on the 332L cannot hear me at all
Additionally, when I connect/plug into my home phone socket with the 332L my internet goes OFF until I unplug it
I have NOT been able to ring out from the 332L yet
Possibly the Dial is not good? (12FBR 62/2)
My Line colours are the new ones so I have transposed as below
See LIST below for colours and connections made
My Handset is complete – No. 164
New diaphragm fitted just in case
I am using the existing cord
Green – T3
White – T4
Red – T5
332L LINE cord colours
OLD-NEW BT Plug cord colours
Red-Yellow-B-T9
Blue-Green-Ringer-T11
White-Black-A-T1
Green-Red-spare-not used
Terminals Linked
T1 + T2
T8 + T9
T10 + T11 + T12
Martyn K is offline
Old 26th Mar 2021, 5:37 pm   #2
russell_w_b
russell_w_b's Avatar
Default Re: GPO 332 conversion to plug and socket.
Hi Martyn, and welcome to the forum.
You appear to have the telephone's own capacitor linked in and you shouldn't need that if you're plugging into a line-jack unit.
Could you connect your lead to your telephone as per the attached diagram? My diagram shows the 'traditional' colours that come with a BT standard plug and lead. The numbers on the BT plug read left to right as you look down on the contact side with the lead towards you and the plug-end away from you. Don't worry about a resistor between terminals 11 and 12 for now - a link will be fine.
Name:	332 plug and socket wiring2.jpg
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 26th Mar 2021, 7:47 pm   #3
Dave Moll
Dave Moll's Avatar
Although, as Russell says, you need to disconnect the internal capacitor if you are using the ringing wire from the master socket, I wouldn't expect this to cause the problems you describe, so you may still have a problem after doing so.
Dave Moll is offline
Old 26th Mar 2021, 8:00 pm   #4
russell_w_b
I wouldn't either, Dave, but I thought better to start from a 'clean' plug and socket conversion and take things from there. I run my 1968 Ericsson Dialog with the internal capacitor connected and in parallel with the one in the LJU and it works fine.
Regds,
Russell W. B.
G4YLI.
Old 26th Mar 2021, 8:22 pm   #5
Dave Moll
Dave Moll's Avatar
Indeed!
